Raz4back's 2012 MGM Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Raz4back, Jul 8, 2012.
  1. Jun 9, 2013 at 2:14 PM
    #61
    Raz4back
    Raz4back [OP] Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    Thanks! Once I removed the small front flaps I haven't had any issues. I did trim a very small amount on the back of the front flares (maybe 1/4 inch) Even before I trimmed it very rarely rubbed.
  2. Jun 9, 2013 at 2:22 PM
    #62
    Raz4back
    Brett
    Benton, Arkansas
    Thanks man! Your truck looks great, who did your lift?
    Are you talking about the tabs on the alignment rings? If so, I had to use a rotary tool and grind a little off of all three tabs. Don't seal your lights back up until you have your cut off lines where you want them and your projectors tightened good. You will have a little play in the rotation of your projectors after you grind the tabs and if your projectors aren't good and tight it's a pain to tighten them without throwing your cut off out of whack once they are sealed.
  3. Jun 10, 2013 at 7:16 AM
    #63
    GATACOMA
    GATACOMA Active Member
    Does it Matter
    4x4
    Where did you get the factory style switch that's below you AC controls that hooks up to your Hellas?
  4. Jun 10, 2013 at 7:39 AM
    #64
    Raz4back
    Brett
    Benton, Arkansas
  5. Jun 10, 2013 at 11:44 AM
    #65
    gholcomb
    gholcomb Member
    George
    Bryant, Arkansas
    TRD-Sport 4x4
    6" ProComp, Magnaflow Exhaust, H1 Retrofit, Everything Murdered Out
  6. Jun 11, 2013 at 8:00 PM
    #66
    Raz4back
    Brett
    Benton, Arkansas
  7. Jun 25, 2013 at 4:38 PM
    #67
    stanford2011
    stanford2011 Member
    Kenny
    Sac, CA
    07 Tacoma 4x4
    Just got my Tacoma. I have wanted a tacoma ever since i was little and finally got one the other day. currently it is stock 2007 4x4 TRD Sport. Extended Cab. 4.0L V6 Future Mods: -Flowmaster Original 40 muffler -Flat black Exhaust tip -Bilenstein 5100's all the way around -Eibach Coils -1.5" Rear AAL -New stereo (Pioneer 3500 BHS Deck) -Light Bar (Crossfab most likely) -HELLA black magic 500's x3 -Scanner+CB -Firestik 4' Whip -Black headlight mod and tail lights -black emblems -Maybe new grille insert -OEM Factory Fog light switch to run auxiliary lights independently
    Where did you order your hella black magics? Was it a kit? Did it come with three or just a pair? I have a light bar with 3 tabs like you but trying to figure out best way to buy the black magics and how to set 3 up
    Thanks
  8. Jun 25, 2013 at 6:39 PM
    #68
    Raz4back
    Brett
    Benton, Arkansas
    They come as pairs. I bought a kit from Pep Boys. For my third light I lucked out and found a single light with the relay and harness on the Internet. If I hadn't found the single I was going to buy a second kit and save the other light as a spare.
    Just search for single Hella Black Magic on EBAY, Google, etc. and maybe you'll find a single.
    As far as wiring, I wired the pair on one relay and the single on another. Both relays are wired to the same switch.
  9. Jun 25, 2013 at 9:51 PM
    #69
    stanford2011
    stanford2011 Member
    Kenny
    Sac, CA
    07 Tacoma 4x4
    Thanks for the reply! I just ordered the pair kit and now gotta find a single one. I haven't had much luck yet but ill keep an eye out. If you come across one lemme know I would really appreciate it! Was setting up an independent switch for the lights difficult?
  10. Jun 26, 2013 at 5:03 AM
    #70
    Raz4back
    Brett
    Benton, Arkansas
    No, it isn't difficult at all. You need a wire that powers with the ignition, a wire to the two relays, and a ground (if you want the switch to light up when it's on) there is a boot on the drivers side firewall that the main harness runs through that you can use to get the wiring into the cab.
  11. Jul 2, 2013 at 1:58 PM
    #71
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Dunlap,TN
    13 MGM Sport 6sp AC
    Nice truck man! Ive got a 13 access cab MGM on its way here. I may copy your headlights theyre so sexy! :spy:
  12. Jul 2, 2013 at 8:18 PM
    #72
    Raz4back
    Brett
    Benton, Arkansas
    Thanks! Go for it with the headlights, aside from the looks, the light output is a big improvement over stock.
  13. Sep 22, 2013 at 2:22 PM
    #73
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    nice truck. when you painted the wheels what did you use? and how did it hold up?
  14. Sep 23, 2013 at 6:38 AM
    #74
    Raz4back
    Brett
    Benton, Arkansas
    Thanks!
    I painted my wheels with duplicolor wheel paint. Graphite is the color. They held up really well. I didn't have any issues at all with flaking or chipping.
  15. Nov 17, 2013 at 5:14 PM
    #75
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    Nice truck !
    Question on your tire size, did you ever have mudflaps?
    Id like to run the same size and have 5100 at 1.75 but I want to keep the flaps.
  16. Nov 18, 2013 at 1:20 PM
    #76
    Raz4back
    Brett
    Benton, Arkansas
    I had already removed my mud flaps. You may be able to get away with leaving them on if you are running your stock wheels.
  17. Jan 11, 2014 at 1:02 PM
    #77
    jaymay82
    jaymay82 Well-Known Member
    '13 MGM TRD Sport PRO DCSB
    Solid looking truck man. How hard was it to do the retrofit? Does it include instructions? Thanks.
  18. Jan 11, 2014 at 1:29 PM
    #78
    Raz4back
    Brett
    Benton, Arkansas
  19. May 10, 2014 at 11:56 AM
    #79
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    looks good
  20. May 11, 2014 at 6:45 AM
    #80
    Raz4back
    Brett
    Benton, Arkansas
    Thanks man
