Releasing clutch makes subtle ping noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Vehement, Dec 27, 2018.
  1. Dec 27, 2018 at 2:22 PM
    Vehement
    Vehement [OP] Active Member
    Colorado
    Yeah. It almost sounds like a drumstick would on a bare bike cog. Lower pitch but similar. Pretty quiet. I can only hear it when parked next to a large curb or wall.
    Reverse is starting to get a little harder to get into. Only sometimes.
    Apologies if there's an existing thread for this. Didn't quite find the symptom match.
  2. Dec 27, 2018 at 3:27 PM
    MitochondriaMan
    MitochondriaMan Well-Known Member
    MitoMan
    Florida, USA
    04 3.4 TRD 4WD
    Tundra hyper-silver double 5-spokes with 265-70-17 BFG All-Terrains. Compact Cobra CB in the ashtray slot. Cut a small hole in the plastic and mounted the antenna to the drivers side windshield wiper mount using an old Harley Davidson blinker bracket. 1 1/4" drywall screw is holding door handle together nicely.
    Sounds like it's outside of the cab then right? Check your gear oil/ clutch fluid levels?
    If you're lucky you just have low fluid or it might be your master cylinder. Slave cylinder is deeper. Fix it... you'll feel new
  3. Jan 17, 2020 at 12:27 PM
    Vehement
    Colorado
    UPDATE
    This seemed to go away, but now it's back better than ever. All fluids have been flushed, the driveshaft doesn't have any slop (out of rotation axis). It happens as change of direction occurs or transitioning from engine braking to forward/backward engine power.
    I've included a link for a youtube vid of this sound.
    https://youtu.be/7NCm3Dk09nA
    GQ7227 likes this.
  4. Jan 17, 2020 at 12:32 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Have you ever greased the slip joint in the drive shaft?
    GQ7227 and jammer like this.
  5. Jan 17, 2020 at 12:37 PM
    Vehement
    Colorado
    Nope. I suppose I should probably do that anyway.
    jammer likes this.
  6. Jan 18, 2020 at 7:45 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    It’s probably the slop in the driveline ringing through the driveshaft as you change directions and take the slip out. No big deal
    Vehement[OP] and Black DOG Lila like this.
  7. Jan 18, 2020 at 9:06 AM
    Glamisman
    Glamisman Well-Known Member
    a guy a few weeks ago discovered that the splines on a splined flange were worn... I forget if this was on a 4X4 or a RWD.
  8. Jan 22, 2020 at 12:25 PM
    Vehement
    Colorado
    Whole Driveshaft greased, no change in the sound.
    I'm starting to think this is what's happening. When you slap the driveshaft section after the Tcase, it makes the exact same pitch/sound.
  9. Jan 22, 2020 at 12:40 PM
    Wulf
    rock raisin
    Did you separate the shaft at the splined portion and grease it by hand? @eon_blue just went through this
    Does your carrier bearing have a lot of play in it?
    eon_blue and GQ7227 like this.
  10. Jan 22, 2020 at 4:05 PM
    eon_blue
    Azusa, CA
