reset warning light
Discussion in 'Technical Chat' started by fullback, Feb 25, 2011.
  1. Feb 25, 2011 at 9:53 PM
    fullback
    fullback [OP] Well-Known Member
    NJ
    Double Cab TRD short bed
    how does one Reset the oil replacement reminder (“MAINT REQD”) light in my 2009 Taco??
  2. Feb 25, 2011 at 9:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2... There's a reason they put it in the glove box. There's a series you need to do with the key and the trip odo reset button. I don't remember what it is but it's in the owner's manual.
  3. Feb 25, 2011 at 10:10 PM
    fullback
    NJ
    Thanx Guys , I have tried it and it didnt work for me Thats why i asked
  4. Feb 25, 2011 at 10:14 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Latest Generation Tacoma's. Reset Of "Maint Reqd" light
    Just some fyi in case you don't know how to reset it. TcBob could we make this a sticky?
    This is directly from the owners manual Section 1-6 "Operation of the Instruments and Controls" under "Service reminder indicators and warning buzzers" Subsection G "Engine Oil Replacement Reminder Light" page 150
    Clearing the "Maint Reqd" light on 2005 and up Tacoma's
    This light acts as a reminder to replace the engine oil.
    This light will come on when the ignition key is turned to "ON" and will go off after about a few seconds.
    When you drive for about 7200 km (4500 miles) after the engine oil replacement this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key turned to the "ON" position. If you continue driving without replacing the engine oil, and if the distance driven exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to the "ON" position. The light will remain on thereafter.
    If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. IF the light comes on, replace it as soon as possible.
    The system must be reset after the engine oil replacement. Reset the system by the following procedure:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown (For details, see "Odometer and two trip meters" on page 143 in this Section.)
    2. Turn the ignition key to the "ON" position while holding down the trip meter knob.
    Hold the knob for at least 5 seconds. The odometer indicates "000000" and the light goes off.
    If the system fails to reset, the light will continue flashing
    Got it from this: http://www.tacomaworld.com/forum/2n...eneration-tacomas-reset-maint-reqd-light.html, which is located under the Mods an Tutorial sections of the forum.
  5. Feb 26, 2011 at 2:24 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    You tried wrong.
    It works just fine.
    Try again.
  6. Feb 26, 2011 at 2:47 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
  7. Feb 26, 2011 at 1:57 PM
    fullback
    NJ
    Thnax Bud
