Pro comp lift...
Discussion in 'Suspension' started by toyo freak, Feb 13, 2011.
  1. Jul 19, 2011 at 10:19 AM
    #441
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man.. that's why I was asking. The top plate spacer really isnt a lift tho. I think Its like 10mm. Thats it. I just want to level It again. I'm happy with the performance of the pro comp kit. It did give me three inches, but noe the front has settled so It doesnt sit as level as id like. I'm not looking to get more lift for bigger tires or anything. My cv angles are fine too. Never have had any problems and it goes anywhere off road. They made those top plate spacers for a reason right? I Mean they should work.. unless they are only for the 5100's.. I don't wsnt to replace the entire suspension cuz Im actually really happy with this kit.
  2. Jul 19, 2011 at 11:39 AM
    #442
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    I was thinking the same thing, just a little more lift up front would be perfect.
  3. Jul 19, 2011 at 11:48 AM
    #443
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I emailed toytec and asked them some questions about. Just waiting on a response. I think two 1/4 spacers (one each side) would be enough. They raise it a half an inch. they dont preload the springs since its on top of the coilovers. We will see.
  4. Jul 19, 2011 at 1:34 PM
    #444
    St. Swervus
    St. Swervus Well-Known Member
    Nathan
    Mill Creek, WA
    '09 Double Cab TRD Sport
    Leer Camper. Thule Rack, NFab side rails w/step, 3' lift, Weather Tech mats, Paracord grab handles, LED interior lights, Bed Rug, Front windows tinted to match factory rears.
    It's a little stiffer than stock but no big deal. Supposedly it'll settle down even more. I need to look in to removing my sway bar. The kit was coils and AALs and shocks. I love it!
  5. Jul 19, 2011 at 2:12 PM
    #445
    Blacktacoma23
    2011 Mall Crawler
    Yeah man ditch the sway bar.
  6. Aug 11, 2011 at 4:33 AM
    #446
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    Maybe y'all have had this problem or maybe its not even a problem at all. I got this kit the coils and the AAL's everything was fine for 15K miles then when I rolled over 25K on my truck the steering wheel shakes back and forth at about 40-55 ish. So I put a new steering rack on and it still does it but only when it wants to. Like I could be going 45 for 5 min then all of a sudden it quits then when I go around a turn it does it again. I have had 3 places tell me everything up front is tight. Tires plus, Toyota, my buddy mechanic. Im running 20s on 33x12.5. Toyo mts. I was also wondering if y'all could take some pictures of the front sway bar bushings/brackets so I can compare to mine. I reaaly want then wobble in the wheel to go away. If it's easier for you to txt me the pictures I will be more than glad to give my number.
    Help pleaase!!
  7. Aug 11, 2011 at 5:11 AM
    #447
    NoDrAmA357HK
    NoDrAmA357HK Well-Known Member
    Michael
    North Carolina
    2011 Timberland Mica DBL CAB 4x4 TRD Sport
    3" Pro Comp w/ AAL, 17x9 -6 Offset 4.75 Backspace Pro Comp 7033, LT285/70/17, Xtreme M/T Pro Comp - 67285
    Take pics of your front inner mud flaps....No Rubbing? How is the ride on 20's?
  8. Aug 11, 2011 at 6:25 AM
    #448
    francis1291
    What does that have to do with my problem lol? I don't think the mud flap has anything to do with the steering problem.
  9. Aug 11, 2011 at 4:23 PM
    #449
    francis1291
    Yes they did. I got free tire balances on all tires since that didn fix the problem. I honestly think I have tried everything. The tires are fine. No coupling or anything like that. My uncle thinks it could be I rotated them to much. I did it every 3K and moved the front straight back and then crossed the back up front. Idk.
  10. Aug 11, 2011 at 4:27 PM
    #450
    francis1291
    Maybe the tires didn't like that????? Idk really.
  11. Aug 11, 2011 at 4:30 PM
    #451
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Wheel bearings.
  12. Aug 11, 2011 at 4:34 PM
    #452
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  13. Aug 11, 2011 at 4:37 PM
    #453
    Tacomanator
    Clam Slammer
    Southern Cali
    I quoted the wrong post lol. Meant to quot this one...
    Wheel bearings.
  14. Aug 11, 2011 at 4:41 PM
    #454
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Haha.. its all good.
  15. Aug 11, 2011 at 8:19 PM
    #455
    francis1291
    21K. Yes tired couple places.
  16. Aug 11, 2011 at 8:20 PM
    #456
    francis1291
    I have not checked that but will that make my steering wheel woble??
  17. Aug 11, 2011 at 8:52 PM
    #457
    Tacomanator
    Clam Slammer
    Southern Cali
    Yes, especially with your heavy ass wheel/tire combo. Your steering rack will also wear prematurely. Check your tie rods and ball joints too.
  18. Aug 11, 2011 at 9:11 PM
    #458
    francis1291
    Never thought of wheel bearings. Got to see how much that will cost. Kinda pissed off. Spend 520 bucks on a new steering rack and its still not fixed. Tie rods and ball joints are good.
  19. Aug 11, 2011 at 9:53 PM
    #459
    Tacomanator
    Clam Slammer
    Southern Cali
    Yeah man, def check those out. Just jack the front end up and try wiggling your tire back and forth. If they have any play in them, then it's probabbly your wheel bearings.
    Hope you figure it man! Good luck.
    Edit: Here are some part #'s for wheel bearings, tie rods etc. http://www.tacomaworld.com/forum/2n...el-bearing-replacement-part-s-general-bs.html
  20. Sep 26, 2011 at 2:38 AM
    #460
    DV88
    DV88 Active Member
    Dustin
    Redding
    Rock Rails Rear Bumper in Progress Skid Plates in Progress
    i want to see more pics!
    anyone have a heavy bumper with this kit?
