rear diff oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by Max-4_Yota, Dec 25, 2009.
  1. Dec 25, 2009 at 9:38 PM
    Max-4_Yota
    Max-4_Yota [OP] The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    i know its already been menitoned but here it goes, my truck has 104K on it and ive been thinkin bout changin the rear diff fluid. what all will i need, i know i need a 24mm socket. Mobil1 oil but what weight and what about the lsd stuff. what is that?
  2. Dec 25, 2009 at 9:42 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    LSD is for the 2nd gen guys (limited slip differential)
  3. Dec 25, 2009 at 9:44 PM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
    subscribed.
  4. Dec 25, 2009 at 9:51 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Hello Max-4_Yota!
    Here is a good link that explains the "How To" part of changing it out, It's a oil change for a 2nd Gen but it is pretty much the same process.
    http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
    I would suggest going with Mobil 1 synthetic 75W-90, I also don't think the 1st gen's come with LSD's but I could be wrong. Check the diff cover and see if it has a sticker with LSD printed on it. If it doesn't, than you should be fine and not worry about it.
    If it does than you should use Dino oil (none synthetic oil) and the same stuff they used on that link I put up.
    I hope that helps, and welcome to TW
  5. Dec 25, 2009 at 10:01 PM
    BG04
    BG04 Well-Known Member
    04 2.7 SR5 4X4
    There is a limited slip additive for the gear oil but I put Royal Purple in mine 75 90 and it already has it in there. Shops who change my diff oil offered LSA separately although my differential is not LS.
  6. Dec 25, 2009 at 10:07 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
  7. Dec 25, 2009 at 10:35 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    I could be wrong but if you've never changed it before, I'm not sure you should use synthetic now with so many miles. Anyone know otherwise? Where's chris4x4 he's the officiato on this sort of thing.
  8. Dec 25, 2009 at 10:41 PM
    BG04
    04 2.7 SR5 4X4
    I heard it was a rumor it made a difference and it didn't matter if you switched to synthetic.
  9. Dec 25, 2009 at 10:44 PM
    Yoytoda
    Roland
    completely stock
    that is another common synthetic myth. synthetic just lubricates better and is still the same weight (75w-90 is same weight whether synthetic or not)
    The original myth is that synthetic is rougher on old seals, but its a myth none the less...
    My pops has a 89 suburban back in ny that was switched over to synthetic at 150k and currently has 400k+ on stock drivetrain. Synthetics are awesome
  10. Dec 25, 2009 at 10:48 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    ^^^^^^^ This is correct. It makes no difference at what mileage you switch over to synthetic, and will not cause oil leaks any more than conventional oil would when comparing like for like oil weights.
  11. Dec 25, 2009 at 10:57 PM
    Yoytoda
    Roland
    completely stock
    Synthetics are probably the best investments you can do to protect a vehicles longevity. my sister had an old pos dodge shadow and after i convinced her to go synthetic it ran for 175k which is amazing for that little shit box. It finally died when but not the engine, it had a electrical issue not worth fixing
  12. Dec 26, 2009 at 4:38 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    IMHO, the real advantage to synthetic gear lubes is the longer change interval. If you still need to change them frequently because of contamination (such as submerged axles) then stick with the dino juice and change it.
    In my wife's daily driver, though, the extended change intervals are nice!
  13. Dec 26, 2009 at 9:08 AM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
