Pros/Cons of U-Bolt Flip w/ Minimal Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tencrawler, Feb 1, 2011.
  1. Feb 1, 2011 at 9:17 AM
    tencrawler
    tencrawler [OP] I'm a lover not an expert
    Wes
    Petaluma
    1985 Pickup 4x4 SCLB 22R 5SPD Manual
    Only 55K Original Miles in Spring of 2018
    My truck is not set up (yet) for any "serious" off-roading, but I do cut wood, haul hay, hunt, and drive plenty of pastures. I noticed that I often have debris caught on the rear axle, and was curious if 5100's set at 1.75" w/ Stock TRD Coils and a Fat Bob's Garage 2" AAL would be deemed worthy of a U-Bolt flip kit for the extra clearance. I obviously don't drive a rock crawler, but for functionality and convenience I figured I would just do the flip while I was installing my AAL. Opinions and comments are greatly appreciated.
  2. Feb 1, 2011 at 9:18 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    if your already re-doing your rear suspension might as well for 50 bucks
  3. Feb 1, 2011 at 9:21 AM
    tencrawler
    Wes
    Petaluma
    Thanks. Affirmation is a great confidence booster. I think I will go with the All Pro kit. Any other suggestions on brand or vendor?
  4. Feb 1, 2011 at 9:22 AM
    PLC721
    Patrick
    Chandler, Az
    i have the all-pro one, it is yet to be installed tho but i rrecommend them.
  5. Feb 1, 2011 at 9:23 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
  6. Feb 1, 2011 at 9:25 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    yup do it......
  7. Feb 1, 2011 at 9:31 AM
    tencrawler
    Wes
    Petaluma
    Looks like a no brainer. Going with All-Pro, now I guess I'm on the hunt for shocks. Thanks for all the quick responses.
  8. Feb 1, 2011 at 9:33 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    What are you going to do for bumps?
  9. Feb 1, 2011 at 9:41 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :smack: coke is bad for you dumbazz :smack:
    jwizzmasterwet and Inkedgenius85 like this.
  10. Feb 1, 2011 at 9:42 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    When combined with the appropriate supervision, it can be quite fun.
  11. Feb 1, 2011 at 9:59 AM
    tencrawler
    Wes
    Petaluma
    Do I have to get new bump stops with the u bolt flip? I figured since I was only going with 1.5" of lift I could get away with the stock bumps? Please enlighten me if otherwise. This is my first time doing suspension work on my Tacoma. Very capable shade tree mechanic just not aware of all parts and combinations needed. As of right now, I am putting 5100's up front set to 1.75" (i'm okay w/ a little rake), 5100's in the rear, all-pro 3 leaf progressive AAL, and the all-pro u bolt flip kit. What am I missing?
  12. Feb 1, 2011 at 10:01 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    You will have to adapt your current bumps to fit on the u-bolt flip kit.
  13. Feb 1, 2011 at 10:03 AM
    tencrawler
    Wes
    Petaluma
    ...but it is possible?
  14. Feb 1, 2011 at 10:06 AM
    S.B.
    Sean
    San Diego
    15 Taco
    yes. call them and get the kit that is made to adapt timberins bumps (don't buy the bumps just the plate that is drilled out for them) and drill out 2 hole in your current bumps and screw them in.
  15. Feb 1, 2011 at 10:08 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea I asked because if you don't want to spend money on timbrens you can mod the stock ones to work. Just make sure the plates for the flip kit come with the pre threaded holes for the timbrens. I did a writeup on how to put the stock bumps on it.
  16. Feb 1, 2011 at 10:08 AM
    tencrawler
    Wes
    Petaluma
    Good to know. Thanks for the heads up.
  17. Feb 1, 2011 at 10:11 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
  18. Feb 1, 2011 at 10:18 AM
    S.B.
    Sean
    San Diego
    15 Taco
  19. Feb 1, 2011 at 10:19 AM
    tencrawler
    Wes
    Petaluma
    Bookmarked! I was actively searching and bookmarking all of the how-to's I will be referencing in the next week for my install. Thanks.
    On a side note. I can only do front and rear installs on different days. Which should i do first front or rear? Drive around with my ass in the air for a day, install the front and get it aligned following the install?
  20. Feb 1, 2011 at 10:21 AM
    S.B.
    Sean
    San Diego
    15 Taco
    I'd do front first.
    OG_Tacoma likes this.
