SATOSHI MOD --- 1st gen. write-up (lots of pics)
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomarotto, May 31, 2012.
  1. Jul 31, 2012 at 10:06 AM
    #141
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    I've attached a few pictures that could help a beginner body work person out. That seemed like it was going to be the most difficult part of this project because of the fiberglass work and such.
    I'll start off with the fiberglassing since the obvious cutting is needed, we know that much. The best way to go about this is to get as close to level as possible, I understand why the 98-00 Tacos are difficult to do this with now.
    Tape off both side on the inside of the grill:
    Go over the top just a little, makes it easier in the long run:
    Place the fiberglass inside the mixture, per directions and lay across the tape on the outside of the grill. (could not take pictures, play with fiberglass and you'll understand why) Once dried, remove the tape, yes it comes off easily:
    I applied additional glassing to reinforce it, do so as necessary, I wanted a sturdy backing:
    Now to the "Fun" part of it......Sanding.....
    Get a block and sand with some rough stuff, you'll be doing it more than once so cutting it down is the key:
    Before applying any Filler, clean the grill thoroughly to ensure proper adhesion. Soap and water or acetone will be fine.
    I used the red putty stuff used in other Satoshi mods, you can use body filler, I just got this because I didn't need the entire can of Filler/Bondo. I have found through my experience that if you get the filler/Bondo can with hardener and such it will make it easier in the long run:
    Keep going making sure to apply some pressure not only to cover everything, but to get into all the cracks.
    Done with first round of filler:
    Now sand everything with a block. I used some cardboard pieces with 600 grit wet/dry sandpaper. Using the block is critical to ensure you will be able to notice any holes or lumps anywhere, this will clear everything up.
    Next, clean again with soapy water or a light layer or acetone; acetone will start to remove the putty, it is a strong chemical, you've been warned:
    Now spray time! No you aren't done, this is to see where you messed up! :
    I used this:
    Light coats every 5-10 minutes should do the trick.
    When done, you'll be able to see stuff like this:...Bummer...
    and imperfections like this:
    ewww you don't want that showing on your fancy new grill, do you?
    I didn't take pictures here, but the process is simple...I call it rinse and repeat. Block sand the rough areas again down the fiberglass and fill the areas that need it. Sand that filler, clean and prime, once you can't see anything you are good to proceed to the next step.
    I must have missed this, but I just sanded with 1000 grit wet/dry and used "Sealing Primer". Remember to clean before priming!
    Now...template time.
  2. Jul 31, 2012 at 10:18 AM
    #142
    CliffordBRD
    Cliff
    Tampa, FL
    To make your precious template keep in mind, you have one shot at this. Don't go crazy and try to just hack away at your metal and expect it to turn out perfectly.
    Get a nice piece of cardboard, if you ordered your mesh from Homer, well...use his!
    Make a rough draft:
    I cut slits in the cardboard to guess how big I will really need to make it, this will help me at the end, measuring everything up.
    I also made note of where all the tabs are since I want to utilize those to help secure the grill. Move your template to your mesh and trace:
    Very good:
    Start cutting, make yourself aware that you get one shot, keep fitting it to the grill to make sure you don't cut out too much. I just kept bending pieces back and marking where I could cut to:
    Getting there:
    Like I said, go slow....make many many cuts, this part takes time:
    Pretty much there, just a few more cuts:
    It's hard to tell, but I cut out two slots on each side to slide on to each piece since I will be riveting the grill in.
    Tabs and all ready to go:
    Just a little off center, I never said I was perfect :eek: But everything fitting nicely now:
    Well, well, well...this actually is looking legit now:
    I drilled some holes for my rivets, wiped it all down and painted it with engine enamel. I used an entire can and could still use a little more. Light, even coats every 10 minutes or so.
    Riveted in:
    Ready to go on; Satoshied!
  3. Jul 31, 2012 at 11:12 AM
    #143
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    ^^ Looks great! You shoulda made your own write up though... especially for us guys with the 98-00 grilles :D
  4. Jul 31, 2012 at 12:37 PM
    #144
    CliffordBRD
    Cliff
    Tampa, FL
    Well, I was going to, but I want there to be a like "master satoshi" thread....I'll do it I guess...
  5. Aug 2, 2012 at 1:10 PM
    #145
    tacomarotto
    tacomarotto [OP] Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    sweeeet. looks good
  6. Aug 2, 2012 at 1:20 PM
    #146
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  7. Aug 2, 2012 at 1:32 PM
    #147
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    Awesome thread. Subbed for when I do mine soon!
  8. Aug 2, 2012 at 10:42 PM
    #148
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Just about finished with my 3rd 01-04 satoshi then will be doing a 98 if anyone would be interested send me a pm.
  9. Aug 2, 2012 at 10:52 PM
    #149
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    beautiful... wish i took it easy when i did mine 3 years ago.. :( mines looks like crap
  10. Aug 3, 2012 at 8:06 AM
    #150
    tacomarotto
    Jon
    Jacksonville, FL
    thanks man. why not do it over?
  11. Jan 7, 2013 at 11:09 AM
    #151
    03tacoman
    03tacoman Well-Known Member
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    the reason everyone is using bondo on parts of the grille is to smooth out the ends/cuts from where the old parts of the old grille insterts were right? so that they wouldn't show infront of the satoshi ?
  12. Feb 14, 2013 at 3:31 PM
    #152
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    fiberglass is drying right now on mine! :D
  13. Feb 14, 2013 at 4:08 PM
    #153
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Perfect time to upload some progress pictures....:D
  14. Feb 15, 2013 at 7:02 PM
    #154
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    I'll have a few up in just a little bit! Got the bondo almost done today, one more touch up layer and final sand tomorrow then I get to shape my mesh. I'm not using any mesh like anyone else that I have seen though. I just picked it up from home depot and it doesn't look too bad it's mesh that's meant for cement work I think but different is good ? :confused: you'll see an example of it on the pic I upload of the triangle inserts that I finished doing tonight as well
  15. Feb 15, 2013 at 7:27 PM
    #155
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
  16. Jun 11, 2013 at 10:28 AM
    #156
    AhviFree
    AhviFree Well-Known Member
    San Antonio,TX
    01 4x4 Tacoma
    Thanks for the write up, it was helpful. One thing I did differently was instead of cutting out the 2 side grill inserts and then gluing them on, I used a small torch (pencil torch) to heat up each tab on backside then just pull off..then use the same tabs just put on heat tabs and smash em flat..worked great
  17. Jun 11, 2013 at 10:46 AM
    #157
    tacomarotto
    Jon
    Jacksonville, FL
    well done good sir!
  18. Jun 11, 2013 at 10:49 AM
    #158
    PreRunning
    PreRunning Well-Known Member
    Clayton
    Missouri
    01 Lunar Mist Prerunner SR5
    Window Vents, Westin Bull Bars, Kenwood Deck, Kicker and Kenwood Door and rear Speakers, Alpine 660 RMS Amp, Twin Kicker 12 inch CompVR Series Subs, 265/75/16 Wrangler ArmorTrac Tires, Uhaul Towing package, removed mud flaps, Flowmaster 40, Cold Air.
    That looks friggen sweet! Digging the flat black hood stripe
  19. Jun 12, 2013 at 10:48 AM
    #159
    AhviFree
    San Antonio,TX
    01 4x4 Tacoma
    Thanks..yeah I had the whole grill wrapped in it but it got damaged during the mod. Cheap way to cover the faded paint on my hood
  20. Jul 27, 2013 at 12:14 AM
    #160
    tacomarotto
    Jon
    Jacksonville, FL
    damn im excited to do this again when i get my second taco. i miss her already...
