Pelfreybilt Hi-Clearance Rear Bumpers
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Feb 27, 2013.
Thread Status:
Not open for further replies.
  1. Feb 2, 2016 at 8:02 PM
    #421
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I just drilled and tapped two holes into the swing out. 2 bolts, washers and lock washers, and it's been solid ever since. I don't have their bracket though (I just made one from scrap i had laying around) so I'm not sure what theirs is made for. I vaguely remember someone saying they were just going to use rivets for it. Don't know if that worked or not :notsure:
    Fonzi25[QUOTED] likes this.
  2. Feb 2, 2016 at 8:38 PM
    #422
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
    What I did was pull the wires out of the loom to give me more wiring so I didn't have to do any splicing. With the bracket, I use a clamp to figure the position, because you can mount the bracket in 2 different positions. What I mean is, the bracket horizontal or vertical the gate. After I have where I wanted the camera, I then drilled 2 holes and used the extra rivets from the table. The view is practically spot on.
  3. Feb 2, 2016 at 9:03 PM
    #423
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Ok I think I know what you mean that helps a bit thanks
  4. Feb 21, 2016 at 6:59 PM
    #424
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    What is the recommended Hi-Jack length for mounting up to the swingout tire carrier? Will the 60" fit or will be that too long to mount up? Any help or input would be great! Also is there a way to lock up the Hi-Lift onto the swing out or do I just use a cable and lock? I have my bumper on order but ETA is mid April. I can't wait! It's killing me.
  5. Feb 22, 2016 at 11:17 AM
    #425
    Socalduckslayer
    Socalduckslayer [OP] Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    You should stick with a 48" jack for the gate. There is not a way provided that locks it but a cable or locking know could be added easily.
    MotoEd likes this.
  6. Feb 22, 2016 at 1:10 PM
    #426
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    Thanks Tyler. That will help me when I buy a new Hi-lift.
  7. Feb 29, 2016 at 11:27 AM
    #427
    mitchellak
    mitchellak Well-Known Member
    Aaron
    Severn, MD
    TRD Tacoma
    Toytec ultimate lift LR UCA DAKARS ICON RR BEEFED Sliders Airflow Snorkel Pelfreybilt hybrid front Pelfreybilt highclearance rear
    The spring mechanism that closes the latch on my bumper seized and I broke the handle trying to get to release. Is there any way to replace these.20160229_142136.jpg
  8. Feb 29, 2016 at 12:10 PM
    #428
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    That's a bummer. I put bearing grease all over the springs on both of mine to avoid this. I would recommend that when you get a new one. Just PM @Pelfreybilt
  9. Feb 29, 2016 at 12:52 PM
    #429
    mitchellak
    Aaron
    Severn, MD
    TRD Tacoma
    Thanks. I'll do that and grease it up if I can get replacement parts
  10. Mar 1, 2016 at 9:36 PM
    #430
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    Do you guys think my stock leaf pack 2+1 (2.7L regular cab) could handle the weight of this bumper (with swingout) for awhile? before i purchased a new leaf pack
  11. Mar 1, 2016 at 9:45 PM
    #431
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    You'll have some bro stance but it's not like you won't be able to drive the truck. You've got bump stops right :thumbsup:
  12. Mar 1, 2016 at 9:48 PM
    #432
    markm0311
    2000 Toyota RAV4
    Haha bro stance. Ok, it's taking me a bit of reading/researching to figure out what leaf pack I need for the extra 190# and keeping a stock height rear end.
  13. Mar 2, 2016 at 5:38 AM
    #433
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    I've got the part numbers for the two T handles if you need them.
  14. Mar 2, 2016 at 9:48 AM
    #434
    mitchellak
    Aaron
    Severn, MD
    TRD Tacoma
    Thanks, but due to typical A+ plus Pelfreybilt service they have already sent me a replacement.
    ready6delta and llibrm like this.
  15. Mar 7, 2016 at 10:44 AM
    #435
    505_BajaYota
    505_BajaYota Active Member
    13 Baja DCSB
    Just pulled the trigger on a hi clearance with swing out this morning!
    The wait begins!!!
    Jim Bob likes this.
  16. Mar 8, 2016 at 11:20 AM
    #436
    snowgod06
    Rob
    06 Access Cab
    Here's a question for everyone with a swing-out and a folding table. Did you have to cut down the studs that are welded on for the wing nuts that hold the table?
    I had to cut them down so far I can barley get a wiz nut to thread itself all the way. If not the studs would rub my tailgate. The still do a little but I can't do anything about it now...
  17. Mar 8, 2016 at 11:54 AM
    #437
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    You may need to move the entire bumper back just a little to get them to clear. Its a tight fit in there.
  18. Mar 8, 2016 at 12:40 PM
    #438
    snowgod06
    Rob
    06 Access Cab
    It's all the way back as possible also lol
  19. Mar 8, 2016 at 1:24 PM
    #439
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Odd, typically they clear by ~an inch and only one or two I know of are very close. The bumpers are all pretty much identical within a very small margin. I wonder if there are differences in the contours on the tailgates, you wouldn't think so. Since I have only heard on one or two that are uncomfortably close like yours it is puzzling.
  20. Mar 8, 2016 at 2:13 PM
    #440
    snowgod06
    Rob
    06 Access Cab
    Huh... that's odd. I wonder if there are slight frame differences? I say because on my HC, the lines of the fender well do not match up with my bumper. It appears pushed forward, but I can't move the bumper back the inch or so it needs.
Thread Status:
