Problem after taking vinyl sticker off window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Djarmpit, Jan 28, 2013.
  1. Jan 28, 2013 at 7:36 AM
    Djarmpit
    Djarmpit [OP] Well-Known Member
    So I peeled off a vinyl sticker after 2-3 months but it's still there and noticeable at certain angles. Anyone have any advice on what I can use to get rid of what's still there? Thanks!
  2. Jan 28, 2013 at 7:39 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    If it on your glass just use a razor and glass cleaner to scrape the glue off or you could try goo-b-gone. Try make stuff to take the glue off..
  3. Jan 28, 2013 at 7:41 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Odessa, TX
    OME Lift
    My mom had the same problem on her 4runner. We used tried lots of different things but nothing worked. Eventually after several washes it went away.
  4. Jan 28, 2013 at 7:41 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    Make: Chevy Model: Pile
    Yes
    Oh no!!!! Another sticker removal thread!!!! :goingcrazy:
    OP try some goo gone on that adhesive. Rubbing alcohol or WD40 would work also.
  5. Jan 28, 2013 at 7:42 AM
    tex
    tex Well-Known Member
    Aaron
    Arlington, TX
    2015 4 Runner Trail
  6. Jan 28, 2013 at 7:42 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    I was scared to comment thinking of the other one
  7. Jan 28, 2013 at 7:46 AM
    fsbrain03
    fsbrain03 Well-Known Member
    Good luck getting reliable help OP. these guys just want to joke and call you names. But yes, check out the thread that Tex posted. Should at least get you started.
  8. Jan 28, 2013 at 7:50 AM
    TexAggie
    Eric
    Odessa, TX
    OME Lift
    :stirthepot:
  9. Jan 28, 2013 at 11:00 PM
    Djarmpit
    Thanks everyone. I'll try the goo gone
  10. Jan 29, 2013 at 12:14 AM
    brokeincollege
    brokeincollege 1<3
    bay area
    11 4x4 DC/LB TRD Sport
    Use 0000 steel wool, it won't scratch your window. It will actually polish and clean your window. 100%. I just took off a sticker and used a razor to remove the big gunk then used 0000 steel wool to clean the rest. Window is super clean now.
