PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Nov 21, 2013 at 10:50 PM
    #1561
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Ah I feel like you were talking about this in another forum, and his sale thread is on another site other than TW, right?
  2. Nov 21, 2013 at 10:51 PM
    #1562
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yup, it's on the IH8MUD forum. He stopped making them for a while, but started back up back in September. He sales them for cheaper than it would cost to buy everything and make it yourself.
  3. Nov 21, 2013 at 10:53 PM
    #1563
    yote
    Mark
    Tacoma, WA
    So now what would that particular relay block do as opposed to a (Blue Sea or really any brand) fuse block?
  4. Nov 21, 2013 at 10:58 PM
    #1564
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    It allows you to run a lot smaller wires into the cab to switches. The switch is using very little current to activate the relay. That's what the 2amp fuse is for.
    For your light forces, they won't be able to just run with a fuse straight to a switch. You'll need a relay in there as well. That box just cleans it all up I think because it has relays and fuses in one spot.
  5. Nov 21, 2013 at 11:01 PM
    #1565
    yote
    Mark
    Tacoma, WA
    Ahhhhhh ah ah ah.. makes sense. For things that don't need a relay then you wouldn't need one & would just use a fuse then, yeah?
  6. Nov 21, 2013 at 11:02 PM
    #1566
    PcBuilder14
    Brent
    Nor Cal
    Exactly.
    It has the 5 relays for anything that needs a relay. And five 30 amp fuses for anything that uses constant power/doesn't need a relay such as a CB radio.
    Basically gets rid of all of the wiring harnesses that comes with different lights and puts it into one clean box.
  7. Nov 21, 2013 at 11:03 PM
    #1567
    PcBuilder14
    Brent
    Nor Cal
    Those five 30 amp fuses can be used for things that don't need a relay such as a cb radio.
    Here's a pic of the wiring
  8. Nov 21, 2013 at 11:06 PM
    #1568
    ffirg
    mike
    Anchorage, Alaska
    Out of my 7 aftermarket lights/CB on my truck, I have a relay on just the D2s. And that's only because it came with the harness. I normally wouldn't do a relay on any LED light or accessory that draws less that 15-20amps. But that's just ME. a lot of people on here seem to think relay or meltdown on everything. But that's just not true if you choose the right gauge wire and fuse.
  9. Nov 21, 2013 at 11:07 PM
    #1569
    ffirg
    mike
    Anchorage, Alaska
    That thing is super clean. I like it.
  10. Nov 21, 2013 at 11:08 PM
    #1570
    PcBuilder14
    Brent
    Nor Cal
    This is true, but if something were to short out the relay keeps it more contained than just running it straight through a switch
    Agreed :cool:
  11. Nov 21, 2013 at 11:13 PM
    #1571
    ffirg
    mike
    Anchorage, Alaska
    Correct. If there's a short at the battery, the fuse should protect the wiring/switch. If it happens IN the switch, that's a different story. But a relay wouldn't do much there other than reduce the amperage through the switch. But it'd still be shorting.
  12. Nov 21, 2013 at 11:41 PM
    #1572
    yote
    Mark
    Tacoma, WA
    Gnarly. That should definitely do the trick to clean up the wiring
  13. Nov 22, 2013 at 12:09 AM
    #1573
    yote
    Mark
    Tacoma, WA
    Hah, and we were just talking how that was a lot... check this guys light collection out :eek:
  14. Nov 22, 2013 at 12:13 AM
    #1574
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  15. Nov 22, 2013 at 12:14 AM
    #1575
    PcBuilder14
    Brent
    Nor Cal
    That't too much concentrated in one area! Haha
    That's why I just wan't D2's for fogs, a retrofit for headlights, two HID spots and a 40" light bar for fill between the spots and fogs. Might not even bother with the 40" light bar.
  16. Nov 22, 2013 at 12:18 AM
    #1576
    yote
    Mark
    Tacoma, WA
    SO much fcking light.
    The first thing I thought was how much $$$ that would cost.
    I nearly shat myself buying my LF & D2's I can't imagine all of that
    Christ :eek:
  17. Nov 22, 2013 at 12:18 AM
    #1577
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I couldn't spend that much on lights. Too much other stuff I want haha
    I'm still trying to decide what lights I want for spots. I'm thinking LightForce 170's...
  18. Nov 22, 2013 at 12:20 AM
    #1578
    yote
    Mark
    Tacoma, WA
    No shit. My list is getting so long for wish list mods since I've looked through a ton of builds and gathered ideas. Not a good idea.
  19. Nov 22, 2013 at 12:21 AM
    #1579
    PcBuilder14
    Brent
    Nor Cal
    Haha mine's slowly getting shorter....
    Future Mods:
    - Bilstein/
    - 33x12.50x15 KM2's
    - Magnaflow Muffler
    - CO2 Tank System
    - Uniden CB Radio
    - 4xInnovation Rock sliders
    - HiLift, recovery gear, etc.
    - White interior Lights
    - MagLite & Quickfist Mount
    - Diff. Breather Mod
    - Tint
    - Upgraded Sound System
    - HomerTaco M1 Mesh
    - - Ordered
    - Relentless Fabrication Front Bumper - Ordered
    - Rear Icon Remote Reservoir Shocks - Ordered
    - Aux. Fog Lights
    - Winch
    - 2 HID Bumper Lights
    - Skids
    - Aux. Fuse Block
    - Deck Plate Mod
    - Frame Plates
    - U-Bolt Flip Kit
    - BoxRocketFab Bed Rack
    - CVT Tent
    - Light Racing Upper Control Arms
    - 2.5" Extended Travel Icon Remote Reservoir Coilovers
    - HID retrofit
    - Wet Okoles
    - Line-x Bed
    - CBI Bushmaster 1.0
    - Full Size Spare Tire
    - Rock Lights
    - Aux. Reverse Lights
  20. Nov 22, 2013 at 12:21 AM
    #1580
    yote
    Mark
    Tacoma, WA
    Can't go wrong with LF.
    They had my money as soon as I got their 12v plug in 240 spotlight.
    I've shined yotes 300-400 yards away (easy) to where they are clear as day.
    I was impressed.
