ProComp coil with 5100?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CorrosiveTendency, Feb 14, 2013.
  1. Feb 14, 2013 at 3:31 PM
    CorrosiveTendency
    CorrosiveTendency [OP] When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I know it's done with the OME and Eibach coils and have the shocks set at '0'. The Procomp coils I have give me 3" of lift, slightly less since the are broken in and settled. Am I right thinking it will work fine, set on '0'?
  2. Feb 14, 2013 at 3:49 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Someone has to know. My pointer is on the buy button.
    Alexely999 likes this.
  3. Feb 14, 2013 at 3:51 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  4. Feb 14, 2013 at 4:01 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I concur, the ride sucks schweddy balls! I bought the truck with the lift on it, It is Procomp struts and rear shocks. Just looking for a slightly better ride. Besides, the rear shocks are stiffer than a prom night dick when it's cold out and the bushing are gone. Fuck it. Bought.
  5. Feb 15, 2013 at 6:41 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
  6. Feb 15, 2013 at 6:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If they're the Pro Comp 700# coils, I wouldn't put them on 5100's. That's a pretty damn stiff coil and I don't think the 5100's will dampen them properly. Most people won't even run the OME 886 coils on 5100's and they're only 650# coils. For reference, Eibachs are around 620#, OME 883, 884 and 885 are 580# and stock is around 540#/in.
  7. Feb 15, 2013 at 7:09 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    #700 is kind of a scary number... Especially if you don't plan on attaching the great wall of china attached to the front of your vehicle
  8. Feb 15, 2013 at 2:03 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    If it is a 700 lb spring, you would think I would have more than 3" of lift....Right? Or I guess it would all depend on the ratio of spring rate to length.
  9. Feb 15, 2013 at 2:09 PM
    Pugga
    Massachusetts
    Spring rate and lift aren't directly related. If you had a 700# spring and a 600# spring, both the same length, then the 700# spring would make the vehicle sit higher because they wouldn't sag as much under the vehicle's weight. I'm not sure how long the Pro Comp coils are relative to the different OME or Eibach coils.
  10. Feb 15, 2013 at 2:14 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    That I understand. So if I were to install the Procomp coil on the 5100's, I wouldn't expect catastrophic failure of the strut would I? (In the TW opinion) It would just ride stiff as usual, and honestly, I don't think it would ride harder if it was lifted with 4x4 wooden blocks the way it sits now.
  11. Feb 15, 2013 at 2:19 PM
    Pugga
    Massachusetts
    If the coil is too strong for the shock to dampen, first you could wear the shock out very quickly, it could ride like crap because the shock is essentially just bouncing along for the ride and isn't properly setup to dampen the coil and the last issue is a constant hard top out which could damage the shock. I know even with the OME 886 coils it's recommended to go with OME shocks and not the 5100's so I can't see pairing an even stronger coil with the 5100's being a good idea. You're right though, I would doubt the ride would improve at all since it's the coil causing the problem, not the shock. If you get 5100's, you could just go back to stock coils and kick the 5100's up to 2.5.
    On another note, you might want to wait and let someone chime in to make sure that the Pro Comp coils are even compatible with the 5100's. They should be but you never know, they might not set into the coil seat correctly.
  12. Feb 15, 2013 at 2:28 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I am very much NOT opposed to getting rid of the Procomp coil. I just need to stay within the budget. Might just bite the bullet and order a set of 885's.
  13. Feb 15, 2013 at 2:42 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Wonder if this would work Subd
  14. Feb 15, 2013 at 2:48 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Well stick around, I am going to give it a shot. I will post back once I have it set up. What is done, can always be undone. At least until I get a better set of coils.
  15. Feb 15, 2013 at 2:58 PM
    BAMFTACO
    Juan
    Kings bruh
    In theory this should work
  16. Feb 15, 2013 at 3:14 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    It will work, but like Pugga has said, it may very well wear out the strut prematurely. I am going to give it a shot, and if it is as bad as the ride I have now, I will just swap in OME coils.
  17. Feb 21, 2013 at 5:25 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Just put the rears on. Wow what a difference. I didn't realize just how bad the rear shocks were. Hoping to get the front struts on this weekend.
  18. Feb 21, 2013 at 5:32 PM
    BAMFTACO
    Juan
    Kings bruh
    Yeah I had the procomp shocks in the rear when I put my Billy's on it was he'll of a difference.
  19. Apr 8, 2017 at 6:46 AM
    Jakecullowhee
    Jakecullowhee Member
    That's what I run and does great for me 5100 and pro comp springs
  20. Apr 8, 2017 at 6:49 AM
    Jakecullowhee
    Don't listen to these people the ride is firm but not bad I have no weight on my front end either ...I love this combo
