Rear differential lock...
Discussion in '1st Gen. Tacomas (1995-2004)' started by sull625, Jun 4, 2013.
  1. Jun 4, 2013 at 8:43 PM
    sull625
    sull625 [OP] Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    I have an 04 Tacoma and when I try to lock the rear differential and the light just blinks. I'm not sure if its locking but I can hit the button and it will blink and hit it again and the light will go off. Is this a major issue? Any insight into this is greatly appreciated
  2. Jun 4, 2013 at 8:46 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Probably just needs to be taken off and cleaned, when I lock mine you can here the gear engage and of course feel it when you turn on the road. Have you tried driving in an S pattern to engage it ?
  3. Jun 4, 2013 at 8:50 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Dear god don't drive in a s pattern.
    If the light is blinking it means it is not engaged.
    First of all, you are in 4low right?
    Second, if it won't engage try turning the steering wheel to the left and right while not moving. You can also try driving forward and reverse in a straight line. Sometimes it needs a little help aligning
  4. Jun 4, 2013 at 9:01 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    This. The e-locker won't engage unless you're in 4-low or have done the gray wire mod.
    If you aren't in 4-low or haven't done the gray wire mod, the light on the dash will blink at you like an angry Hulk.
    As mentioned, if you are in 4-lo or have the gray wire mod, drive forward or backward in a straight line for 20-30 feet and see if it engages. If it doesn't something deeper is going wrong.
  5. Jun 4, 2013 at 9:40 PM
    sull625
    Dave
    Montana
    Wow so I feel like an idiot but putting it into 4lo and engaging diff lock worked just fine. Thanks for all the help fellas. I'm pretty happy that there are resources out there to help with this kind of thing. ( I almost had a melt down thinking something was wrong) once again thank you!
  6. Jun 4, 2013 at 9:45 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    that is completely retarded! how is turning the steering wheel to the left and right while NOT moving going to get it to lock? Are you afraid that turning to the left or right with it locked for a short time is going to explode it? Guess what, it isnt.
    glad to hear it works fine! If it is having problems disengaging i found the best way was to disengage it was to be stopped, hit the button, turn the wheel sharply and reverse with a little tap on the pedal until you hear it click or the light turn off.
    you can also complete the grey wire mod so you can turn it on and off whenever, not needing it to be in 4lo. this making it a true select-able locker
  7. Jun 4, 2013 at 10:28 PM
    sull625
    Dave
    Montana
    I would like to do the gray wire mod. Do you have the info on doing this?
  8. Jun 4, 2013 at 10:29 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  9. Jun 4, 2013 at 11:51 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  10. Jun 5, 2013 at 9:12 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You are a fool. Driving in an s pattern in 4lo with the diff locked, especially on hard terrain, is asking for damage. Go ahead and try it. In fact make a video and report back here.
    As far as turning the wheels without moving, it shimmy the rear end and twists it just enough to engage the locker. Once again go try it.
  11. Jun 5, 2013 at 9:17 AM
    BigOly
    BigOly Well-Known Member
    Bay Area, NorCal
    14 MGM DCSB TRD/OR 4x4
    I agree, but to an extent. I doubt it would hurt anything if you're just wiggling your steering wheel just a little while moving to get it to engage. It doesn't make sense that you can lock when you are not moving. I think what the guy was trying to state is you should not drive in S patterns ...you will most likely damage your diff in the long run.
    OP: As you use the locker more often, you may notice that the system will engage quicker. That's been my experience. Reiterating what IDtruck has already stated, It helps to do the gray wire mod so you don't have to go to 4low in order to lock the rear diff, I highly recommend this mod as it still retains the safety of not allowing the locking at high speeds.
    Overall, in regards to our 1st gen factory lockers, the rule everyone should follow is "use it or lose it". ;)
  12. Jun 5, 2013 at 9:20 AM
    BigOly
    Bay Area, NorCal
    Actually you can hit the button and nothing will happen, the safety feature is still there, that's one of the beauties of the mod, it's idiot proof.
  13. Jun 5, 2013 at 9:24 AM
    BigOly
    Bay Area, NorCal
    Wow, calm down folks... lol, I believe you are both correct...I just think there was just a little bit of misunderstanding between the both of you.
  14. Jun 5, 2013 at 10:24 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    LOL! If the front tires turn while standing still it will shimmy the rear enough to some how engage and disengage? Still a stupid idea. I will say it again, you have to be moving for it to disengage and engage. Simple as that. If you have not done the grey wire mod and you have to be in 4lo to do this you are probably right, driving in tight s turns is going to bind like a bitch. Hence why the grey wire mod is a good idea.
    true. like i said earlier, best way to get to lock or unlock is to turn the wheels sharply, while stopped hit the button, and give it a quick little step on the gas. click.
    oh haha, my bad. mine is on a standalone circuit, so no ecu for me. If i hit that button the bitch locks. I have to make sure to tell anyone who drives my truck not to touch that button ever, but then they will want to, so i seriously consider pulling the power to the switch to keep idiots from hitting it, never know.
  15. Jun 5, 2013 at 10:34 AM
    bellassaiw10
    Currituck NC
    I can lock mine in in 4H so sorry about the S turn comment haha
  16. Jun 5, 2013 at 10:40 AM
    scocar
    scocar hypotenoper
    Sheesh. Dudes need to chill. If it won't engage and you are in 4 low, it means the pin isn't lined up with the diff, and the rear wheels need to move at very slightly different rates to get it to line up and lock in. This is normal. And by S turns, no one is suggesting huge sweeping S turns. Just a tiny bit of steering wheel input at a crawl is enough to move the diff so that the locker can engage. This is normal.
    This is not like have 4WD on and turning that binds up the front diff on pavement.
    OP, just go find a flat dirt patch or parking lot and do it several times to get the feel of it. You'll feel/hear the clunk.
    You also need to use it or lose it with these things. They are sort of notorious for corroding or seizing if not operated.
  17. Jun 5, 2013 at 10:52 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    All you have to do is try it friend, I just did it at lunch and it worked perfectly, once again
  18. Jun 5, 2013 at 10:58 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    Yup. Mine was a bitch when i brought the truck last year. Few trips to BLM and Hollister Hills and it works great now.
  19. Jun 5, 2013 at 11:19 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    The grey wire mod is one of the greatest things I've done to my truck and it makes it even better that it doesn't cost anything.
    I always lock and sometimes unlock my by driving in an s pattern. It won't hurt anything. Hell I drive on the highway with mine locked sometimes just because I was using it and forgot to turn it off. Of course, I turn it off as soon as I come to a stop just because it will make the rear tires wear more. I know countless people who either run spool lockers or welded diffs on their daily and never have a problem. They just don't act stupid, like mashing the gas while turning.
  20. Jun 5, 2013 at 11:56 AM
    ToyTacosRule
    ToyTacosRule Well-Known Member
    Dane
    Texas
    4x4
    What is the max speed that can be hit before it cannot be engaged? also does the truck have to be stopped to engage it with this mod? I have rear dif lock on my truck but I have never had to use it in the sands at the beach nor any mud holes I have hit and never really bothered with it since it was a hassal to mess with 4 lo haha.
