Ride Quality with Eibach/Billys
Discussion in 'Suspension' started by Mog, Aug 14, 2010.
  1. Aug 14, 2010 at 8:57 AM
    Mog
    Mog [OP] Active Member
    Brandon
    Gilbert, Arizona
    05 DC TRD Sport 4x4 Silver
    I have heard that the Eibachs with Billy's set at 0 = better than stock TRD ride (I have a 2005 DC 4x4). My question is if you set the Billy's at 0.85, how comparable is that set-up to the stock TRD ride. I really like the "feel" of my ride right now and don't want to compromise it much but was wondering if the extra lift is worth the decreased ride quality. Thanks
  2. Aug 15, 2010 at 11:01 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    The ride quaility is great. I added this set up to my 2010 DC/LB and also added michelin MS2 tires. No issues with vibes and a much much improved ride quaility over stock.
    Suggest you use the search mode and you will see lots of info on this subject.
    Good luck!
  3. Aug 16, 2010 at 9:38 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I have the 5100's set at zero with Eibachs and the ride is much better than stock. I plan to raise my 5100's to .85" in the near future for a little more lift.
  4. Aug 16, 2010 at 9:42 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Im about to install my eibachs this week. I will be leaving my billies at 0.00 setting. I figured the 1.6" lift capability that the eibachs provide is good enough. Plus I wanted to prevent any extra preload on the shocks, in order to preserve as much ride quality as possible. Im hoping 1.6" up front with only TSB 4 leaf pack in the rear, will provide somewhat of a leveled look. I will post pics when complete.
    Laters...
  5. Aug 16, 2010 at 9:56 AM
    Kernel
    Kernel Well-Known Member
    Ohio
    09 TRD Off Road 6sp Manual
    5100's all 4 corners, front at .85 with Eibach Coils, Rear TSB w/AAL, TRD Catback Exhaust, AFE Pro Dry S, Duratracs, redline hood struts, maglight mod, weathertechs
    I'm curious on this topic as well. Searching gives info, but there are varied results. The 1.6 lift seems to only apply to non 4x4s. A few are reporting they only got around 1 inch of lift if they are a 4x4. Those of you that are 4x4's with billies what are you actually seeing height wise?
    With 5100s @ 1.75 with stock coils I get 1.6 inches of lift on my TRD OR. I'd like to be in that 2-2.5 range. Looking at the eibachs and the .85 setting but I may only end up back to where I'm currently at, if the 1" of lift is true.
  6. Aug 16, 2010 at 10:30 AM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OME 885x coils, 5100's set at 0. Deaver 2" AAL and 5100s out back. AFE Pro Dry S drop-in, BHLM, '10 sport grille.
    I'm thinking about the OME coils (supposed to be 2" ..?) with the 5100s set at zero. I have nothing in the rear and plan to AAL so I'm trying to figure what will end up even with that. From information I've gathered on here - that might not be quite high enough in the front
  7. Aug 16, 2010 at 11:12 AM
    Taco's for All
    Taco's for All Well-Known Member
    Vermont
    2013 Tacoma Double Cab SR5
    Nothing at the moment
    In my 2009 4x4 I've got my 5100's set at .85 with my Eibach springs. I thought I was going to get 2.45 inches of lift (1.6+.85), but I really only got 2 inches. Either way, I still think it looks good and looks pretty good sitting next to the stock Tacoma's at the dealership.
  8. Aug 16, 2010 at 11:44 AM
    Kernel
    Ohio
    That's kinda what I expected. I'm considering doing this mainly to get less preload on the spring, and therefore a better ride. The extra .4 inches is nice too.
  9. Aug 16, 2010 at 1:08 PM
    Carlo
    Carlo Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    I have a 2010 SR5 V6 4x4 access cab and the ebachs with the 5100's set a 0. Ride is much firmer coming from standard SR5 suspension but, it's not harsh in anyway. Firmer for sure and on some really bad streets you do feel it more. I got more lift than some others here did. After my set was on it was about 1.80 inches. It has settled just a bit, but I would say that they are about 1.75. I am basically happy with my set and need to deal with the rear end. It's a good setup. I would maybe go with OME as the ride may be a little softer if I was to do it again. But, that is because I spend most of my time on the pavement. When I am off road, the new setup works really well.
  10. Aug 16, 2010 at 6:33 PM
    Mog
    Brandon
    Gilbert, Arizona
    I'm curious about this as well. I haven't seen as many people going this route, is there a reason? Is it the $20 difference (Eibach 149, OME 169)or are there compatibility issues with 5100s?
  11. Aug 16, 2010 at 6:35 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
  12. Aug 16, 2010 at 6:36 PM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    I actually found a couple posts on another related topic in "suspension" from Chris4x4 (who seems to be respected for his knowledge on such things) and his comments made me think I'm on a good path looking at the OME coils. Were it not for just snagging a good deal on 5100s from a forum member - I was planning on just going full OME
  13. Aug 16, 2010 at 7:04 PM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    Numnutz, you wouldn't have that AAL any more if I had the TSB. LOL
