Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Dec 22, 2017 at 6:53 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    You can also use 2014 4Runner brakes (14wa) if you run 17” rims it’s bigger thang the gx470 upgrade
    Red Baron and nastyneight like this.
  2. Dec 22, 2017 at 6:58 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    From what I have found this is what I was talking about. It is going based on the older stuff and probably cheaper than the 2014 T4R brakes. So is the T4R rotors and calipers larger than these? I haven't seen or heard of that upgrade. I know I would like to convert the rear to discs at some point as well.
    https://www.tacomaworld.com/threads...t-oem-parts-part-s-provided-installed.443656/
  3. Dec 22, 2017 at 7:06 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    The gx ones(13wh) can be used with 16” rims iirc there slightly larger and thicker, but the (14wh) is even bigger aka need minimum 17” rims.
    https://www.tacomaworld.com/threads...unner-bbk-upgrade-for-2nd-gen-tacomas.504234/
    I want to do the 14wa and have seen then at part stores for ~$85 a caliper + core
  4. Dec 22, 2017 at 7:16 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Per the thread I posted the wh may have to use 17in wheels as well since the T4Rs and the GX were running 17s. But he doesn't know if some 16in and other 17s will fit. I am running 17in methods so I should be good. I am going to look into the one you suggested.
    The one thing I don't want to do is end up with to much caliper piston and have to upgrade the master. I know when I switch to discs in the rear the proportioning valve will have to be changed. I have done a bunch of brake upgrades in the past on other peoples stuff as well as my own and it can be a slippery slope once you upgrade one thing you don't get full potential or any benefit because other parts of the system aren't sized appropriately.
  5. Dec 22, 2017 at 7:28 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    It looks like the 14wa and the 13wh both use the same diameter rotors at 338mm but the 14wa runs a little thicker @ 31.8mm vs. 28mm and the calipers have 2mm over sized pistons. That makes me think the pads friction surface is slightly larger. It would be nice to know the pad size though as compared to the 13wh's though.
    It seems the 14wa is slightly a better upgrade without going over bored for the stock master cylinder. I wonder if the 5th gen T4R master has a larger bore and would bolt up??? It is really nice to do upgrades with factory components compared to aftermarket so much easier to get parts when they fail.
    Thanks for the link!
  6. Dec 22, 2017 at 8:14 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Too many words
    nastyneight likes this.
  7. Dec 22, 2017 at 8:18 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Did that go over your head? :rofl::rofl::rofl:
  8. Dec 23, 2017 at 2:03 AM
    YamaDirtrider
    Josh
    Elizabeth CO
    https://www.tacomaworld.com/threads/doublld-master-cylinder-upgrade-feeler.471751/
    I can see what ya mean by slippery slope, I started looking at al this when I realized that I’ve got a wrapped rotor :frusty:
    I’ve combated it for now with friends take off parts but considering my trucks an 06 it’s proably due for a good refresh anyway.
    Red Baron likes this.
  9. Dec 23, 2017 at 2:08 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Makes my peanut brain hurts.
    Sandman614[OP] likes this.
  10. Dec 23, 2017 at 3:42 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    The tundras and sequoias have a factory brake upgrade that goes to a larger diameter and thicker rotor to combat warping issues. I want to say it was the 1st gen tundras and up to maybe an 06 sequoia IIRC.
    I messaged him about being the guinea pig and lets just say it isn't how the automotive world works for being a test bed. I wonder if there is a factory master cyl. that has a larger bore/piston and will bolt right up, again ease of getting repair parts.
  11. Dec 23, 2017 at 4:45 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Agreed. Need to limit people to 50 words or less, ha.
  12. Dec 23, 2017 at 9:53 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    YamaDirtrider[QUOTED] likes this.
  13. Dec 23, 2017 at 5:00 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Got some cheap rock lights on Cyber Monday decided to get them installed today since it was so nice. Started documenting the install on my build thread but here's a money shot ;)
    T4RH33L and Red Baron like this.
  14. Dec 23, 2017 at 5:35 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Smiley52, nastyneight and Blkvoodoo like this.
  15. Dec 23, 2017 at 7:30 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    I was feeling neglected
  16. Dec 24, 2017 at 8:40 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Merry Christmas Eve, gents!
  17. Dec 24, 2017 at 9:24 AM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    Que lo Pase Bien
  18. Dec 24, 2017 at 9:56 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Tu Tambien, Brotato Chip.
    voz[QUOTED] likes this.
  19. Dec 24, 2017 at 10:21 AM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    счастливого Рождества
  20. Dec 24, 2017 at 11:16 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Aloha Snackbar?
    Brent2014 and Smiley52 like this.
