Prerunner wheel bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by BaxInky, Jan 12, 2020.
  1. Jan 12, 2020 at 4:15 PM
    BaxInky
    BaxInky [OP] New Member
    01 prerunner 4cyl
    I have an 01 prerunner 4 cylinder 2wd, I’m trying to replace the wheel bearings in the front end but in order to get to the bearing to press it out there’s a gold bearing nut with 4 holes on it, does anyone know what size it is or a part number or something on it? I bought another 4 prong socket and it was for gm and it was to small, bought another 8 prong socket for Toyota and was going to take 4 of the studs out but the socket itself was slightly to big, I see all kinds of kits with 6-7 sockets in them but not sure if it would be the right size
  2. Jan 12, 2020 at 4:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Jan 12, 2020 at 4:33 PM
    BaxInky
    01 prerunner 4cyl
    You just made my day sir thank you
  4. Jan 12, 2020 at 5:36 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    I took apart my hub assembly yesterday as I am replacing my bearings also. I just used a punch with hammer and tapped it out. Took a couple hits came out beautiful. I plan on reusing the nut.
  5. Jan 13, 2020 at 8:49 PM
    BaxInky
    01 prerunner 4cyl
    Tried that and put Allen wrenches in and tried to turn with and extension and it didn’t budge, the socket gets here tomorrow
  6. Jan 13, 2020 at 8:58 PM
    Moonrman
    Hill Country, TX
    Yeah I tried some stuff like that, stabbed some Allen wrenches in the holes and took a wrench to leverage between. No luck. Just beat em out with a punch.
  7. Jan 13, 2020 at 9:00 PM
    Moonrman
    Hill Country, TX
    Don't get me wrong, having proper tool always best. Good luck and hope all works out for you.
  8. Jan 13, 2020 at 9:05 PM
    Moonrman
    Hill Country, TX
    Replacing bearings sucks
    BaxInky[OP] likes this.
  9. Jan 19, 2020 at 11:13 PM
    Green Croc
    Green Croc Active Member
    Green 01 Tacoma
    New wheels , painted grill, seat covers
    Is there a write up for how to change them?
  10. Jan 20, 2020 at 5:33 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Green Croc likes this.
  11. Jan 20, 2020 at 7:50 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Green Croc[QUOTED] likes this.
