REVTEK 3" lift, your thoughts.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Mar 23, 2014.
  1. Mar 23, 2014 at 12:37 PM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    OK fellas...after mucho research, I think I'm settling on this.
    http://www.4wheelparts.com/Lift-Kit...eafs.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=REV426A
    Cost is an issue...I don't wheel (I wheel with my V8 4Runner)...I do tow a 6X9' trailer sometimes.
    I think this will be fine....
    Putting 16X7.5" FJ Anthracites with 285/75's, Duratracs, 1.25" spidertrax wheel spacers.
    Thoughts or haters, let me know. I know it's not the best, but it will suffice.
  2. Mar 23, 2014 at 1:00 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Probably gonna ride like complete shit. I've ridden in 3 Taco's with revtek lifts, and they were terrible. (2 1st gens,& 1 2nd gen
  3. Mar 23, 2014 at 1:11 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LOL yeah... spacers and blocks..... may as well just take the 350 bucks and set it on fire.
    Get some bilstine 5100's set em at 1.75in or 2.5 in the front and get a proper add a leaf for the rear
  4. Mar 23, 2014 at 1:14 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Don't settle man, save up and get a real lift! Take it from us guys who already went through the trial and error!
    Save up a little more loot and get a old man emu lift
  5. Mar 23, 2014 at 1:41 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Are you installing your self?
    Either way, you could get the bilstein adjsutables for front and AAL for the rear and it would be the same price or cheaper than the revtek lift.
    $200 for adjustable bilsteins
    $50 for procomp AAL
    $45 for U-Bolts
    Total = $295 (just a thought since cost is an issue)
    gutsybuttsy likes this.
  6. Mar 23, 2014 at 3:03 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Can I get a full 3" out of the 5100s?
  7. Mar 23, 2014 at 5:00 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
  8. Mar 23, 2014 at 5:07 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    1st choice...bad
    2nd choice...better
    If you are on a tight budget, the springs and aal will work good. Eventually you will want to swap out for something better though. If you have the coin, i would just go ahead and get a full lift with shocks and all. Just my .02
  9. Mar 23, 2014 at 5:14 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Yeah...don't have the cha-ching at them moment...maybe in a year or so. I'm thinking the coils and AALs will have to be good for now. But yes, after more research I'm staying away from spacers.
  10. Mar 23, 2014 at 5:16 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Not a fan - I went through the lift/suspension research and settled on a costly but quality setup. Don't go spacer or body lift, save up and do it right. Just my .02
    Bugna510 likes this.
  11. Mar 23, 2014 at 7:46 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    Ya my truck already had I think a procomp "level lift" and it sat way lower in the back so I went with rear spring and now saving up for new coil overs and uca and be done with it
  12. Mar 23, 2014 at 8:56 PM
    JDM DAD
    JDM DAD Well-Known Member
    Dustin
    Tucson AZ
    14 DCSB BRM TRD SPORT
    Dipped badges and wheels
    What's the difference between 884, 885, or 886? Should you run the spacer that come with the kit? Or are all spacers bad?
  13. Mar 23, 2014 at 9:05 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    The second lift would be better but DON'T go with the 886s. You would need new shocks and it will be stiff as hell. 886 is mostly if you are going to run a front plate bumper...
    Also somebody already said it but you're going to need new UCA's if you go over 2.5"... Light Racing is the most affordable brand of UCAs
  14. Mar 23, 2014 at 9:08 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    The difference is length and load capacity. 884 is a light duty spring, 885 is medium duty, and 886 is heavy duty for added weight (plate bumper, winch, etc). The spacers with that lift are only 1/2" so its not as bad as other spacers. You shouldn't run them with the 886 coils though...
  15. Mar 23, 2014 at 9:12 PM
    JDM DAD
    Dustin
    Tucson AZ
    So if I ran 885 with the spacers I would need uca? I don't off road much if anything getting to a campsite but nothing crazy...
  16. Mar 23, 2014 at 9:15 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    I would think so because the spacers are 1/2" and advertise it to be a full 3" lift. 2.5"+ = New UCAs
  17. Mar 23, 2014 at 9:29 PM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
    On a 2nd gen DC V-6 4x4 with stock bumpers and no armor, you'll get about 2" of lift up front with the 884 coils. Your stock struts will likely be too short and under damped for 884's, because the OME's are longer than stock (which is how you get the lift). You really should put on some 5100's, assuming you can't afford the OME struts/shocks. And unless you like a lot of rake, put a 1.5" AAL in the rear. (See my build pics for how this looks). You go much above 2.5" of front lift and you'll need new UCA ($400+), or else you won't be able to align your front end and will have a truck that handles like shit and wears out tires prematurely.
    The "Old Man Emu: Questions, Answers and Pictures" thread has extremely detailed information on this.
  18. Mar 23, 2014 at 9:34 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    This!^^ here's the link to that thread http://www.tacomaworld.com/forum/suspension/258245-old-man-emu-questions-answers-pictures.html
  19. Mar 23, 2014 at 9:40 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  20. Mar 23, 2014 at 9:48 PM
    spitfire501
    spitfire501 Well-Known Member
    Austin
    Napa, CA
    dude i cheaped out and bought that. rides like total shit and i feel every little bump. like everyone else is saying save up for the real deal.
