Replacing the fuel filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by doc1911, Sep 1, 2012.
  1. Sep 1, 2012 at 6:31 PM
    doc1911
    doc1911 [OP] Well-Known Member
    NC
    2018 Pro
    2004 with 135k and I'm looking to replace the fuel filter. Should I go with OEM or does anyone have a rec on an aftermarket?
    Thanks
  2. Sep 1, 2012 at 6:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I have used the luber finer ones from autozone without any problems. One work of advice......spray fitting with some pb blaster and use line wrenches. Regular wrenches have a tendency to strip the nuts.
  3. Sep 1, 2012 at 8:38 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    You don't mention whether you've got a 4- or 6-cyl engine which, IIRC, does vary the parts required and specifics of the job. There's info on several options here. (I went with a WIX 33319 for my V6.)
    This is is good advice! The filters need to be pretty tight to prevent leaks, so it might take some "elbow grease" to remove the old one and be very careful not to cross-thread the fittings when installing the new one.
  4. Sep 2, 2012 at 11:55 AM
    doc1911
    NC
    2018 Pro
    Thanks for the help.
    It is a V6 double cab
    Tacomaman06-- can you explain further what pb blaster is?
  5. Sep 2, 2012 at 1:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Pb blaster is basically a better form of wd40..........a good lubricant. Helps break rusted parts free easier.
  6. Sep 2, 2012 at 1:40 PM
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    Pb blaster is a penetrating spray solution. It has many uses, one being to help loosen the nuts holding the filter to the lines. A high quality penetrating solution is a must when working on good ol' 1st Gens.
  7. Sep 2, 2012 at 2:06 PM
    doc1911
    NC
    2018 Pro
    Muchos gracias
  8. Sep 2, 2012 at 2:14 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    hi will long time you good?
  9. Sep 2, 2012 at 2:24 PM
    Norton
  10. Sep 2, 2012 at 6:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Yeah man......been busy as hell though.
  11. Sep 3, 2012 at 12:02 AM
    WiscTaco
    Wisconsin
    Sr5 Trd 23.42 mpg
    Has anyone put any type of sealant on the threads in the line? My knowledge is somewhat limited in regards of fuel line/type of compound in seal not meshing.
    Like I would assume the typical Teflon-plumbers tape would not work, but is there a similar product for fuel lines?
  12. Nov 12, 2014 at 8:09 AM
    jensenjoe
    jensenjoe Active Member
    Joe
    Bay Area
    2000 XtraCab 4x4 SR5, red
    42" LED lightbar, CB, PA system, sirens, SKL Motorworks KL-PRO1 performance chip, Viper alarm w/keyless entry, Rancho Quicklift Loaded struts, 2.5" Hell Bent Steel front spacers, RuggedLift 2" rear block spacers, Revtek 1" Diff-drop, 4' Firestik w/custom fabbed bed mount, round LED flood/fog lights, Apex 8000k Xenon HID's
    This is the fuel that came out of my fuel filter that to my knowledge had never been replaced by previous owner. You can literally see SAND AND DIRT sloshing around in it. BAD. My mpg has increased slightly since replacing and same with the engine's idling.
  13. Nov 12, 2014 at 8:17 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    no! never put anything on fuel line connections, they are designed to seal as a dry fit only and if you put something on it it could cause it to leak as strange as that sounds.
    I use the wix filters from autozone and they look identical to OEM and work great, I think it was around $16 with new washer seals but I have the 4 cylinder so the filters are different numbers because the fuel lines are a little bigger on the v6
  14. Nov 12, 2014 at 11:29 AM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    EDIT: GEEZE-us. I just saw the date on that PB blaster post. Sheesh. Nevermind. Nothing to see here. Gotta love the bumps!
  15. Nov 12, 2014 at 2:36 PM
    keakar
    karl
    louisiana
    lol me too, I see a post any just reply if I can help without ever checking the date :p
  16. Nov 12, 2014 at 8:28 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Thats probably how mine looks. Possibly worse. Was it a difficult job?
  17. Nov 12, 2014 at 9:17 PM
    keakar
    karl
    louisiana
    on the v6 its super easy, its right under the drivers seat bolted to the frame rail
  18. Nov 13, 2014 at 7:17 AM
    copacetic1
    copacetic1 Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    I did this recently on my V6. PB blaster is your friend. Wix filter, took about 45 mins, there's a good "how to" in the sticky list of DIYs. Line wrench helps but not necessary. I had a small leak after test driving but just loosened the fittings and re-tightened and it was fine.
  19. Nov 13, 2014 at 8:34 AM
    97TacoNM
    Jim
    NM
    Werd. "Hey, I can help on that one!" goes through the mind, without seeing that the post was from 2009 or something :facepalm:
