Putco LED Dome/map Lighting Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wjpjr, Nov 24, 2013.
  1. Nov 24, 2013 at 3:12 AM
    wjpjr
    wjpjr [OP] Well-Known Member
    Bill
    Nashville Tn
    13 4x4 DCLB TRD Sport
  2. Nov 24, 2013 at 7:50 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  3. Nov 24, 2013 at 8:50 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Does replacing the stock bulb with an led bulb negate the theater lighting feature of the interior dome light?
  4. Nov 24, 2013 at 9:03 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    It still does have the dimming feature, but not as smooth. It's like steps. This may depend on the led though. Mine did this when I swapped in a single led bulb to the dome light.
  5. Nov 24, 2013 at 10:11 AM
    wjpjr
    Bill
    Nashville Tn
    Humm, sorry to inform you I did do the research . You offer a 30 day warranty . (Your led looks like the far eastern style that blows out quickly) You put up no spec's ??
    1 Year Warranty Putco offers a 1 year warranty for the Putco LED replacement dome lights.
    Here's the Putco spec sheet
    If you just under advertised that's fine but, some of us inquiring minds want to know ;)
    These premium dome light kits are 18 times brighter than factory halogen lighting. Putco has designed each one specifically for your car, truck, or SUV and ensured that the LED light bulbs will last at least 50,000 hours.
    Stock Code: PUTCO-980751 Part No.: 980751 Wattage: 9 Watt Bulb Type: LED Length: 9 in .Life Hours: 50,000 Made in USA: Yes Case Quantity: 18 Brand: PutcoUPC: 10536241204 Voltage: 12 Color Temperature: 6500 Kelvin Width: 5 in. Lumens (Initial): 800 Warranty: 90 Day
  6. Nov 24, 2013 at 10:17 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Thanks for the info. I've actually been having flickering issues with my jumpers led's. I might have to check those out. They look very directional though.
  7. Nov 24, 2013 at 10:25 AM
    wjpjr
    Bill
    Nashville Tn
    There's a few posts about them here on the forum . I could find no complaints at all on the internet . I also like the duel body ballast/resister the dome is mounted to. They look a lot like the aircraft grade lights I use at work .. I'm a factory repair mechanic for Embraer aircraft . ;)
    Here's one of them
    http://www.tacomaworld.com/forum/sdhq-offroad/301675-putco-interior-leds.html#post7669078
  8. Nov 25, 2013 at 3:46 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Thanks for the info OP. liked how you handled this with out bad-mouthing anyone.
  9. Nov 26, 2013 at 2:03 AM
    wjpjr
    Bill
    Nashville Tn
    I look at it this way . We are all just trying to make are trucks nicer and spend the least amount of money doing it .
    Some are more passionate about it than others . But, We still all have the same goal . Once the information is out there it's up to the reader to decide what they want to do .
  10. Nov 26, 2013 at 2:03 PM
    wjpjr
    Bill
    Nashville Tn
    Only 4 left in stock :eek:
  11. Nov 26, 2013 at 8:31 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    My LEDS from Putco. Put into my 11' DC then swapped into my 13' Access cab.
  12. Nov 26, 2013 at 8:39 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    The LEDs I buy of Vleds and superbright LEDs have done well. Oldest one is in my dad's truck and is still running strong 1.5 years later. I'm sure these are a little better quality but I could never justify spending nearly $40 for LEDS.
  13. Nov 27, 2013 at 1:21 AM
    wjpjr
    Bill
    Nashville Tn
    There's only 1 left
  14. Nov 30, 2013 at 6:51 AM
    USArchangels
    USArchangels Well-Known Member
    Max
    Houston, TX
    '12 TX Pro Baja
    Stock BAJA: bfg ta ko 16's 60mm racing Bilstein & TRD coil springs up front 50mm remote resevior race Bilsteins in back 71/21 mpg MODS: AeroTurbine 2525XL Muffler on all stainless TRD exhaust. Chopped and dumped TRD Tailpipe. Now 90 degrees. Cut just after axle. aFe ProDry S drop-in air filter Secondary (wire mesh) Filter delete Wilson 4ft Flex Silver Load CB antenna Midland 75-822 CB - hardwired Passport Escort 8500x60 & TomTom GPS unit wired to interior fuse panel with add a fuse BAMF antenna mount (front for CB) Relentless Fab antenna mount (tailgate) Fake Bead Lock delete reversed white wall tires All mudflaps delete Predator Tube Step delete TX Baja decal delete debadged Avid bars front and back SnugTop Rebel Rear Diff Breather mod to bed storage compartment STANT locking gas cap with fishing wire. Interior Map lights - Green LED Interior Dome Light - Red LED ConsoleVault
    Has anyone seen any green Putco LED's anywhere? I need Green specifically. If I can't find that, will end up getting white and placing a green lens over. Working on a cockpit mod.
  15. Jan 4, 2014 at 10:10 AM
    tacoIcecream
    tacoIcecream Member
    murry-land
    2014 sr5 v6 4wd access cab
    I bought some off of Amazon. Thanks for the recc. wjpjr !
  16. Dec 14, 2014 at 8:14 PM
    drscott11
    drscott11 Well-Known Member
    The kit includes the map lights and is very easy to install. These Putco LEDs, though somewhat expensive, are much brighter and truer white than than the factory bulbs; but not so bright that they are blinding. A subtle but worthy mod and one that I would recommend.
  17. Dec 14, 2014 at 9:20 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
  18. Dec 14, 2014 at 9:40 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    What a ripoff, I paid 8 bucks for my 36 led panel. Your money to spend op.
  19. Dec 14, 2014 at 11:18 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Agreed... eBay 36 LED panels plus adapter for $5 shipped.
    Get 4 of them for $12. Who needs a warranty fit that price? The one in my Taco is very bright, does the gradualast dim, and has worked flawlessly since June...
