Passenger Side Interior Buzzing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hilborn, Feb 16, 2012.
  1. Feb 16, 2012 at 1:34 PM
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Diode Dynamics SL2 Pro LED Bulbs. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I've had this buzzing sound coming from the kick panel and door stil area from about 6 months and it's driving me crazy. I have tried several ways to insulate the areas that I thought that might be giving me a plastic on plastic buzz, without succuss. Has anyone else had this issue and what was your fix?
  2. Feb 16, 2012 at 1:37 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I have the same noise but no clue what it is
  3. Feb 16, 2012 at 1:38 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Is it coming from the speaker?
  4. Feb 16, 2012 at 1:48 PM
    07NavyTaco
    07NavyTaco Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
  5. Feb 16, 2012 at 1:55 PM
    Hilborn
    Michael
    Utah
    It's neither the speaker or the blower motor. You only hear it under light acceleration.
  6. Feb 16, 2012 at 1:59 PM
    07NavyTaco
    Josh
    North Chicago
    are you sure it's not the blower motor? any time i've heard someone complain about a noise on the passenger side, that's the culprit.
    i have the same noise, i just assumed it was the blower motor. i haven't gotten under there to check it out. :rolleyes:
  7. Feb 16, 2012 at 2:09 PM
    Hilborn
    Michael
    Utah
    I've turned off the A/C unit and I still hear it.
  8. Feb 16, 2012 at 2:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sure it's not behind the glovebox ?
    lots of earlier threads on guys with a buzzing in the wire loom that runs behind the glovebox .
  9. Feb 16, 2012 at 2:17 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    Instrument Panel Rattle Below Glove Box (T-SB-0106-10)
    Some 2005 – 2009 model year Tacoma vehicles may exhibit an instrument panel rattle or tick noise below the glove box area. The faint noise is most evident when accelerating slowly between the 1000 – 1600 RPM range. The rattle has been found to be coming from a wire harness cover coming into contact with the HVAC bracket.
  10. Feb 16, 2012 at 5:44 PM
    NC15TRD
    Nick
    PA
    Any idea how to fix?
  11. Feb 16, 2012 at 7:42 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    This noise drove me absolutely insane. It does it at the low rpm needed to drive economically.
    I copied the TSB fix. It essentially tensions up the harness so it can't rattle in its plastic firewall grommet. You'll need adhesive dense rubber foam (I stacked 2 layers each 3/8" thick) and put it between the main harness and the metal bracket where it passes closest to it down by the blower motor.
    Been quiet as a mouse ever since.
  12. Feb 16, 2012 at 9:41 PM
    Hilborn
    Michael
    Utah
    Awesome. I'll try it out. Let you know how it turns out tomorrow night.
  13. Feb 17, 2012 at 5:50 AM
    Hilborn
    Michael
    Utah
    Well thanks to you guys I found what the actual buzzing I had was coming from. Now knowing what I was looking for I was able to search for it on here and locate the issue. Used several pieces of electrical tape, I compressed the loom onto the wires tightly and then zip tied it to another wire loom. Overkill... Maybe. Fixed... Should be. I'll found out later when I go to work this evening. Thanks.
  14. Feb 17, 2012 at 8:43 PM
    Hilborn
    Michael
    Utah
    Didn't work. I'll have my gf sit and ride with me and see if she can pin point the buzz and go from there. I'll let you know what I find.
  15. Feb 17, 2012 at 9:22 PM
    iroh
    michigander
    tonneau
    The wire harness rattle is difficult to find and fix because the source of the rattle isn't actually down by the blower motor. It's the plastic hole in the firewall two feet up the loom towards the engine. That's why just tying it to another point usually doesn't work; it needs to have a little tension put into it. That's what the foam does, it pushes it down unnaturally and it pulls against the firewall a bit.
    If you want to verify it is the rattle I speak of, have her give it a tug when it's doing it. Thankfully it doesn't take a lot of acceleration to start the noise if indeed it is the same problem in your truck.
    To be honest I probably killed every other rattle looking for this one. I used about sixty square inches of adhesive felt on every joint of two pieces of plastic all through the dash trying to find this dumb noise.
  16. Feb 27, 2012 at 9:05 PM
    Hilborn
    Michael
    Utah
    I think I have fixed the issue. I looked up all the other ways everyone else was fixing the issue, and I went in and ended up placing about 7-8 zip ties on several wire looms. On the way to and back form work today, I didnt hear one buzz. I hope it stays like that.
