Roll Bar. Where to get how to install.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airsoft_warrior, Jun 27, 2008.
  1. Jun 27, 2008 at 10:48 AM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I am looking for that off road look. and trying to install a roll bar in the bed of my 08 double cab with short bed. I would also like to put some KC lights on it but dont know where to look for the bar or how to install it or the lights. If anyone has some advice on where to look what kind, lights and installation proceedures. It would be helpful. Thanks!
  2. Jun 27, 2008 at 10:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Jun 27, 2008 at 11:19 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    What your talking about would not be a roll bar but a glorified light bar. No actual protection from a roll without doing some serious modding to your truck and the bar itself.
  4. Jun 27, 2008 at 11:19 AM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    The problem you have with most pre-made, or multi piece kit is that they are just for looks, and you will notice in searches they are usually called "sport bars". The only way you will get a true protective roll bar is to find a good welding/fabrication shop. You will have to cut holes in the bed and have bar directly mounted to frame. If you just want the look, then do a search for light bars, or as mentioned sport bars. Usually versus a bar can be mounted on the sheetmetal bed by making plates larger than the base supplied with the bar to spread the load over a larger area, but the Tacoma's bed is not sheetmetal, but I guess you could do the same and see how it goes.
  5. Jun 27, 2008 at 11:27 AM
    LRH
    GA USA
    '07 2.7L PreRunner
    It seems every South/Central american, Euro and Pacific Rim portion of the world offer those as option on most every make of truck, but not much in the US anymore except for truly funcional types in Jeeps, old FJ's and other similar, smaller 4WD sport utes. I guess in the US everyone is so lawsuit happy, that they sue when the sportbar crumples in a rollover.
  6. Jun 27, 2008 at 1:14 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    Check my gallery. I got one from a '95 and the only issue I've run into is that apparently the '95 Tacomas' wheel wells were tilted slightly inward, so it doesn't mount flush. If I flip the left downtube with the right, it might aleviate the problem, but I haven't gotten around to testing it. That is one of my plans I'm saving for when I quit my job.
    If you can find one on Craigslist or in your local classifieds, ask the seller if they would mind you coming by to test-fit it and you can go from there to determine the cost vs effort vs reward ratio. The only reason I mention looking for a used one, is because no company makes a decent looking light bar for the 05+ Tacoma.
    All of this is only my two cents, of course.
  7. Jun 27, 2008 at 2:55 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    *quietly backs away from this thread*
  8. Jul 1, 2008 at 7:57 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I checked some of the other threads and looked around the net. I cant find anything anywhere. I am wondering if trick trucks could get hold of one. I don't care if it doesnt protect me in a roll over. I want the lights on top. I just love that look.
  9. Jul 2, 2008 at 5:20 AM
    Angus_NB
    Angus_NB Well-Known Member
    Riverview, NB, Canada
    '08 Tundra DC SR5 4x4
  10. Jul 2, 2008 at 6:06 AM
    Janster
    Jandy
    Lancaster, PA
    You could get one custom made but it'll cost BIG BUCKS to do it. Just visit a hotrod shop or specialty 4WD fab shop....they could bend tubing and custom weld a rollbar to your exact specifications.
    Airsoft warrier?
    My husband just started doing that. I'll probably get out there one of these days and give it a try..... I'm more tempted to pelt the rabbits in my backyard with it. :eek::D
  11. Sep 22, 2008 at 1:43 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    where are you going, with your sport bars?
  12. Sep 22, 2008 at 1:47 PM
    mjp2
    NJ
    Off to wash and wax my truck. The neighbor mowed his lawn and kicked some dust up onto my beautiful paint! :mad:
  13. Sep 22, 2008 at 1:48 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    the first time anyone here mentions your name in about 3 weeks and look who shows up...:eek: you're starting to scare me.
  14. Sep 22, 2008 at 1:51 PM
    mjp2
    NJ
    I sensed that someone was longing for my presence. Imagine how bummed I was to see it was only you!
  15. Sep 22, 2008 at 1:52 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    you were so right! I had to wish toy4life a happy birfday on your behalf, it was horrible :mad:
  16. Apr 11, 2010 at 7:05 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Hehehe, I finally found one. Shadowfalkin helped me get it fabricated right and I should have it mounted soon.
