Possible transmission issue??? 2015 TRD
Discussion in 'Technical Chat' started by House Forsaken, Mar 18, 2016.
  1. Mar 18, 2016 at 4:51 AM
    House Forsaken
    House Forsaken [OP] Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    Hi Guys,
    I recently purchased a 2015 TRD OR. The past few weeks I've noticed after long drives without stops, ie. highway driving. When I do come to a stop light where the truck is stationary for a while, it will bump/lunge...almost like it was hit from behind. The truck has 12K as well...
    Has anyone else experienced something like this?
    I'm afraid to take it back to the stealer and have them tell me they didn't find anything...
  2. Mar 18, 2016 at 5:10 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    How severe is the lunge?
    Ever since I've had my 2015, I've noticed that when sitting at a stop light for any longer than about 10-15 seconds, the truck sort of "winds up" and lunges forward. It's not severe enough that it feels dangerous or that I would lose control, but it's noticeable enough that I have to apply more pressure to my brakes to counter it.
    Sound like the same deal?
  3. Mar 18, 2016 at 5:12 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    Is the A/C compressor on?
  4. Mar 18, 2016 at 5:13 AM
    House Forsaken
    Paul
    It's like letting off the brake and pressing it down hard again.
  5. Mar 18, 2016 at 5:13 AM
    House Forsaken
    Paul
    No, AC is not on
  6. Mar 18, 2016 at 5:15 AM
    House Forsaken
    Paul
    That sounds exactly what I'm experiencing...it seems almost like it down shifts late and hard. I too press the brake hard because it feels as if the truck is moving
  7. Mar 18, 2016 at 5:15 AM
    Arailt
    Dallas, TX
    2019 GX460
    No defrost? The compressor is also on when system is on defrost.
    The reason I ask is my truck often lunges while stopped when my compressor is on. Not terribly, but noticeably.
  8. Mar 18, 2016 at 5:17 AM
    House Forsaken
    Paul
    I do run the mix of floor and defroster, but the compressor isn't on on that setting...
  9. Mar 18, 2016 at 5:22 AM
    Arailt
    Dallas, TX
    2019 GX460
    I'm almost positive that both the defrost and defrost/floor settings engage the compressor. Maybe someone else can confirm.
  10. Mar 18, 2016 at 5:22 AM
    tacoguy26
    tacoguy26 Well-Known Member
    Trevor
    San Ramon, CA
    Sold :(
    in my 2015, I'm pretty sure my compressor kicks on on that setting. I too notice the "lunge" when at a stop light.
    Arailt likes this.
  11. Mar 18, 2016 at 5:24 AM
    Arailt
    Dallas, TX
    2019 GX460
  12. Mar 18, 2016 at 5:24 AM
    House Forsaken
    Paul
    The AC light doesn't come on, nor does it blow ice cold air. I though I had read somewhere on here that full defrost as well as the coldest setting will turn on the AC, but not the floor/defrost mix.
  13. Mar 18, 2016 at 5:28 AM
    House Forsaken
    Paul
    That is interesting! I will have to take a look. Wouldn't I have worse mileage if the AC was kicking on...because the other day I accidentally had it on for a while and noticed a significant drop in my mileage...
  14. Mar 18, 2016 at 5:31 AM
    Old School
    Old School You are ignoring covfefe by this member.
    @gearcruncher
    I have been having trans problems since early, main problem, after accelerating up to freeway speed, I ease up on the throttle, and it bangs into O/D.
    I've complained since early on, finally got the fluid level checked and it was over 3/4 qt low on fluid!
    Since then, I've had a master tech duplicate the experience, and he put the trans back in learn mode, but still experiencing the bang into O/D!
    I have several cross country road trips, including 2 towing a trailer.
    If the trans continues like this I will be requesting a new trans be installed.
    I know this isn't the same issue as the OP, but let's see if any other '15s are experiencing trans issues!
    Hope Gearcruncher doesn't mind, here's a note from a PM between us...
    "4TH GEAR TO 5TH GEAR UPSHIFT . Reports at TRNI indicate the SLT solenoid has issues .
    http://www.moranbahweather.com/toyota/lc_trj12/rm/rm1151e/m_05_1113.pdf
    The flash also fixes the clunk upshift to 5th gear http://www.tacomaworld.com/forum/technical-chat/344879-tsb-0044-12-pinging-transmission-fix.html
    I am sure you read this , but I thought I should pass it along"
    gearcruncher likes this.
  15. Mar 18, 2016 at 5:33 AM
    Squishy
    Squishy Member
    Darryl
    Fitchburg Wi
    Tacoma 4 dr 4WD TRD Off Road
    If you have the heater controls on any of the defrost settings the AC compressor will cycle on and off . Most cars and trucks have this function. My 2014 Tacoma does this also.
  16. Mar 18, 2016 at 5:34 AM
    Arailt
    Dallas, TX
    2019 GX460
    Yeah, my mileage suffers when I'm running the AC or defrost as well. Not so bad on long highway trips, but definitely in stop-and-go traffic.
    If you want to follow those steps to disable defrost AC, make sure you click on the "2009+" link at the top of the page. That write up is for <2008.
  17. Mar 18, 2016 at 5:35 AM
    House Forsaken
    Paul
    Good to know...I'll run with this off or on a different setting and see if I still get this bump. Thanks!
  18. Mar 18, 2016 at 5:36 AM
    House Forsaken
    Paul
    I'll definitely be taking a look at that mod over the weekend! Thanks!!!!
    Arailt[QUOTED] likes this.
  19. Mar 18, 2016 at 5:37 AM
    House Forsaken
    Paul
    Wow! That sucks. I haven't had anything like this.
  20. Mar 18, 2016 at 5:41 AM
    gearcruncher
    Canadain bumper technician
    AC compressor by the sounds of it . My truck also does this .
    Old School has an issue with his truck we are trying to figure out .
    I am working on it . Running low on transmission fluid while towing will definitely cause issues .
    Old School likes this.
