Problem when taking turns...
Discussion in 'Technical Chat' started by BlissTaco, Nov 9, 2009.
  1. Nov 9, 2009 at 1:32 PM
    BlissTaco
    BlissTaco [OP] 2022 TRD Offroad
    James
    San Diego
    22 TRD Offroad 4x4
    Kings, Method 701, Toyo AT3 285/70R17, interior/license LED's, tonneau cover, Subaru tweeters
    I am having a problem that I hope someone can help me identify. I just installed 2.5" Coilover and had the alignment done. When I am taking an agressive turn (right turn from what I have noticed) the truck beeps and feels like I am driving on gravel. I am not sure what this is. From what I have read it sounds similiar to what should happen when the brakes over heat, but it only happens in sharp turns, or maybe what the anti lock brakes would do. Any help would be much appreciated. I am taking it in to the dealer tomorrow, but sometimes I think there is more knowledge on this site then in the shop.
    Thanks!
  2. Nov 9, 2009 at 1:39 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Sounds like VSC is engaging.
  3. Nov 9, 2009 at 3:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Need more information....
    Did you change wheels & tires? If yes...what size, backspacing, etc.
    What exactly do you mean by 'beeps'?? Is there something in the cab electronics that are beeping at you?
    When you are turning and this is occuring, are you using the brakes? Can you see or feel the brake pedal pulsating?
  4. Nov 9, 2009 at 4:44 PM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    I did change the wheels and tires. Changed wheels to the FJ wheels (16x7.5 - 4.5BS) and tires to 265/75/16 load range E. But I had the wheels and tire on for a week before the suspension change and never noticed a problem. The load range wheels do make me wonder though...Yes somthing in the cab electronic beeps. Also, I think somthing red lights up, but I can't see because I am turning.Once I was using the brake, but another time I don't think that I was. I drove a long windy distance using the break frequently, but only occurs in a constent turn. Not sure if it the brake or not, but defenitly pulsating.Thanks again for any input.
  5. Nov 9, 2009 at 5:09 PM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Hmm...
    Same thing happened to me about 2-3 times since I installed a 3" lift. Guess we'll wait and see what the tech guys think.
    2009 4x4 DC TRD Sport
  6. Nov 9, 2009 at 8:33 PM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    Ok I was able to duplicate this again on my way home. I was taking a turn (freeway on ramp) without use of brakes. Also, I did see the light that came on. It was the car with the squiggly lines under it. I don’t have A-trac so it must be the auto LSD. But why would this happen? How can I resolve this problem? Did I do somthing wrong with my suspension?
  7. Nov 9, 2009 at 9:14 PM
    kento1987
    kento1987 Member
    Kent
    Arkansas
    06 TRD OFF-ROAD
    Same thing happens when I take relatively sharp curves.
  8. Nov 10, 2009 at 4:26 AM
    Janster
    Jandy
    Lancaster, PA
    This might have to do with the wheel sensors.
    I haven't ever looked myself, but there should be some wiring & plugs going to the sensors at each wheel. Jack up the front end and turn the wheels to each LOCK (both). Crawl underneath the truck (make sure its properly supported) and check the wiring & the plugs. Unplug them & plug them back in. Make sure the connections are clean. When the wheels are turned fully, make sure they're not pulled too tight or kinked. Check both sides.
    If you find some that are too tight, simply follow the wires - they might be attached via Toyota clips that you might have to cut in order to prevent it from pulling too tightly.
  9. Nov 10, 2009 at 6:36 PM
    kento1987
    kento1987 Member
    Kent
    Arkansas
    06 TRD OFF-ROAD
    Are these the tire pressure sensors?
  10. Nov 11, 2009 at 10:55 AM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    Thanks for the input. That seems logical because on a banking turn one side is being compressed and the other is being extended. Possible causing an issue with sensor connections. I havnt had time to inspect in the daylight, so I have dropped it off at the dealer. I will keep ya'll posted.
  11. Nov 11, 2009 at 12:07 PM
    Janster
    Jandy
    Lancaster, PA
    Nope....
    The Tire pressure sensors are in your wheel. They're a part of the valve stems.
    The sensors I'm referring to - are wheel speed sensors. It sends info to the ECM about the 'speed' your wheels are going. The ABS (& other) systems use the wheel speed sensors so they know when the wheels aren't moving, slipping, etc.
  12. Nov 11, 2009 at 6:22 PM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    Nothing from the tech. Everything checks out to them. Could not even duplicate the problem. I am thinking it has to do with the stance of my truck. I have the front about an inch higher then the back (stock). When I am making a banking right turn the front passenger side lifts and I think enough to cause the truck to engage VSC? I have done some reading on the VSC/LSD/Trac and I am going to try the different options where I no the problem happens. Maybe upgrading the rear shock would help the balance the front and the back?
    What are your guy's measurements?
    Mine are (with 265/75 tires):
    Driver Passenger
    Front: 37.75" 38"
    Rear: 37" 37"
  13. Nov 12, 2009 at 3:18 AM
    Janster
    Jandy
    Lancaster, PA
    If they couldn't duplicate the problem - then they probably didn't check anything.
    Did you check the wiring & plugs at each front wheel? Sometimes all you need to do is unplug the connectors and plug them back in. We had the same problem in our corvette, kept tripping the traction control lights at tight turns....
  14. Nov 12, 2009 at 10:23 PM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    So right you are. They did nothing. I am going to try and check the sensors this weekend. Turning the vsc off did not even work.
  15. Nov 13, 2009 at 4:06 AM
    Janster
    Jandy
    Lancaster, PA
    And again, I'm not familiar with the tacomas system....but I think the wheel speed sensors are also a part of ABS.
    Good Luck!
  16. Nov 15, 2009 at 2:47 PM
    nedhead
    nedhead Member
    Rocky Mountains, CO
    09 Tacoma Dbl Cab LB SR5
    I have the very same problem. I live in the mountains and drive mountain roads to get everywhere. Sometimes as I take a turn the (VCS?) engages on the outside front wheel applying the ABS brake on that wheel. I just had snow tires put on my new 2009 Tacoma Double Cab and that's exactly when the problem started. The new tires are 265/75R16 load rated E, replacing the stock 245/75R16. Please post a solution if you find one. Thanks.
  17. Nov 15, 2009 at 3:08 PM
    dlthunder
    dlthunder Well-Known Member
    Dan
    Reno, NV
    Sold my Taco
    TRD Skid Plate Rear Seat 11inch DVD Toyota Bed Mat Pace Edwards Full Metal Jackrabbit Nerf Bars Tailgate Electric Dynolock D-ring Bedbolts
    There is a lot of talk about this in the suspension section. Do a search for "Lift with VSC" and one of the guys posted a PDF with how to recalibrate it. If I knew how to link I would have done a link on here.
  18. Nov 15, 2009 at 3:36 PM
    nedhead
    nedhead Member
    Rocky Mountains, CO
    Thanks for the information. I'll try my dealership and see if they will do this. here's the link to the VSC Calibration thread.
  19. Nov 15, 2009 at 7:18 PM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    Great info I will look into this as well. The thread just seams to die. I checked the sensors and gave the wiring a little slack. I did not unplug them because I was a little afraid of breaking them. I also noticed something that could be a problem in the picture below. I don't know how to explain it, but hopefully the picture will speak for itself.
  20. Nov 21, 2009 at 8:31 PM
    BlissTaco
    James
    San Diego
    22 TRD Offroad 4x4
    I was finally able to get the tech at the stealership to do this for me. Why does everything have to be a pain in the a$$ with them? I will let you all know if this did the trick as the probelm was happening everyday for me.
