(Request) Electronics for Dummies
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dinorawr, Jul 15, 2021.
  1. Jul 15, 2021 at 12:02 PM
    Dinorawr
    Dinorawr [OP] Member
    Hey all!
    I'm assuming this is common knowledge for you mod masters....but I have no clue...
    At what point do you upgrade your fusebox/ anything else to support electronic mods?
    Specifically things that I'd like to hardwire are:
    • A dashcam (currently always on when the car is on through cigarette lighter, thinking of hardwiring it)
    • I also want to hardwire some LED lights/ add a push switch
    • Have BestBuy add a Compustar/Drone Mobile soon.
    It's greek to me and I don't want to fry anything. Thanks in advance!
  2. Jul 15, 2021 at 12:15 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    74 pages of fuse panels can be found over here. Also, you can ask Ken over here. :thumbsup:
  3. Jul 15, 2021 at 12:24 PM
    Dinorawr
    Thank you, I appreciate it!
  4. Jul 15, 2021 at 1:00 PM
    RyanDCLB
    4/19 DCLBOR
    There's some posts on the dashcam here including an adapter here.
    What type of LED lights? Inside? Outside? Bed? Checkout here @mattgecko
    For the remote start, I went with the N2Designs as seen here. Remote start can be found here and the TW Mega thread can be found here. Use N2TWFREESHIP for free shipping. @N2DesignsInc
    Also, for basic questions, you'll get a ton of answers if you ask them in the "What have you done" thread over here. GL! :thumbsup:
  5. Jul 15, 2021 at 1:05 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    So far your really only talking about adding 1 circuit directly to the battery.
    1st step for considering an additional fuse box is to get an idea of how big the new box needs to be. Some of these mods get really expensive. You want to get the size right the first time if possible.
  6. Jul 15, 2021 at 1:21 PM
    dagobert
    dagobert Well-Known Member
  7. Jul 15, 2021 at 1:31 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Solid state relays > mechanical
    N2DesignsInc likes this.
  8. Jul 15, 2021 at 1:32 PM
    Dinorawr
    That's good advice, I'll keep that in mind for sure.
    I guess my actual question is "Installing only these 3 things, do I need to upgrade any currently stock electrical to handle it?"
  9. Jul 15, 2021 at 1:36 PM
    PhenixFord
    Randy
    Arkansas
    Simple answer is NO
    1 Set of lights will just be 1 addition to the battery.
    The Dash Cam and Compustar will be integrated into existing circuits.
  10. Jul 15, 2021 at 1:43 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    The components that you plan on installing are relatively low draw so my opinion is that you don’t necessarily “need” to upgrade your electrical system or add a secondary fuse block. I run my dashcam off an add-a-fuse from the main fuse block under the dash and the led lights can be run using a stand alone harness with a relay. That will be the easiest way to install those two things.
    My personal experience with Best Buy installations is that they aren’t going to try and figure out your added wiring and will install things the easiest way they can- usually with included harnesses or tapping into factory wiring.
    That being said, the benefit of upgrading your electrical system with a secondary fuse block could potentially benefit you in the long run because it will allow you to easily add more components later if you choose and you’ll avoid the bird’s nest of wiring associated with clumsy installs piled on top of each other.
    If you have questions let me know. IIRC, you’re relatively close by so I can even help with the install if you need it.
    Dinorawr[QUOTED][OP] likes this.
  11. Jul 15, 2021 at 1:48 PM
    PhenixFord
    Randy
    Arkansas
    I wouldn't touch it. Something isn't quite right about that thing. They advertise (5 - 30A circuits and 5 - 15 amp circuits). But looks like there main power wire is only a #10. ?????
  12. Jul 15, 2021 at 2:06 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Careful with the drone mobile. It draws power constantly. Not a lot but enough that it can kill your battery
  13. Jul 15, 2021 at 2:11 PM
    PhenixFord
    Randy
    Arkansas
    I would guess that the all do. I've been interested in the Drone Mobile also. I just like the look of their APP.
  14. Jul 15, 2021 at 2:11 PM
    dagobert
    5 - 30 amp switched(with fuse)
    5 - 30 amp max fused only
    Power running into the Bussman is your choice - everything inside the Bussman runs off a buss bar - both + and -
    10' leads coming out of the Bussman for your circuits and switches.
    Been running one for near 7 years with zero issues.
  15. Jul 15, 2021 at 2:15 PM
    dagobert
    I've had The Drone in my FJ since '13. The FJ used to sit for 3 weeks while I travelled and the battery never ran dry. You can also set alert for low battery as well. IMO with all the features available through the app it is very well thought out.
  16. Jul 15, 2021 at 2:16 PM
    ascendr
    ascendr Active Member
    If you have a local mobile audio/security shop, I would go that route over BestBuy. Also it's convenient to add the Dashcam hardwire, install a switch, relay and fused hardwire to the battery for LED lights when the installer is installing the remote start.
  17. Jul 15, 2021 at 2:17 PM
    PhenixFord
    Randy
    Arkansas
    That makes a little more sense.
    I was looking at the pic that showed a #10 GROUND and assumed that it was part of the FEEDER. Guess I assumed wrong.
  18. Jul 15, 2021 at 2:20 PM
    dagobert
    The bracket they offer also has a mounting location for a circuit breaker. Neat and tidy.
  19. Jul 15, 2021 at 2:23 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    It can also be fun and educational to build your own
  20. Jul 15, 2021 at 2:37 PM
    ascendr
    For the LED lights, I would run a fused wire straight to the battery, piggy-backing on existing fuses in the panel could melt panel wires if the load is too much. A dashcam is fine for a piggy-back, so is the trigger for a relay, but I wouldn't source a lightbar/aux lights from it.
