Pros and Cons of Sway bar removal on 2nd gen
Discussion in 'Suspension' started by BulletToothTony, Jul 14, 2011.
Should i remove my swaybar?
Poll closed Oct 22, 2011.
  1. Hell yes take it off!
    70 vote(s)
    53.4%
  2. You wont really see a difference.
    10 vote(s)
    7.6%
  3. I wouldnt do it.
    41 vote(s)
    31.3%
  4. Whatever you do dont take it off!
    10 vote(s)
    7.6%
  1. Jul 14, 2011 at 7:28 PM
    BulletToothTony
    BulletToothTony [OP] You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    So i did some searching and couldnt find what i was looking for. So my question is just as the title says, what are the pros and cons of removing the swaybar? I know you get more flex offroad but are there any more benefits? Also whats the negative side of the arguement, any "holy sh!t" moments when having a swaybar would have been beneficial?
    Thanks for the help guys. Also adding a pole to make it easier.
  2. Jul 14, 2011 at 7:36 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I voted pull it off, but i'm a Xrunner haha
    bsp_taco likes this.
  3. Jul 14, 2011 at 7:37 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    people talk about it like you're gonna roll the fuck over and die. i've had it off for what seems like forever now and drive 2hrs everyday. haven't had one "oh shit" moment. the ride feels better too. granted it's a bit weird at first, but you get used to it very quickly.
    it's not like you can't ever put it back on..it takes 10min. take it off, drive it around, if it's too much, put it back on
    digitaLbraVo likes this.
  4. Jul 14, 2011 at 7:41 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Taken out of context, but, That's what she said!!!
  5. Jul 14, 2011 at 7:41 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  6. Jul 14, 2011 at 7:47 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Read as voice of Apu from the Simpson's:
    "Such a thing has never been done"
    tpotnoc likes this.
  7. Jul 14, 2011 at 7:52 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    try it out. While not near other cars, do some abrupt lane change maneuvers. Report back on whether or not your vehicle stability control freaks out and thinks you're about to roll over.
  8. Jul 14, 2011 at 8:07 PM
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
    i dnt have one i took it off when i had my 6" lift and 35s put on i get alot my flex and i dnt tell to much of a diff with out it on road iv taken turns at 30 to 35 and sharp not once did i feel like id flip or loose control
  9. Jul 14, 2011 at 8:10 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    you will have more sway and no bar.
  10. Jul 14, 2011 at 8:12 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah. The concern isn't when you gradually work your way into a high speed ramp turn that generates a lot of Gs pushing you against the side of the truck.
    The concern is when you make a sudden directional change maneuver going from zero to say .7 G, more or less instantly forcing a quick and sudden "sway" into the body which has to follow the wheels and chassis that just changed directions under it
    So if you do *that* and you're happy with the result - I say more power to you. Mine stays on. The philosophy on my rig is "daily driver sometimes driven on pretty tough trails." Removing the sway bar seems to me to be crossing the line over to "my hardcore trail rig that I still drive on the street."
    Silvertaco 603 and gmanrider9 like this.
  11. Jul 14, 2011 at 8:14 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i took mine off but i did it to install my lift and high clearance skid from all poo. when it was in stock trim and i removed i did not like how much body roll was introduced into normal driving. since the lift was installed though it handles like it was when it was stock i was not sure what to expect but, the stiffer coil over set up of the lift kit mitigated alot of the body roll despite it having a higher center of gravity.
    like moose said try it out it only takes a couple of minutes to either remove or install it just do it where you have some room if some thing does happen to go awry. btw mine never set off the traction control at all and i tugged pretty hard on the wheel a few times.
  12. Jul 14, 2011 at 8:17 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, but you're still running those 700 lb ProComp springs on your regular cab, right?
  13. Jul 14, 2011 at 8:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Depends, couple ways to look at it, if you just offroad a little or once in a awhile & are on stock susp. I'd say leave it on.. If you've done a susp. lift & offroad then absolutely take it off so you can benefit from all the extra travel..
    I've had mine off for over a year or so & it'll never go back on...;)
  14. Jul 14, 2011 at 8:18 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Que?
  15. Jul 14, 2011 at 8:18 PM
    DAN_FPC
    DAN_FPC Well-Known Member
    Dan
    Calgary
    09 Dbl Cab TRD
    i just removed my sway bar when i put my lift on, and it seems a little softer on the corners and when i go back and forth. But i also added bigger tires so im sure that doesn't help. I feel tottaly safe and dont think i will put it back on.
  16. Jul 14, 2011 at 8:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    A suspension lift raises the truck's roll center. That combined with the (usually) stiffer springs means you won't notice much increased roll if you take the swaybar off under normal conditions. From what I can tell, though, transient response is worse. The truck may roll over in the moose test (swerving one way, then quickly swerving back) if the swaybar is off.
    Hilux failing moose test (note the driver cutting the wheel left to save it). A stock Taco would never do this even with VSC off.
    http://www.youtube.com/watch?v=aZF8N9NItHI
  17. Jul 14, 2011 at 8:33 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    haha yep :( i need a bumper up front to hang some weight over the front axel then the situation may change but for now its ok.
  18. Jul 14, 2011 at 8:46 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Odd coincidence that that video is called the "Moose Test." :cool:
  19. Jul 15, 2011 at 11:20 AM
    BulletToothTony
    Im gonna to get my coilovers on next week, i think i will leave it off and see how i like it.
  20. Jul 15, 2011 at 11:22 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    There is a noticeable body roll when my wife drives.....lol! She swerves anytime someone touches there brake. You just have to remember its off and the stearing is more sensitive. It makes the truck feel smoother in all other aspects and not so stiff up front! I would only remove it if you offroad. If its a street queen its not worth it.
