rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Oct 18, 2024 at 2:56 PM
    #3401
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Read the first post.
    "OldManTan" and rcbs204[OP] like this.
  2. Nov 23, 2024 at 5:35 PM
    #3402
    DJ IslandBoy
    DJ IslandBoy Well-Known Member
    Dave
    North Central WA
    2008 4x4 Tacoma Access cab
    After 8 months sitting in my to-do bin, I finally got around to attempting to put this in. Well past my warranty period.
    Putting the board in was pretty easy, where the wires in instructions are soldered, there was a plastic twist-in plug. Since I don’t have solder equip nor very proficient at it I was going to do the other option. So I wanted to keep that little plug to protect the wires from getting chaffed on the metal edges, so I drilled a hole through the middle and have my wires through the plug and the switch parts all back together.
    I was a little lost on the instructions after that. It looks like the pins on the attached wires plug straight into the wire plug that goes to the switch. After that, it’s hazy. How then if the wires are into the plug are we connecting to the A/C system for power? Without reading and reviewing 171 pages, Is there another write-up or video that anyone has done to explain that part?
    I’m newb to anything electrical, so any help would be appreciated.
  3. Jul 19, 2025 at 9:23 PM
    #3403
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    So this wont work on a 2013?
    ACEkraut likes this.
  4. Jul 21, 2025 at 12:27 AM
    #3404
    EL DUDE
    EL DUDE Well-Known Member
    any left?
  5. Jul 21, 2025 at 1:41 AM
    #3405
    AllTacosFloat
    Boston ish
    Nope, I tried to give mine to a friend with a 13’ and it’s not compatible.
    If anyone is in need I have one I cannot use.
    AR15xAR10[QUOTED] likes this.
  6. Jul 21, 2025 at 6:04 AM
    #3406
    AR15xAR10
    Bummer, thank you for the clarification!
  7. Jul 21, 2025 at 7:41 AM
    #3407
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    As mentioned, no, this will not work on a 2013. The switch on the 12-15 did not allow light to go through so no illumination. But there are other options out there for the 2012-2015. There is a thread that is on TW. I will see if I can locate it.
  8. Jul 21, 2025 at 7:59 AM
    #3408
    AR15xAR10
    I appreciate that. Not a priority. I just saw someone else selling an illumination kit they never installed and i’m glad i did my diligence to check before hand.
    however, my next question is, if its just the switch not allowing the light to come through, what if i swap the 4x4 switch from my 2008 into the 2013?
  9. Jul 21, 2025 at 9:22 AM
    #3409
    ACEkraut
    Aaron
    Durham, Maine
    The short answer is that they are not compatible. The work around is to buy a switch from a Forerunner or HiLux and then you have to buy a wire with a pin on it and insert that wire in the correct spot on your existing connector and then connect the other end to a source under the dash for lighting. One 4 X 4 switch fits and the other requires a small metal sleeve as the switch is slightly smaller than the opening. A TW member sells the metal ring. So everything is "available", but it will require a little bit of installation.
    Here are the threads:
    https://www.tacomaworld.com/threads/diy-gen-2-illuminated-4wd-switch.3681/
    https://www.tacomaworld.com/threads/machined-ring-for-hilux-lighted-4x4-switch.451738/
  10. Jul 21, 2025 at 9:27 AM
    #3410
    AR15xAR10
