Rear Spring & Tailgate TSB Quick Reference
Discussion in 'New Members' started by tcBob, Mar 25, 2008.
  1. Mar 25, 2008 at 10:32 AM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    -This is a quick reference for new Tacoma owners on two oft-discussed TSBs they should be aware of
    -A more comprehensive list of TSBs (thanks to Angus_NB)
    A TSB is a Technical Service Bulletin. The two most talked about TSBs regarding 2nd gen Tacomas are the rear spring TSB and the tailgate TSB.
    Rear Spring TSB
    If you are still under warranty (36k/36mo) and have a 2005-2010 Tacoma 4x4 or PreRunner (including TRDs), you are eligible for the rear spring TSB, which replaces your shocks with the Bilstein shocks normally given on the TRD package and replaces your 3-leaf springs in the rear with 4-leaf springs. This is to help with bottoming out and sagging that's experienced when a heavy load is placed in the bed. The TSB is specified for the 2005-2010 models.
    If you approach your service dept about getting this TSB done, it's good to have the TSB printed out in-hand when you show up.
    Get the TSB to print out here.
    See this post & discussion for tips on getting it approved without too much hassle.
    Bent Tail Gate TSB
    On 2005-2008 models, there is a TSB to strengthen the tailgate which can be bent under certain conditions. Note this has been fixed in 2008s made after a certain date (details in the pdf below).
    Here is the PDF for the tail gate TSB: BO018-07.pdf
    (thanks to Flycatcher for assisting with this)
  2. Mar 25, 2008 at 11:12 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Thanks, do I have to bend the tailgate to get it fixed? I'm already trying to get my springs updated from the weak ones.
  3. Mar 26, 2008 at 10:31 AM
    Flycatcher
    Flycatcher Master of the Universe
    Minnesota
    2009 Acadia (regretfully sold the Taco)
    That is a good possibility. Every dealer is different. You might try calling Toyota first at 800.331.4331 and see what they say. If they give you a case# you can take that and the PDF to a dealer and give it a try. It seems absurd to wait for the tailgate to bend, replace it and then strengthen the new one, but that is what some places require.
    I replaced my bent one before I knew about the TSB. I called Toyota, they gave me a case# and a Fax number. I faxed in my receipts form 6 months ago and they are reimbursing me. I may try to get the TSB work done as well.
  4. Mar 27, 2008 at 11:00 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I've heard that the gate has to be bent for them to replace it.
  5. Apr 17, 2008 at 11:19 AM
    hymus
    hymus Member
    Chandler, Arizona
    06 Tacoma SR5 4x4 4 Dr LB
    I took my truck in to the dealer for service and when the service manager noticed that I actually use my truck bed he prompted me with questions on if I had noticed it bottoming out or having poor handling with a load in it. Once I figured out that he was trying to get a yes out of me, he informed me of the TRD suspension available for my 06' 4x4 via the TSB!! I was excited until he called me back later that day and said my claim was denied since my truck didn't actually exhibit a malfunction. Basically what he told me is I have to wait until a shock fails to get the TSB suspension upgrade. Has anyone else run in to this and been able to work around it?
    Thanks!
  6. Apr 18, 2008 at 7:47 PM
    slackdaddy2001
    slackdaddy2001 Active Member
    07 Tacoma DoubleCab, SR5 Offroad Pkg.
    Hymus, I think it failed the suspension inspection by the Toyota dealer because they have must looked at your bump stops & saw there was no evidence of the bed bottoming out. If your bed bottoms out it leaves marks on the bump stops. Load your truck with about 700 lbs (truck is rated at 1350 lbs) & take it for a ride to feel it bottom out. Then your bump stops will have evidence with the bump stop marks. The only other reason it could have failed is if you have 4 lugs on your tires.
  7. Apr 18, 2008 at 8:08 PM
    rick
    rick `
    depends on the dealer i guess. i took my truck in and mentioned the tsb. the service manager ordered the parts then and there, no exclamation or inspection needed
  8. Apr 18, 2008 at 8:11 PM
    rick
    rick `
    do you have more than 36,000 miles on your truck?
  9. Apr 19, 2008 at 5:55 AM
    hymus
    hymus Member
    Chandler, Arizona
    Thanks for the tip Slackdaddy. The service manager at the dealer I go to actually thought it would be a "no brainer" just call it in like he had done for other owners, Toyota approves and the parts are ordered. I think what is happening is Toyota is cracking down on all the people asking for the upgrade and they have made it more fact based - i.e. actual evidience of the problem. I called the Toyota care line directly after reading another thread and after going through a couple service agents, I finally got one to issue a service request to my dealer (playing dumb and being nice can pay off sometimes!). The dealer called me last night and i need to follow up this a.m. with them but from his message said, t sounds like he has a few questions and then he can order parts...
    I am going to definatey check the bumpers since I know i have had it loaded up to 700 lbs in the last few months. Worse case, i might squirt some oil on a shock and see if that will qualify as a "failed" part!
  10. May 25, 2008 at 10:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I probably wont be able to get this done since I did AAL already. Or would I?
  11. Jun 5, 2008 at 3:01 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I can't wait until they add the 2008's to the suspension TSB. :pout:
  12. Jun 5, 2008 at 3:02 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    It doesn't apply to diesel Tacomas anyway.
  13. Jun 5, 2008 at 3:03 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Damn - I guess I will have to put the gas engine back in...
    ...oh, wait, that was only in my dreams.
    DOHT! :frusty:
  14. Sep 12, 2008 at 6:20 PM
    Janks
    Janks Active Member
    London, Ontario
    05, TRD sport. Speedway Blue
    3"Trail Master lift, 31x11.5x17 MT Bias Belted...
    I bought my 05 with 51k (KM) a few months ago. I bought the full out warrenty with it. It states that front and rear suspension is covered. When I took the truck into the dealer with the TSB # he punched it in and it said "no coverage"
    Is this when I should be calling that 1-800 number? Any one else have this problem? Remember that I'm in Canada...
    Thanks for any info..
    Janks
  15. Sep 12, 2008 at 6:42 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I bent my tailgate and Toyota replaced it, my old tailgate is sitting in my garage right now.
  16. Nov 28, 2008 at 7:32 AM
    PaulVthe3
    PaulVthe3 Well-Known Member
    Does the rear spring TSB apply to the 09's as well?
  17. Nov 28, 2008 at 7:42 AM
    tcBob
    Bob
    check out the 2009 tsb thread here.
  18. Dec 2, 2008 at 12:24 PM
    br217398
    br217398 Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    Hey yall!!!! just want to give a huge thank you to everybody that has helped with these TSB's. Toyota said there was no TSB untill i faxed this copy to them:boink:.... the dealer told me there werent any other problems so i printed both out and handed it to them in person, then while i loaded my bike in the back of the truck I bent the tailgate, so I brought that to them as well!!!!! I'll see what happens, but atleast ive got all of your help!!!:D:D
    THANK YOU:wave::wave::bananadance::thumbsup::rasta:
    GaryLaurenLogan likes this.
  19. Dec 10, 2008 at 5:38 PM
    ddfda
    ddfda Active Member
    Tallahassee FL
    2020 Tacoma XSP
    Towing package, locking tailgate, tonneau cover
    VERY useful info! Just what I was looking for, thanks!
  20. Jan 3, 2009 at 9:40 AM
    jonl9
    jonl9 Jonl9
    Eastern North Carolina
    06 Prerunner, Xtra cab, towing package
    Another new member here who is grateful for the information in these forums. I printed out the suspension TSB and brought it to my dealer. I explained I haul a 4,000 camper, and...the parts are on order!
    Thank you!
