Power at Cigarette lighter with key off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TRDSPORT, May 8, 2012.
  1. Aug 26, 2012 at 3:35 PM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    Op when I did mine the relay was in the cab to the left below the steering wheel,and I took the relay out and put in a 14 guage jumper wire worked like a charm
  2. Aug 26, 2012 at 3:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's where it is on 2nd Gen.
    1st Gen it's under the hood.
    I'll just repost this here since the link was on the 1st page....
  3. Aug 26, 2012 at 4:30 PM
    brny67
    Bill
    Moyock NC
    08 TRD Sport A/C
    My bad I thought it was a 2nd gen
  4. Jan 13, 2013 at 12:54 PM
    2011TRDSPORT
    2011TRDSPORT [OP] Well-Known Member
    Len or Lenny
    Kamloops, BC, Canada
    Tacoma TRD Sport. Magnetic Gray
    2" front and rear.
    I still haven't had the chance to do this mod yet. Does anyone know if there are other accessories that run off this relay or is it just the cig lighter?
  5. Jan 13, 2013 at 2:51 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Just the lighter.
  6. Jan 16, 2013 at 11:49 AM
    2011TRDSPORT
    Len or Lenny
    2" front and rear.
  7. Jan 16, 2013 at 4:54 PM
    jgunccrugby
    jgunccrugby Well-Known Member
    Mount Holly, NC
    13 PreRunner SR5 DBL Cab
    Tacoma Seat Covers, Tacoma Kick Guards, Nerf Bars, Front window tint. To come: Bull Bar
    I just added one directly, it wasn't difficult.
  8. Jan 16, 2013 at 5:46 PM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Jason, is that a double USB outlet?
  9. Jul 11, 2013 at 11:13 AM
    gsw721
    gsw721 New Member
    prerunner sr5
    hey, i hope someone still reads this!
    i just bought a 2013 tacoma. i am trying to install my sirius portable radio with the car adaptor. it uses the cigarette lighter for power but since they shut off with the engine, it has to reboot every time the car is started. that takes too much time and is annoying. I have looked under the hood and under the steering column and do not have any relays that say power outlet. there is a fuse under the steering column that says power outlet but it is a standard 15 amp fuse. do you have any ideas where else i can find the relay? i can live without the relay mod if i am able to hard wire into the fuse block, but 1) any idea what fuses are always on? and 2) how do i do that? i plan on cutting the plug off and either grounding one wire and attaching the other to a fuse, or attaching both wires to both sides of the same fuse...which ever one is correct.
    any help would be fantastic!
  10. Jul 21, 2013 at 7:08 PM
    gsw721
    gsw721 New Member
    prerunner sr5
  11. Jul 21, 2013 at 8:44 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
  12. Jul 23, 2013 at 1:53 PM
    DBF
    DBF Well-Known Member
    2012 Tacoma, 4x4.base model, access cab.
    Another bump. I have a 2012 and also can't find this relay.
  13. Jul 24, 2013 at 5:43 AM
    gsw721
    gsw721 New Member
    prerunner sr5
  14. Jul 24, 2013 at 6:37 AM
    12DblCab
    12DblCab I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    The fuse panel you need to access for 2012+ models is behind the lower part of the dashboard, to the left of the steering wheel. If I remember correctly, I took out a few screws and took off that piece of the dashboard. Then there is one screw that releases the fuse panel, and I believe the cigarette lighter relay you need to alter is on the back side of the fuse panel. The relay is about an inch wide and tall (not sure what the label is). Once you remove the square relay, you pry it open with a small screwdriver, and it should look like my picture in post #20. You just cut a little piece of plastic to shove in there to keep the relay open. Some people use a little piece of folded electrical tape.
    It's been a while since I've done it, and I don't want to take my car apart again to do a write-up. If someone does it, take pictures and make a write-up for everyone else.
    This link might help. I didn't unplug any wires from the fuse panel just to access it like this guy did, and I don't think I unhooked the hood release.
  15. Oct 14, 2013 at 11:00 PM
    #35
    2011TRDSPORT
    Len or Lenny
    2" front and rear.
    I FINALLY got around to doing this mod. My truck is a 2011. You actually need to put something in it to keep the relay CLOSED. Not open. I would think it's the same for a 2012+. Just cut a piece of plastic or rubber to keep the contacts together. I used electrical tape and after the first day, it stopped working with the key off. The second time I used a piece of plastic. After already taking it apart once, it literally took me 5 minutes to do it again. Easy job and well worth it!
  16. Oct 14, 2013 at 11:07 PM
    #36
    Rich91710
    Rich
    Los Angeles
    08 Base
    Old (reversible) mod from Tundrasolutions was to slip a piece of credit card (or last year's AAA card) between the NC contacts.
    Non-reversible mod is to simply solder a jumper across the blades, or open the relay up (as needed for the credit card mod) and solder the NO contacts closed.
  17. Nov 10, 2013 at 9:55 PM
    #37
    2ndchancetoyotas
    2ndchancetoyotas Well-Known Member
    Greg
    AZ
    Rebuilt
    Good lord people, just put in a jumper wire with blade terminals. Why would you rig a relay?
    clinteastside and Norton like this.
  18. Nov 10, 2013 at 10:41 PM
    #38
    Rich91710
    Rich
    Los Angeles
    08 Base
    Because people will run the jumper between the wrong contacts and smoke their harness.
  19. Apr 27, 2015 at 12:36 PM
    #39
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Bringing this thread back to life! Please elaborate on what wires your would jumper with blade terminals? I have a 13 and I want full time power to acc outlets!
  20. Aug 30, 2016 at 1:48 PM
    #40
    wlandrum
    wlandrum Member
    Pasco, WA
    '12 Tacoma DC/LB, Mag Gray, TRD Sport
    Did you ever get this figured out? I am interested in doing this as well.
