retaining stock stereo and adding rca outputs for amp question
Discussion in 'Audio & Video' started by victorramse3, Sep 21, 2013.
  1. Sep 21, 2013 at 10:50 PM
    victorramse3
    victorramse3 [OP] Well-Known Member
    Victor
    Bakersfield, CA
    2013 Dbl cab TRD OR 4x4
    N/A
    I am new to the car audio scene and have been researching how to add an amp or two while retaining the factory headunit. I see that many people on here are using something like this http://www.amazon.com/gp/aw/d/B002T4XR78 to add rca outputs.
    I was speaking with a buddy of mine that did his and he used a couple of these for his setup. http://www.amazon.com/gp/aw/d/B001EAWS3W/ref=mp_s_a_1_4?qid=1379828502&sr=8-4&pi=AC_SX110_SY165
    my question is what is the advantage/difference between these products?
    Would the PAC units be sufficient to get a good amp/speaker combo going?
  2. Sep 21, 2013 at 11:32 PM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    the PAC is sufficient unless you need the additional outputs or want the equalization or optional sub output level control features of the AudioControl units. our stock radios are only lacking in power.
    i would actually recommend the EQL/EQX/EQS over the LC boxes. all take speakers level input and the EQ parts add equalization and crossovers in the higher end units
  3. Sep 22, 2013 at 12:00 AM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    What are the EQL/EQS/EQX and LC boxes? I'm not familiar with the terminology.
    As for the equalization and sub output level, isn't the amp normally able to control those?
  4. Sep 22, 2013 at 6:26 AM
    SlowComa666
    San Antonio TX
  5. Sep 22, 2013 at 1:25 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    Oh ok I understand now. Since all I'm looking for are RCA outputs for an amp the PAC units will suffice. Thanks for your input!!!
  6. Sep 22, 2013 at 10:56 PM
    Highspeed
    Highspeed Well-Known Member
    +42° 52' 21.69", -124° 32' 8.50"
    TRD off road
    A.R.E. cap
    You might also consider using amplifiers with high level inputs. This would eliminate the need for converters. It will limit your choice of amplifiers but there are some good ones out there.
  7. Sep 23, 2013 at 1:20 PM
    spieler
    spieler Well-Known Member
    Jonesborough, TN
    13 white DCSB SR5 4x4
    3" Lift kit/265 Duratracs/SCS Stealth 6 matte black wheels, OEM White grille switcheroo, TRD skid derped white, CSjumper drtl map dome parking lights fog light bulbs, Lifetime LED headlights, **Reverse light mod, Foglight anytime Mod, Trimmed mudflaps, Fully Debadged, 3rd brake light cover by well...me, Liquid Innovations black carbon dipped front emblem, G-Tek Fab diamond plate white door sill protectors, SOS Bolt-on Sliders bedlined, MattGecko rear window security bar, Hardwired Radar Detector w/custom sucker mount, Horse Stall Bed Mat, Audiocontrol LC2i with custom mount ACR-1 remote, Custom sub box behind drivers rear seat, Mag light holder behind seat, Center console organizer , Passenger seatbelt flapper fix, Tailgate anti-theft Mod, Bed storage Locks Mod, hygieneboy ghetto gutter grille guard
  8. Sep 23, 2013 at 4:38 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    That's a pretty nice mod you made there!
    I ended up just going with the PAC RCA output adapter. Down the road if I decided that I want to tweak it a little more I may choose to add some of those Audiocontrol boxes, but being that i'm still learning i'm trying to keep it simple.
  9. Sep 24, 2013 at 4:56 AM
    spieler
    Jonesborough, TN
    Thanks, it was easy, just take your time...cut...fit...cut...cut...fit! Nothing wrong with the PAC at all, they do their job. Only reason I went with the AC unit is my amp didnt have any xovers in it so my sub was playing full range and was horrible.
  10. Sep 25, 2013 at 2:06 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    What are crossovers? Are they like the Hi/Lo audio filters that are used? I just ordered my amp, JL Audio JX 500/1D am I going to need something similar?
  11. Sep 26, 2013 at 5:03 AM
    spieler
    Jonesborough, TN
    yes, exactly. The JL you purchased has the xover built into it for the sub so you're golden.!!
  12. Sep 26, 2013 at 12:06 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    Ah ok!
    Thanks for the info!
  13. Sep 26, 2013 at 12:14 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Yep one or the other of the ones you listed would work.
    High level (speakers) to low level (subs) or a straight through line converter. Speaker to rca. If the amp is of pretty much any quality these days it'll pick up the frequency band you need for either a subwoofer amp or speaker amp.
    If you are keeping the stock speakers, you can just lift the rear plastic piece long the door sill and it should expose enough of the speaker wire to splice onto. As well for your switch wire or remote wire, you can just attach that to a speaker wire as well. I had a set up like this for about a year.
  14. Sep 26, 2013 at 12:17 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    You can attach the amp remote wire to an existing speaker wire? I was planning on tapping into one of the stereo wires behind the stock head unit.
  15. Sep 26, 2013 at 12:22 PM
    ImplicitlyAlberta
    David
    edmonton
    Really you don't even have to remove the head unit.
    The remote wire just needs a tiny bit of power to ensure the amp stays on.
    As well, depending on the rca adapter this may also need a remote hook up.
  16. Sep 26, 2013 at 5:20 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    Good to know!
  17. Jan 1, 2014 at 9:33 AM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    so how did the PAC end up sounding?
  18. Jan 3, 2014 at 8:39 AM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    The PAC unit sounds great. No complaints here.
    I had some issues initially but it was due to my installation skills (or lack thereof).
    I definitely recommend the unit to anyone who is interested in adding an amp.
