Rear Shock relocation thread
Discussion in 'Suspension' started by Box Rocket, Feb 5, 2013.
  1. Jun 20, 2013 at 11:32 AM
    #101
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    I'm going to weld my rear cross member this weekend and I'm trying to determine how far back I want it to go while trying to maximize full useage of the shock, up and down travel. In order to maximize full useage of the shock I was planning on having an angle like this / instead of a more vertical angle like this l.
    What are the disadvantages to having a shock lean further back than almost vertical?
  2. Jun 20, 2013 at 12:31 PM
    #102
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    decreased dampning the further away from vertical you get.
  3. Jun 21, 2013 at 1:39 PM
    #103
    Johnnie
    I.E. SoCal
    Feds
    I'm planning on mounting them rearward between 35°-40° from the axle. Do you think might cause any issues?
  4. Jun 21, 2013 at 1:56 PM
    #104
    Box Rocket
    Adam
    Syracuse, Utah
    Shouldn't as long is they don't limit travel or bottom out.
  5. Jun 21, 2013 at 2:15 PM
    #105
    Johnnie
    I.E. SoCal
    Feds
    They're are 10" shocks & my leafs give me 11.5" of travel. If I put them at 40 degrees rearward I can get the full 11.5" of travel with the shocks.
  6. Nov 28, 2013 at 2:28 PM
    #106
    01tacorunner
    01tacorunner Active Member
    can you post pictures of this build? i want to do the EXACT same thing and need a little guidance
  7. Dec 26, 2013 at 8:21 PM
    #107
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    I was researching the pelfreybilt relocation kit. Anyone have any comments on these?
    I am looking to run the All Pro Expos, XJ shackles (flipped) and a 12" or 14" shock.
    (I currently have a 6" prochump lift w/ blocks I am looking to get rid of)
    I also would like to know if it is and why it would be necessary to relocate the stock mounts on the axle. The pelfreybilt kit doesn't seem to include these.
    Thanks.
  8. Dec 26, 2013 at 8:45 PM
    #108
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    The pelfrey kit includes all you need including the axle tabs. it's great imo! but if you flip ur shackles you will need to have it fabbed to work with the flipped kit since it will need to be bumped differently. I like mine just fine without a shackle flip and the expo pack. Just make sure you fab and measure when installing to get it right.
  9. Dec 26, 2013 at 9:00 PM
    #109
    ImplicitlyAlberta
    David
    edmonton
    In order to gain the extra height ill have to do a shackle flip with an extended shackle.
    The kit does have axle relocate tabs. Good to hear.
    What size bumpstop can you use with the kit. I was looking at the Radflo hydros and the have a 2.0 and a 2.5 there is quite a price difference as well.
    Thanks.
  10. Dec 26, 2013 at 9:03 PM
    #110
    SconnieHailer
    Marc
    the kit is a 2.0 bump size. but you can shape it to fit a 2.5 if you want i spose.
  11. Dec 26, 2013 at 9:10 PM
    #111
    ImplicitlyAlberta
    David
    edmonton
    For an extra $110 and added effort to make it fit, maybe ill stick with the 2.0. Lol
    How long have you had you kit for? Any notables during install and application I should know about?
  12. Dec 26, 2013 at 9:14 PM
    #112
    SconnieHailer
    Marc
    Yea 2.0 has been plenty of bump for me. I carry lots of weight so having a shock valved for the weight was the biggest change and then the bump to help the bottoming was awesome. You get used to the clicking of the bumps. Just make sure you get a forklift to cycle it before you burn it in permanently. Getting the bump position right is a big deal so you don't neg arch your leafs too much. Other than that positioning the hoop on the plate might be interesting with your amount of lift to run a 12" and use all of it right. Just call Tyler to hash out the details, he's very helpfull.
    Kit has been on my truck for probably 3 months
  13. Dec 26, 2013 at 9:31 PM
    #113
    ImplicitlyAlberta
    David
    edmonton
    Excellent info. Thanks a ton.
    Is Tyler with Pelfreybilt?
  14. Dec 26, 2013 at 9:32 PM
    #114
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Tyler is Pelfreybilt :cool:
  15. Dec 26, 2013 at 9:37 PM
    #115
    ImplicitlyAlberta
    David
    edmonton
    Very good. Does he have a hook here?
  16. Dec 26, 2013 at 9:39 PM
    #116
    PLC721
    Patrick
    Chandler, Az
  17. Dec 26, 2013 at 9:49 PM
    #117
    SconnieHailer
    Marc
    Thanks Patty! :wave:
  18. Dec 26, 2013 at 9:56 PM
    #118
    PLC721
    Patrick
    Chandler, Az
    I got you! :wave:
  19. Dec 26, 2013 at 9:59 PM
    #119
    SconnieHailer
    Marc
    huuuuuurd that!
    BTW salt in WI sucks! its eating away at all my shit I didn't paint good enought. Can't wait to get back to WY just sand and no plowing.
  20. Dec 26, 2013 at 10:09 PM
    #120
    ImplicitlyAlberta
    David
    edmonton
    Alright!
    Thanks again guys.
