on board air system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GYOAZ, Jul 22, 2015.
  1. Jul 22, 2015 at 10:59 PM
    GYOAZ
    GYOAZ [OP] Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    I just ordered a Viair 400h. I'm looking for any advice or pics of a decent mounting location. So far I'm considering somewhere under the hood or in one of my bed compartments. I don't plan on running an air tank, maybe in the future I will. Also I may consider an ARB front locker eventually.
  2. Jul 22, 2015 at 11:04 PM
    G.T.
    G.T.
    CONUS
    Heaps of threads here discussing the same issue, here is one that somewhat combines them all.
  3. Jul 22, 2015 at 11:19 PM
    G.T.
    G.T.
    CONUS
    I was actually checking it out the other day and pondering some ideas but blew them off and bought a new suspension lift to replace the one that I derped and sold.
    Dj Suisav likes this.
  4. Jul 23, 2015 at 12:38 AM
    EBORSETI22
    EBORSETI22 Well-Known Member
    Evan
    New England
    '11 TRD Offroad
    TRD Exhaust Bed Mat Tinted Windows Tonneau Cover Cubby Bed Lights Reverse Lights Anytime Fog Mod Full OME Lift - 887s, LR UCAs, Dakars with D29XXL AAL MB TKO 17" Wheels 255/80r17 ST Maxx CMC Volant CAI with Scoop NFab Running Boards "Raptor" Grille Lights Ditch Lights 30" LED Hidden Light Bar On Board Air
    I actually just finished mounting mine up. Here are some pictures. I used an ARB CKMA12 compressor and ran hose for 2 quick connects - one in the front and one in the rear. You can access all 4 tires with the fill up hose that I have, but this way you should have access to at least 1 of the positions!
    Mounting Location:
    Tough to see, but in the top right of the picture you can see the air splitter and set up I have:
    Front Quick Connect (Follow the front valence line down and you can see it):
    Rear Quick Connect (red hose w/ brass fitting):
    Hope this helps/gives you some ideas!
    -Evan
    da35cent and Dj Suisav like this.
  5. Jul 23, 2015 at 12:42 AM
    GYOAZ
    Gary
    Tucson, AZ
    Thanks for the replies. That's a really clean set up. I'm leaning toward an under the hood set up. I'll have to spend some time assessing the mounting locations under there.
  6. Jul 23, 2015 at 12:46 AM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Thanks. All I need now is some dust caps for the two quick connects so that I can keep debris out of them when traveling! Having a hard time finding them though.
  7. Jul 23, 2015 at 1:59 AM
    GYOAZ
    Gary
    Tucson, AZ
    that's a good piont, one which I hadn't thought of. it can't be too hard to find some caps.
  8. Jul 23, 2015 at 2:08 AM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
  9. Jul 23, 2015 at 3:13 AM
    GYOAZ
    Gary
    Tucson, AZ
    good idea. I may just get one myself and return it if it won't work. I'm headed to the beach in Mexico next week and I wanna have my set up before then. No telling where Ill be able to air up down there I'm sure I'll have to drop my psi out in the sand.
  10. Jul 23, 2015 at 3:22 AM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Yea likely need the set up functioning, and if you have a quick connect in a spot similar to either of the ones that I have, definitely going to want a protector for all that sand getting kicked up etc.
    Have fun!
  11. Jul 23, 2015 at 3:55 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Get some 3 inch tube jigs and cut them down to the size you want. Yes they are for fishing but make great caps. Plus you get a whole package for cheap so it you loose or tear one, your covered.
  12. Jul 23, 2015 at 4:53 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Duct tape son. I know it's ghetto, but it will work temporarily.
    GYOAZ[OP] likes this.
  13. Jul 23, 2015 at 5:34 AM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    It is a good temporary solution! Just found some on Amazon that fit right in them.
    But duct tape for now
  14. Jul 23, 2015 at 8:05 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    For caps you could also check HD or Lowes for the little rubber feet for chairs that go over the legs. I've used those for covers for other things before.
  15. Jul 24, 2015 at 12:19 PM
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    Awesome set up man!!!
  16. Jul 24, 2015 at 12:36 PM
    Tao Zero
    Tao Zero Well-Known Member
    Actually working on this today. I am mounting mine on the bulkhead behind the passenger tail light. I will have many pics of set up when I am done.
  17. Jul 24, 2015 at 1:05 PM
    Michgnxj24
    Michgnxj24 Well-Known Member
    Virginia Beach
    2010 DCSB
    Jeraco Cap, Viair OBA
    This is where I mounted mine. Pretty good location which is out of the way and it was much easier than you would expect to get the compressor in there. The only issue was having to run power to the opposite end of the truck. In the end, I just installed a small Blue Sea Systems aux fuse panel in the drivers side cubby, above the wheel well. Working great so far and now I have all the power I will probably ever need in the back end of the truck.
  18. Jul 24, 2015 at 6:48 PM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Thanks man! Should prove to be very handy I hope!
  19. Jul 24, 2015 at 6:49 PM
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Would love to see some pics of this mounted up. Not the first time I have heard of this location, but haven't seen pics of it before.
  20. Jul 24, 2015 at 9:11 PM
    GYOAZ
    Gary
    Tucson, AZ
    Thanks for the tips everyone. I just got my viair compressor in. I couldn't find a suitable spot under the hood. I ended up going in the passenger side Cubby. I had to do a little bit of trimming off the top of the cubby but it looks pretty clean. I got the metal doors that lock from mob city offroad little while back. I'll get some pics of it up tomorrow.
