Question about fog-lights & high-beams
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StarGazer, Aug 26, 2010.
  1. Aug 26, 2010 at 7:21 PM
    StarGazer
    StarGazer [OP] Well-Known Member
    MegaMan!
    Wherever, Tx.
    2007.5 Dodge Ram 2500 Mega Cab 4x4
    I've done so many mods to this truck it turned out to be a Dodge Ram 2500! WOW was that expensive!!
    I thought I saw somewhere about a mod on that will let you keep your fog-lights on while your high-beams are on. Please point me in the right direction.
  2. Aug 26, 2010 at 7:31 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
  3. Aug 27, 2010 at 6:46 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Yep, I did it last weekend. Took about 5 minutes. Fogs now come on with park lamps and stay on with High Beams. And, you can still turn them off with the switch.
  4. Aug 27, 2010 at 7:37 AM
    StarGazer
    MegaMan!
    Wherever, Tx.
    Thanks, I'll try it out this weekend.
  5. Aug 27, 2010 at 8:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I don't know what your state laws are regarding this type of thing....
    You should check into the 'legalities' of it. Especially if you get inspections.
    I have aftermarket fog lights that I can put on anytime. Here in PA - its illegal to have fogs on with high beams. Each year during inspection, I have to disconnect the power to my fog lights so I'll pass inspection.
  6. Aug 27, 2010 at 8:10 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    FLM FTW!!!
  7. Aug 27, 2010 at 11:37 AM
    spyshot
    spyshot Well-Known Member
    Dayton Ohio
    09 TDR OFFRoad
    dumb question, but will the fog lights go out when the primary headlight switch is turned off?
  8. Aug 27, 2010 at 11:55 AM
    The_Hodge
    SC
    no. they are still controlled by the switch. they will still turn off when the truck is turned off though
  9. Aug 27, 2010 at 12:19 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    In most cases in thick fog or really heavy snow when you would be using Fogs You sure wouldn't want your Brights On!!
