Ome Rear leaf spring Questions? (Please)
Discussion in 'Suspension' started by aidenhardcore, Apr 19, 2012.
  1. Apr 19, 2012 at 5:01 PM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Hey guys, I need help on the ome rear leaf springs pack.( yes I read all the infor on threads).I have the 3inch ome lift kit on my 2010 tacoma. 4x4. I have the top spacers on my truck and rear 2inch aal no tsb. Had the kit for 1 month and the aal are already sagging to low for for liking I knew they were going to sag and go down abit but Im thinking of just getting the new leaf pack for 400. Its sitting level front to back now. . What lift can i get with these. Will my rear be the same height as the 2in aal I have now or would it sit higher with ome leaf pack? How much higher. I put my atv in my bed and carry some heavy things sometimes so I'm thinking of just getting the ome leaf pack and that will complete my 3 inch lift. Thanks guys.
  2. Apr 19, 2012 at 5:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The Dakars lift a DC 2 1/2 - 3"
  3. Apr 19, 2012 at 5:13 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    OK thank you. So does that means my rear is gonna be alittle higher then the aal or stay the same
  4. Apr 19, 2012 at 5:16 PM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
  5. Apr 19, 2012 at 5:17 PM
    OZ-T
    Peter North
    British Columbia
    Measure it centre of hub to underside of fender
    Compare that to this list of average lift results people are getting with the Daks
    http://www.tacomaworld.com/forum/showthread.php?p=3612235
  6. Apr 19, 2012 at 5:18 PM
    OZ-T
    Peter North
    British Columbia
    Lol , John beat me to finding my own thread
    :mad:
  7. Apr 19, 2012 at 5:28 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I just measured it. From the center of the hub to fender. Left and right is 24inchs with 2 inch aal. So from the measurements you guys took, i should only be getting a half inch higher i think if people on the leaf packs getting 24 1/2
  8. Apr 19, 2012 at 5:31 PM
    OZ-T
    Peter North
    British Columbia
    That's correct for a DC
  9. Apr 19, 2012 at 5:36 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    Great thank you. Just one for thing. The new leaf packs shouldn't settle right. I Since there is more leafs in there it should settle fast like an aal right. Thanks. You know your stuff dude haha
  10. Apr 19, 2012 at 5:44 PM
    John3
    Maryland
    You will not regret getting them. It will transform the way your truck rides...it will feel more solid than the factory springs.
    I would recommend getting Wheeler's spring bushings for the Dakars...much better than the factory bushings and easier to install.
  11. Apr 19, 2012 at 5:48 PM
    OZ-T
    Peter North
    British Columbia
    It will settle if you have continuous weight such as a cap .
    My pack has settled 5/8" in 8 months of packing my 200lb Leer cap full time .
    I am going to add the OME AAL for the Dakars , the d29xl
  12. Apr 19, 2012 at 5:59 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    Great. Thanks dude. I cant wait to get them. I have the stock leafs and aal and it doesn't feel right. Idk, I just keep hearing people saying go with ome leaf packs lol. I gonna follow them and get it. People said to get extended break lines if its gonna be the same height as my 2inch aal, i might not need it.
  13. Apr 19, 2012 at 6:05 PM
    OZ-T
    Peter North
    British Columbia
    Get centre pin collars for the Dakars in case you need to add axle shims
  14. Apr 19, 2012 at 6:06 PM
    John3
    Maryland
    I didn't replace my brake lines, but I don't drive off road enough to flex them...plus with the weight of my cap, etc...I don't think I'll need to replace them.
    If you are going to flex your rear suspension a lot, especially with out a cap or tonneau, you might want to get the extended lines. All depends on how you use it.
  15. Apr 19, 2012 at 6:07 PM
    OZ-T
    Peter North
    British Columbia
    As above , I'm on stock brake lines too
  16. Apr 19, 2012 at 6:07 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I have axle shims on my truck now and the aal came with centre pins. Would i need different ones
  17. Apr 19, 2012 at 6:09 PM
    OZ-T
    Peter North
    British Columbia
    Does the shaft of the pins go through the shims leaving the centre pin head exposed ?
  18. Apr 19, 2012 at 6:11 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I dont know haha. Too dark to go outside and check. I will tmw
  19. Apr 19, 2012 at 6:14 PM
    OZ-T
    Peter North
    British Columbia
