OME lift discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by boston23, Mar 21, 2020.
  1. Mar 22, 2020 at 5:55 PM
    texaspete
    texaspete Well-Known Member
    Tyler
    Central VA
    17 TRD OR M/T
    OME Suspension 886 coils SPC UCA’s Dakar leaf pack SCS stealth 6 35” STT Pros Relentless fab bed bars Relentless Front Bumper Baja Designs Fogs Relentless Ditch, hi lift, quick fist mounts. Alpine Designs Cab mount relocation ARB on board air ARB front locker ECGS assembled 5.29 gears Mobtown weld on sliders Mobtown Front skid Mobtown transmission skid Mobtown t-case skid Exhaust re-route Midland GMRS President CB
    I had the 888’s with a stock front and they did great. Dakar medium leaf pack in the rear. But when my Relentless bumper went on, it took a big nose dive. I swapped out to 886’s and couldn’t be happier. So if you’re going to go hybrid & winch, 886 might be the best option.
    LostHusker and boston23[OP] like this.
  2. Mar 22, 2020 at 7:32 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    I had the same set he had. He will be upgrading to 886 soon. We ordered X2 kits on one order and after several thousand miles and weight I needed 886 with the Arb summit bumper, the 888 netted me 1.25" of lift with this massive thing hanging off the front. 886 with PN14 spacers it's at 2.25 front and rear even.
    boston23[QUOTED][OP] likes this.
  3. Mar 23, 2020 at 4:48 AM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    I’m not adding any extra weight, so I’m staying away from the 886’s. I feel like the 887’s will give me what I want in conjunction with my 16” SCS Ray10’s and 265-75-16 DuraTracs.
    I keep thinking about the 888’s, but those might be a bit more height than I need since I’m only going to be running 265-75’s and I’d like to avoid new UCA’s for now.
    The real dilemma I have is what to use for lifting the rear. I don’t haul or tow anything very heavy & I’d like to avoid a harsh bouncy ride. Marie@Headstrong suggested an 1-1.5” block to keep it riding close to stock. She knows her stuff and indicated that there isn’t anything wrong with small blocks. I trust her input.
    However, I know many here are opposed to blocks of any thickness, so that has me also considering doing a 3 leaf AAL. I think a full leaf pack is unnecessary for my situation.
    boston23[OP] likes this.
  4. Mar 23, 2020 at 5:48 AM
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    The OME kit with 888s won't need UCAs unless (possibly) when running a much wider tire like 286/65R16. I didn't need UCAs and was able to get a great alignment with both 10.5" wide 275/65R16s and the taller 10" wide 255/85R16s (what's currently on my truck). I do have a lightweight bumper, winch, a larger battery, and some lights up front.
    Next, I think the Dakar springs with OME shocks in the rear provide a great ride on my 2020 DCSB wether the bed is empty or full of a few hundred lbs of "weekend gear". I've never been a fan of blocks.
    Just had the final combination (OME suspension, 33" Cooper S/T Maxx tires, TRP Pro wheels, Nitro 4.88 gears) out this weekend. We drove about 150 miles on the highway to an event, did 100 miles on a combination of of surfaces from severely pot-holed roads to logging trails, then drove 150 miles home. My princess-and-the-pea lady was very please with the ride both on and off road stating it was way more comfortable than the last time we ran logging roads up north with the TRDOR stock suspension.
  5. Mar 23, 2020 at 7:34 AM
    boston23
    boston23 [OP] Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Hmm thought i had settled on OME but now @JoeCOVA has got me thinking about dobinsons :tinfoilhat:
  6. Mar 23, 2020 at 7:54 AM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Had the ome 888 kit, got a cbi bumper and lost over an inch. Switched to bilstein 6112 with 700lb coil and bilstein 5160 rears, kept the Dakar med leafs and it’s great now.
    texaspete likes this.
