Pelfreybilt Off-Road
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Apr 16, 2012.
Thread Status:
Not open for further replies.
  1. Oct 31, 2013 at 5:33 AM
    #2121
    matt0824
    matt0824 Tin-Toy
    SW< PA
    2012 TRD DCLB Magnetic Grey
    6" Rough Country / 35's / All Pro Front Bumper & Sliders / Warn VR8000 / Bilstein 5100's / PIAA 4" Fogs / ATX Teflon Wheels / 4" Antenna / Clazzio Leather Seat Covers
  2. Oct 31, 2013 at 6:09 AM
    #2122
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    http://www.pelfreybilt.com/#!2005-2013-rear-standard-plate/cmmw
    2005-2013 Toyota Tacoma Standard Rear Bumper:
    All bumpers come standard with 3/4" D-ring mounts.
    Frame mounting points are 3/8" steel.
    Main structure is 3/16".
    At 85 pounds, it's only 10 pounds heavier than factory bumper/hitch combo.
    Options available are:
    1) With or without flush-mount LED reverse lights
    2) With or without hidden hitch (tow capacity not rated)
    Pricing:
    Base bumper starting at $650
    LED reverse light cutouts $50
    Hidden hitch $150
    Powder Coat $100
    Fastenal Shipping is $75-$150 depending on zone
  3. Oct 31, 2013 at 7:10 AM
    #2123
    Socalduckslayer
    Socalduckslayer [OP] Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
  4. Oct 31, 2013 at 7:59 AM
    #2124
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  5. Oct 31, 2013 at 8:14 AM
    #2125
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    I want a bumper that protects what a high clearence needs cut off, could u make sumthen like that? With some additional deflection tubes sticking out to push you away from what ever you come up on?
  6. Oct 31, 2013 at 8:15 AM
    #2126
    machineman89
    Matthew
    San Leandro
    Iam not really up to cutting my truck if I can avoid it
  7. Oct 31, 2013 at 8:20 AM
    #2127
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Unfortunately I am not in a position to take on any prototype or custom projects for a while due to current backlog. There are some companies that have bumpers like that already. All-Pro comes to mind, they have the optional additional coverage without cutting.
  8. Oct 31, 2013 at 8:29 AM
    #2128
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I wasn't either but I knew I would be more pissed if I crunched that rear quarter than just get it over with... All really depends on how crazy you get offroad. aaaand depending on the protective tubing design it doesnt really garauntee protection either
  9. Oct 31, 2013 at 9:28 AM
    #2129
    machineman89
    Matthew
    San Leandro
    I was looking at the all pro one, u dnt gaping too much more clearence from what I could tell by cutting and goin high clearence, well by the tail gate anyways
  10. Oct 31, 2013 at 9:31 AM
    #2130
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Gained almost 5" at the fender flare on my ATO. 4.5" at the rear end. Plenty to be gained by cutting, and if your worried about damaging the qtr panel you might as well cut it and do it all once.
  11. Oct 31, 2013 at 9:35 AM
    #2131
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Cutting ang going hi clearance adds a little more clearance. Main thing is the gained rigidity of the plate material in the area that can become damaged. If you don't get into bad situations often you don't need to cut. I have hit my hi-clearance several times but typically in the rear where a standard one would be fine. I have hit it up closer to the wheel well where the sheet metal is removed only a couple times but was happy I had the bumper.
    Not only does it tear up the sheet metal but often gets the tail light etc when you impact that area.
    If you wheel based on what protection you have you are fine with a standard rear
  12. Oct 31, 2013 at 9:52 AM
    #2132
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I dented/scratched the lower rear fender on the passenger side while trail running and this with careful driving when I had to turn around on a too narrow trail and tangled with a stump and some brush. The good news is I cut that part off when I put on my HC Rear bumper.
    If you rock crawl at all or drive narrow trails a High Clearance is a good investment in my opinion. I would sure hate to buy a no-cut bumper and then bash in the lower fender!
  13. Oct 31, 2013 at 10:13 AM
    #2133
    machineman89
    Matthew
    San Leandro
    Guess its like a band aid... it hurts but faster the better
  14. Oct 31, 2013 at 10:18 AM
    #2134
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    You could say that, or just think of the cutting like this, the first inch takes a little warming up to get ready but once you get into it you'll be glad you did.
  15. Oct 31, 2013 at 10:19 AM
    #2135
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    sounds like doin it for the first time :laugh:
  16. Oct 31, 2013 at 11:34 AM
    #2136
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I can attest to this, before I got my HC bumper I smashed the rear quarter panel, the stock bumper, and the tail pipe. Popped my tail light out snapping all the tabs holding it on.
  17. Oct 31, 2013 at 11:44 AM
    #2137
    machineman89
    Matthew
    San Leandro
    Having the strength and support makes a difference and having the clearence does keep you from getten hung up
  18. Oct 31, 2013 at 2:03 PM
    #2138
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    The biggest plus to the HC bumper is the chicks it pulls at the mall...chicks dig a nice rear bumper.
    Case in point here...this is an irresistable ass.....u know u want it
  19. Oct 31, 2013 at 4:08 PM
    #2139
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    I have the all pro with the side guards. I should have just cut the bed but the local options weren't as good as they are now. The all pro sides help some but I landed on the drivers side pretty hard once and bent the bed side a little. They were great till the rear slipped off a rock, sure it was better than nothing but it did flex and bend some.
  20. Oct 31, 2013 at 11:38 PM
    #2140
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Wish y'all sold 1st Gen armor :pout:
Thread Status:
