Replacing front brakes??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2010Tacoma4x4, Sep 16, 2014.
  1. Sep 16, 2014 at 1:59 PM
    2010Tacoma4x4
    2010Tacoma4x4 [OP] "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Dealer said I'm down to 3mm on my front pads and they want $190 to replace :eek:
    I'm thinking about ordering this upgrade and was wondering if anyone has installed the power stop kit K137-36 and if so how do you like it??
    Also appreciate input or advice on any other kits available with pads and rotors.
    TIA
    Here is a link to the kit I'm considering...
    http://www.summitracing.com/parts/p...NphttoMqszu6uajy5xQK_WefTUV_eM4WlTBoCoBbw_wcB
  2. Sep 16, 2014 at 2:15 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ebc stage 5 work great
  3. Sep 16, 2014 at 2:21 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  4. Sep 16, 2014 at 2:30 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Looks like a very nice set up....a little out of my price range tho. Thanks!
  5. Sep 16, 2014 at 2:33 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
  6. Sep 16, 2014 at 2:34 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I don't think you'll be disappointed with them
  7. Sep 16, 2014 at 2:43 PM
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    I'm cheap so I'll change my own brakes and save a few bucks.
  8. Sep 16, 2014 at 2:48 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Mini H1 Retrofit 5K, 1st Gen TRD CAI, JBA Catback, Radflo 2.5 extended coilovers w/ resis, Radflo 2.5 rear shocks with resis, toytec superflex rear springs, DSM Uniball UCA's, intake manifold spacer
    bought these a few months ago. damn what a difference! my wheels actually lock up when i slam on the brakes now haha. make sure you heat cycle them to break them in properly.
  9. Sep 16, 2014 at 2:55 PM
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
    Sub'ed
  10. Sep 16, 2014 at 3:16 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  11. Sep 16, 2014 at 3:19 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Rock Auto has the Wagner Severe Duty front brake pads for about $45, and once you pull the front wheels, 20 minutes to install. No need to pull calipers, just pull the pins, wiggle the old pads to retract pistons and reassemble.
    Howard
  12. Sep 16, 2014 at 3:25 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Wagners are decent & last a while, good OE level pad. The EBC or Hawk pads have a noticeably shorter stopping distance and bite level.
    For rotors - EBC, DBA, Powerslot / Stoptech are all nice high end replacements. If you have ever developed "warped" rotors which shake the steering wheel when you brake from towing or offroading or whatever reason, slotted rotors will really help prevent that.
  13. Sep 16, 2014 at 3:30 PM
    hetkind
    Howard
    Johnson City
    I beg to differ on the Severe Duty...these are far superior to OE level pads...I have used EBC pads extensively on motorcycles with good success, I like Raybestos or Wagner on four wheeled equipment.
    I don't think there is any need to by boutique pads for a pickup.
    Howard
  14. Sep 16, 2014 at 5:04 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Seattle
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I run Akebono pads on everything I own. Best street pads I've ever run.
  15. Sep 17, 2014 at 9:17 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall Modified bed extender
  16. Sep 17, 2014 at 9:23 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    subbed. stock brakes dont work to well for my set up :rofl: glad i came across this
  17. Sep 17, 2014 at 9:24 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    u need air brakes since ur pretty much airborne all the time
  18. Sep 17, 2014 at 9:25 AM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    yeah. maybe ill look into wings and a tail as well :p
  19. Sep 17, 2014 at 9:26 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    :cheers:
  20. Sep 17, 2014 at 5:48 PM
    KnoxTac0713
    KnoxTac0713 Well-Known Member
    Justin
    Knoxville, TN
    13 DCSB SR5 4x4 Barcelona Red
    Bilstein 6112, rear 2.0 Icon VS shocks, TRD Black SEMA wheels, 255/80/17 Cooper ST Maxx, SOS Rear bumper, SOS bolt on sliders,TRD skid plate, derped badges, 15% tint, color matched oem grille, lamin-x amber fog covers, TRD cat-back exhaust, Tacoma bed mat, Tonno-pro trifold, Depo black tail lights, front tow hook w/ D shackle, Wheeler's Superbumps rear, Wheeler's 1 inch block rear, Custom Car Grills mesh grill insert, light bar in lower valence