  7. Mar 23, 2020 at 9:43 AM
    IrishRed
    Central PA
    Thanks, for the reply. I was under the impression 888’s required aftermarket UCA’s. That’s good to know. However, I think I’m still leaning towards the 887’s. I worry the 888’s might be a tad much with only 265-75’s. I definitely need to give some more thought as to what I’m going to run in the back.
  8. Mar 23, 2020 at 10:43 AM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    What 700lb coils did you switch to?
  9. Mar 23, 2020 at 11:50 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Ha, don't get too distracted, there are a lot of options out there.
    LostHusker likes this.
  10. Mar 23, 2020 at 11:55 AM
    cgs2k2
    cgs2k2 old man
    You'll be fine running a 1.5" block in the back. I have for years on this truck, and did on my last truck as well. Lots of offroading and long trips, zero issues. Never tow anything, and very rarely haul "heavy" loads. I will say that now that I have over 100k on the truck and the original leaf springs are getting pretty tired, I will probably switch everything out for some nice aftermarket springs at this point. But if your truck is newer, throwing a small block on with your stock leafs sounds like it will be sufficient for your situation.
    IrishRed[QUOTED] likes this.
  11. Mar 24, 2020 at 7:36 AM
    TexasTacoma713
    PNW
    2024 OR
    They’re all the same, eibach, headstrong, icon, king. As long as they’re made for 2.5” diameter shocks
  12. Mar 24, 2020 at 2:05 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Also have to compare coil lengths and preload, not just the spring rate.
    boston23[OP] and EchoDeltaSierra like this.
  13. Apr 12, 2020 at 2:41 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Today i saw a member say that dobinsons lower quality than OME.
    Anyone have any thoughts/ experience on this?
    How does dobinsons stack up against OME. I was under the impression is was a smaller company with lower name recognition but slightly higher quality than OME
  14. Apr 12, 2020 at 3:25 PM
    IrishRed
    Central PA
    I’ve never heard anything negative about Dobinson. However, I’ve read a lot of recent complaints about OME coils excessively settling/sagging. Like a lot of things on a forum, you’ve gotta take it all with a grain of salt, do your own research, and make a decision that you feel comfortable with.
  15. Apr 12, 2020 at 3:28 PM
    #35
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    All i know is ronny dahl switched from OME to dobbo’s so......
    JoeCOVA likes this.
  16. Apr 12, 2020 at 5:28 PM
    #36
    JoeCOVA
    Joe
    Colorado Springs
    I think they are pretty close in the end
  17. Apr 13, 2020 at 9:24 AM
    #37
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    I agree. I wouldn't say one is over the other
    Maybe it was just his opinion without actual use and comparison of his own.
    Dobinsons is definitely a lesser-known company since we've only been selling in the USA since 2016, but Dobinsons (1953) as a company is 23 years older than ARB (1976) and OME (1990's-sometime)
  18. Apr 13, 2020 at 12:44 PM
    #38
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Thanks @Crikeymike yeah they seem like theyre pretty much on par, I'm leaning towards Dobinsons because you can grease the bushings. Are both OME shocks and Dobinsons shocks twin tubes?
    Crikeymike likes this.
  19. Apr 13, 2020 at 12:50 PM
    #39
    Crikeymike
    Jax Beach, Florida
    Yes, the standard shocks are twin tubes.
    Dobinsons also offers IMS and MRA Monotube options now, new for 2020.
    The full thread with all options is here: https://www.tacomaworld.com/threads/dobinsons-16-taco-suspension.474308/
  20. May 13, 2020 at 4:21 AM
    #40
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I too have been struggling with which combination to go with. My situation is a bit unique as I've got a double cab long dog, sliders, and full aluminum skids. I have very little intention of getting a bumper. So the truck comes about 150# overweight from the factory, I've added about 225# of armor. I don't know if I should go with 888 coils or the 886 coils. I'm definitely going with the softer ride. When camping, I tow a small travel trailer, no plumbing, no water, about 1600#.IMG_20180831_142108.jpg
