REVIEW 3rd gen suspension on 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFergie, Apr 6, 2018.
  1. Jul 21, 2020 at 2:51 PM
    #301
    Mercedesfan
    Mercedesfan Member
    2011 Toyota Tacoma 4x4 5 speed
    Trd suspension from 2019
    It was pretty easy, no rust. San Diego area. I got this truck from original owner. It never seen off road. undercarriage is clean ( for now )
    BoMartin88 likes this.
  2. Jul 21, 2020 at 3:43 PM
    #302
    BoMartin88
    BoMartin88 Member
    Bo
    Tennessee
    '15 White DCSB XSPX 4x4
    With 500 miles on offroad 2020 suspension do i need all new bolts or anything or can i use the ones that he gave me off his they are in great condition. Have a punch out sockets and wrenches. About to get a 3/8 for sparks and a 1/2 torque wrench. Do i need any other tools or parts
  3. Jul 21, 2020 at 3:46 PM
    #303
    Mercedesfan
    Mercedesfan Member
    I used all old bolts. Set of wrenches , sockets. Punch and a hammer. Zip ties to hold knuckle up.
  4. Jul 21, 2020 at 3:47 PM
    #304
    socal73
    socal73 Well-Known Member
    Westminster CA
    2009 DCSB Sport
    Assuming there's no damage to the hardware given to you with the suspension, using them should be fine.
    BoMartin88[QUOTED] likes this.
  5. Jul 21, 2020 at 3:49 PM
    #305
    Naszero
    Naszero Well-Known Member
    2021 Cement DCSB TRD OR 4x4
    I reused everything from a set that came out of a 3rd gen with 10k miles with no issues. The install was pretty straight forward but I did need an alignment.
  6. Jul 21, 2020 at 5:37 PM
    #306
    Capt’nCrims
    Capt’nCrims Well-Known Member
    Can this be done with a single cab 2012? I imagine it could.
    Just about to hit 100k miles and considering doing this swap with the leafs.
    Also where are you guys picking these up? Some new from the dealer or getting lucky finding them from guys throwing lifts on their trucks discarding these?
    thanks!!
  7. Jul 21, 2020 at 5:48 PM
    #307
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    check out the 3rd gen marketplace here and offerup, Craigslist and Facebook marketplace. No reason to buy from the dealer, that wouldn’t be fiscally feasible or reasonable. Some areas post more 3rd gen suspension take offs like SOCAL, but they’re all over the place because folks go for aftermarket suspensions.
  8. Jul 21, 2020 at 5:55 PM
    #308
    Capt’nCrims
    Right on appreciate it, just found the marketplace here, new to the site. Awesome so far really reminds me of the ranger station forums back in the day. Had a 1998 ranger and spent a ton of time online there.
    I’ll keep an eye out thanks again.
    Micbt25 likes this.
  9. Jul 21, 2020 at 6:08 PM
    #309
    Micbt25
    TM
    My pleasure, good luck in your search.
  10. Jul 22, 2020 at 7:29 AM
    #310
    Tac0Tac0
    Tac0Tac0 Member
    I know this an old thread but I didn't see anyone with my setup. This sounds too good to be true, full suspensions are selling around me for 100-200.
    Will a full 3rd gen off road suspension (coils, shocks, leaf springs, control arms) fit my stock '09 5 lug 2wd access cab?
    This will make my day cause my suspension has well over 100k and could be replaced.
  11. Jul 22, 2020 at 7:48 AM
    #311
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    No they will not fit.
  12. Jul 22, 2020 at 7:54 AM
    #312
    Tac0Tac0
    Tac0Tac0 Member
    Is the whole suspension system just different between 5/6 lug? Is there anything else I can replace to make it fit?
  13. Jul 22, 2020 at 8:15 AM
    #313
    Ryan2103a
    SoCal
    Yes the whole suspension system is different. I did research on this before but I don't quite remember all the info.
    Check this out for more info about lifting your 5 lug
    https://www.tacomaworld.com/threads/the-lifting-your-5-lug-guide.518620/
  14. Jul 22, 2020 at 8:32 AM
    #314
    Tac0Tac0
    Tac0Tac0 Member
  15. Jul 22, 2020 at 10:32 AM
    #315
    leftyj1
    leftyj1 Member
    2006 Silver Tacoma TRD Sport PreRunner
    I've had 2019 OR suspension be on my 2006 dcsb prerunner for a few weeks now and it's settled to about 1.25" up front and .75" in the rear.
    When I turn right into a driveway I get this clunking sound. I've read that this is a common issue but I never had this sound before installing the '19 take offs. Anyone else run into this problem? Is this sound from the new suspension or from the lift?
  16. Jul 22, 2020 at 10:43 AM
    #316
    Ryan2103a
    SoCal
    Did you retorque and check to see if you tighten everything? I had the same issue but found one of the bolts loose.
  17. Jul 22, 2020 at 11:25 AM
    #317
    leftyj1
    leftyj1 Member
    Will do this Friday and report back
  18. Jul 22, 2020 at 12:52 PM
    #318
    Capt’nCrims
    Just to re ask my previous question does this mod work with 6 lug 2nd gen single cabs? Doubt it’s any different for the shorter wheel base but I’d love to hear if someone else has done this to a 2nd gen single cab.
    “If I take an off road suspension off 3rd gen, shocks, springs and leafs would it be a direct bolt on?”
    thanks.
  19. Jul 22, 2020 at 2:20 PM
    #319
    Ryan2103a
    SoCal
    It should work. I think @weeksz upgraded his reg cab with 3rd gen suspension.
  20. Jul 22, 2020 at 2:33 PM
    #320
    Capt’nCrims
    Figured as much, I’ll take my chances! Appreciate the feedback
