Push Button Locking Rear Diff Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magneticnick, Nov 2, 2009.
  1. Nov 2, 2009 at 10:06 AM
    magneticnick
    magneticnick [OP] Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    Hey guys, I just picked up my 2010 TRD Sport Double Cab...I didn't get the locking rear diff button b/c I struck such a good deal on the particular truck I drove home with....
    So anyways, I want to add that feature to my truck, does anybody know what it will take to do it and how hard it is and what it will cost????
    Thanks!
  2. Nov 2, 2009 at 10:09 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I'm not completely sure, but it's not gona be cheap and easy, it locks the rear diff, so your going to have to get into the diff and do some work, someone will chime in with more info though. do you do a lot of 4x4ing?
  3. Nov 2, 2009 at 10:11 AM
    magneticnick
    Nick
    Orange, CA
    None Yet
    I don't do a whole lot of off roading, but I do go to the snow a couple times per year and I will use it to launch boats a few times per year and I dont want to be roasting my tires on the ramp.
    Plus I thought the locking rear diff would be cool....
    Is it kinda excessive????
  4. Nov 2, 2009 at 10:15 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Your looking at about 1300-1500 dollars for a lightly used rear end to replace your OEM open rear. You cannot swap the internals for the E-Locker third. You will have to replace the entire rear axle assembly. Then you get to deal with the wiring.
  5. Nov 2, 2009 at 10:17 AM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    An ARB setup would probably in the end be just as much but..IMO a better setup..
  6. Nov 2, 2009 at 10:19 AM
    SC4333
    Grant
    FL
    I forgot to add, If you want a locking rear, your best bet will be an ARB air locker. You will need an On Board Air setup and the locking carrier. Install for the carrier will be around 350 dollars from a reputable axle shop. Then you will plumb the air hoses that will run from your air tank/pump (under the bed usually) to the rear axle where the locker is housed. Your entire setup will be around 1200-1500 installed and will be much stronger than the factory E-Locker.
  7. Nov 2, 2009 at 10:19 AM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Arb locker is the best option for ya and is about $1300.
  8. Nov 2, 2009 at 10:22 AM
    testedone
    Rick
    U.S.A.
    I know..I know I have said this before but every time I think of ARB..I always remember my custom built Dana 60 (Currie) with an ARB that was on my 99 TJ... I loved that axle.. :)
  9. Nov 2, 2009 at 10:24 AM
    magneticnick
    Nick
    Orange, CA
    None Yet
    Ok, so the moral to the story is if I really wanted it that bad I shoulda just got the damn truck that had it on there.
    Ok, I give up, the locker really didn't mean that much to me. I thought there may be an inexepnsive way to get it done.
    Oh well. So how are they for traction guys????? I've had lots of Fords with limited slip before, do they work better than that? Do you turn off yoru limited slip buttons in the dirt or not???
  10. Nov 2, 2009 at 10:53 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I have found the rear locker to be essential for when I get stuck while in 4LO. That is to say I am in four wheel drive low and I am stuck. That's when I have found it to be invaluable. It has always got me out. Sometimes if there is an extreme rough patch I'll engage the locker to get me through and then I unlock when I am out of the rough spot.
    I use it exactly as the Toyota manual says to use it.
  11. Nov 2, 2009 at 10:57 AM
    Bart
    Bart Well-Known Member
    Franklin,NC
    08 TRD OFFROAD V6 4x4
    metra ipod
    You have a sport which has auto lsd . Unless your going to hard core offroad you should be fine. I have the offroad package and it suck's for me because the open diff spin's all the time you have got to lock it in 4L to get the locker to work now if you had auto lsd and a locker that would be much better. By the way I live in the Mountains. I see gravel and dirt road's all the time! Be happy with auto lsd.
  12. Nov 2, 2009 at 6:06 PM
    jonny
    jonny Betty White Edition Heep ZJ
    you should look into the locker anytime mod then man :thumbsup:
  13. Nov 2, 2009 at 6:14 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Doesn't that throw a check engine light though?
  14. Nov 2, 2009 at 6:16 PM
    Beale
    Beale Member
    NB, Canada
    06 Tacoma 4x4 TRD Offroad
    speaking of that, ive searched that on this forum numerous times but only came across 1st gen....
  15. Nov 2, 2009 at 6:17 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    A locker is not good in the snow. It tends to make the truck fish tail. I think there is an inexpensive but permanent way to do it(not recommended at all for your truck though). Maybe somebody will chime in but I think if you weld the two shafts together you'll have a permanent locker.
    x2 on the locker mod. I use mine quite often in 2 hi and 4 hi.
  16. Nov 2, 2009 at 6:17 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Grey wire mod. Search for that.
  17. Nov 2, 2009 at 6:18 PM
    Jason'sLawnCare
    I thought the gray wire mod was for 1st gens.
    I didn't have a check engine light when I did the locker mod.
  18. Nov 2, 2009 at 6:19 PM
    Jason'sLawnCare
  19. Nov 2, 2009 at 6:22 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It doesn't state if your truck has 4wd or not. If it does you will not have an issue with traction. If it is only 2wd you will still probably be okay with traction control and auto lsd. The only time I have had to disable traction control is when I was stuck and I needed the tires to spin.
  20. Nov 3, 2009 at 6:50 AM
    magneticnick
    Nick
    Orange, CA
    None Yet
    Sorry, it's 2WD. So according to all you guys I should be fine. Only time will tell huh??? I'll report back after trying to pull the boat up a wet launch ramp, and a little off-roading and a little snow. (not all in the same weekend of coarse!)
    Thanks for all the replies guys!
