Rear, Front and Transfer case oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfmco7, Dec 16, 2010.
  1. Dec 16, 2010 at 5:32 PM
    Bfmco7
    Bfmco7 [OP] Well-Known Member
    I have 65,000 miles on my truck. I have never changed the oil in any of these. Would you Change it at this point? I have already purchased the oil. Ig you say yes, do I need any special tools? A pump to get the oil back in? Any help would be appreciated!!
  2. Dec 16, 2010 at 9:21 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    owners manual states 15000 for the front and rear diffs
  3. Dec 16, 2010 at 9:46 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    in the '11 maintenance schedule:
    the regular intervals, excluding special conditions towing schedule, do not state intervals for changing the diff or transfer case oils. they merely state to check them.
    within the regular intervals, the rear diff oil should be changed every 30k IF you have a mechanical LSD. but otherwise they do not specify any intervals whatsoever.
    http://www.toyota.com/t3Portal/document/omms/T-MMS-11Tacoma/pdf/2011_Tacoma_WMG_lr.pdf
  4. Dec 16, 2010 at 10:04 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    I had all mine changed out at 15,000 miles. I figured if there was any metal shavings from being new it would be good to get them out (plus I wanted the dealership to break free the drain/fill plugs .) I plan to change them every 25,000.
  5. Dec 16, 2010 at 10:06 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I would change them if I were you, but honestly I wouldn't fret about being overdue on the service schedule. I've seen plenty of vehicles that have been used into the high 100,000s and never had anything but engine oil changed.
    You will definitely want a pump to get oil back in the transfer case, and it would probably be helpful for the differentials also.
  6. Dec 16, 2010 at 10:22 PM
    OffroadToy
  7. Dec 16, 2010 at 11:27 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    i did mine at 67k bought it used and didn't know if it had been done yet, it's not that hard, just get a good pump and if you have a LSD (sport) make sure you DONT use synthetic oil, just use regular oil with a 4oz tube of friction modifier, i ended up doing this and then going with mobile 1 full synthetic in the front diff/transfer case
  8. Dec 17, 2010 at 7:23 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    My 2 cents after changing all diffs/transfer twice at around 25K each time... (guessing at least 1000mi of 4Hi per winter and on 7th winter), 15K is overkill. For most 30K is fine.
  9. Dec 17, 2010 at 7:27 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I did all three not too long ago. The rear had 10k on the oil and it was filthy, the t-case had 30k and was clean and the front diff had 30k and was filthy. So I would recommend changing them at the least 30k miles. Yes you need a pump for the front diff and t-case but not necessary for the rear diff if you have the quart size bottles.
  10. Dec 17, 2010 at 7:28 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    buy the oil in the gallon container, and buy the cheapo hand pump that fits everyone of those bottles.
    it isnt the easiest,way, because you are under the car all cramped pumping away feverishly like some pervert at an (fill in funny blank as you please)..
    the job is cake.
    Zwilly likes this.
  11. Dec 17, 2010 at 7:35 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    the job is cake that is correct.....fill till full bam done
  12. Dec 18, 2010 at 7:22 PM
    Bfmco7
    what weight oil is used? also.. is the drain and fill plug on the front digg an alan head? I think I see it.. any help would be appreciated!
  13. Dec 18, 2010 at 7:32 PM
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    is synthetic required?
  14. Dec 18, 2010 at 7:37 PM
    Jason'sLawnCare
  15. Dec 18, 2010 at 7:37 PM
    Jason'sLawnCare
    no
  16. Dec 19, 2010 at 12:21 AM
    Cummins
    Cummins Well-Known Member
    Robert
    Winchester, Ky
    05 Tacoma SR5 TRD
    I have roughly the same question but I have a bit more miles. I have not done the front, rear, or trans case since i have owned the truck and it has 177,000 on it now. Should I do them or just leave alone what is not broken.?.?.?
    Thanks,
    Robert:)
  17. Dec 19, 2010 at 4:52 AM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    Ok, may be a dumb question but where is the transfercase on my 09 off road dbl cab. I see the write ups on the diffs but just want to make sure in the trasnsfer case.
    thanks
  18. Dec 19, 2010 at 6:32 AM
    Jason'sLawnCare
    I would. I would probably take it to the dealer and let then crack open that front diff because you may strip the drain plug. I almost did.
    Right behind the transmission. For a visual
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/122749-transfer-case-oil-change.html#post2371846
  19. Dec 19, 2010 at 6:54 AM
    boxxed
    Denver, CO
    09 Off Road
  20. Dec 19, 2010 at 6:59 AM
    Jason'sLawnCare
    If you run it without oil then the dealer probably wouldn't cover it unless you got creative and put some in before you went there but I don't suggest that. It really is simple. Open the fill plug first then place pan under drain plug. Open the drain plug and let it drain a couple minutes and close it back up and fill it till it starts coming out of the fill hole and put the fill plug back in. My point is, it's really easy and not much to mess up. If you feel that you are stripping a plug bring it to the dealer to do that one particular part if you're not comfortable. It's just like changing the motor oil. If you aren't comfortable that's fine just bring it in.
