ScanGaugeII - 2016 Trans Fluid Temp Codes That WORK!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by damnfingers, Jun 15, 2016.
  1. Jun 20, 2016 at 6:48 AM
    #41
    damnfingers
    damnfingers [OP] Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    I don't think that's the transmission used in the 2016's, is it?
    Online it mentions 2014...
  2. Jun 20, 2016 at 6:53 AM
    #42
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Its not
  3. Jun 20, 2016 at 7:27 AM
    #43
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    no it is not but perhaps these shreds of information about temp sensors and the roles in an aisin tranny
    will lead someone who is more resourceful than just 'someone get me the codes for a 2016' to go get
    the info from techinfo or reverse engineer the canbus communication from a techstream
    the new tranny in the 2016 uses the same type of temp sensors for the same reasons, but they are
    obviously using a different message ID's on the canbus than earlier models
    someone with a techstream could find the message ID's from the canbus that would solve the issues in programming scangauge, [I think....]
  4. Jun 20, 2016 at 8:08 AM
    #44
    damnfingers
    Gene
    Mississippi
    And you may be correct...but the codes I'm using for the transmission fluid temperatures on the ScanGauge came from ScanGauge so until someone comes up with some new ones I'm using these.
  5. Jun 20, 2016 at 8:20 AM
    #45
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    got it
  6. Jun 20, 2016 at 8:59 AM
    #46
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    this is when we had the 2012 Tacoma, note the rpms.
  7. Jun 20, 2016 at 1:11 PM
    #47
    damnfingers
    Gene
    Mississippi
    I take it the TT-Pan and TT-Conv are the transmission fluid temperature read-outs? Sure are a lot lower than the ones I'm seeing right now.
    What gauge set-up is that?
  8. Jun 20, 2016 at 4:29 PM
    #48
    damnfingers
    Gene
    Mississippi
    Just checked the http://www.scangauge.com/support/x-gauge/toyota-specific/ website and they're now listing those codes for the 2016 Tacoma.
    Can anyone who has used them verify the fluid temperatures? Mine is appearing to be VERY HIGH compared to the temperature the fluid is supposed to be at.
  9. Jun 21, 2016 at 5:12 AM
    #49
    NoDak
    JR
    Minot, ND
    that is torque pro version. you can setup the screens display however you want. more or less dials, 1/2 dials, ect.
    TT Pan & TT Conv is suppose to be the temp sensor at the pan and the either at the converter or on the output side of the converter, cant remember.
    the only 2 dials that don't read directly from the ecu are the trip mileage and avg mpg.
    Cat is the catalytic converter bank 1 sensor 1
    also if you notice each dial has a green dot. that is a heartbeat indicator for that dial. lets you know the update interval of that particular pid/sensor. if you look some are full green and some are faded.
  10. Jun 21, 2016 at 5:16 AM
    #50
    NoDak
    JR
    Minot, ND
    take my temps with a grain of salt. you have to take into consideration that my intake temp was 50F so the temps will be lower due to being colder outside.
  11. Jun 21, 2016 at 8:29 AM
    #51
    damnfingers
    Gene
    Mississippi
    Wrote to ScanGauge last night and got this response:
    Gene,
    Thank you for pointing out the typo on our website, I will have this fixed promptly.
    Depending on vehicle conditions, weather conditions, and driving conditions, the transmission temperature can range from 145 to 195. Towing will normally bring the temperature up around 200 on the low end. It is not unusual in summer months for the readings to be around 185-195. The TF1 sensor is located above the shift solenoid and the TF2 sensor is located lower near the pan. The TF1 best represents the transmission fluid temperature. The TF2 is effected by the trans cooler and whether or not air is passing through it such as when stopped at a light. The TF2 reading will fluctuate more than the TF1 reading.
    Regards,
    Cristina Bollinger
    cctk2 and deergetr like this.
  12. Jun 22, 2016 at 6:13 AM
    #52
    NoDak
    JR
    Minot, ND
    this pretty much confirms that damnfingers post about temps being the same leads me to believe you are using the same sensor for both readings as scangauge has confirmed that you should be seeing 2 different temp readings. the pan temp should be lower due to the sensor being after the cooler and the converter temp should be higher.
    only reason you should have the pan temp is to let you know something is wrong if both temps are the same between the converter and pan.
    edit : forgot to add, if you are seeing temps in the 210F or higher for extended periods you might want to look into why. you will hit those numbers of your constantly trying to pull a trailer and torque converter isn't working correctly. best bet is to force the transmission into 5th or 4th to take the converter out of the equation.
    yes you will go thru more gas, but your transmission will thank you.
    note : if you see temps in 210+ and you drop it down 1-2 gears (2016+) or 1 gear in the 2nd gen your temps will drop back down into the 185 range.
    this app i used helped a lot when pulling a 6x12 uhaul trailer with the 2012 Tacoma for the daughters college year. forced me to make sure I kept the temps in the 185 range at all times.
  13. Jun 22, 2016 at 6:59 AM
    #53
    damnfingers
    Gene
    Mississippi
    NoDak...not sure what you're saying here. I am seeing two different temperatures as you can see from the last photo where I'm stopped, TF1 is 190, TF2 is 199. The email I sent to ScanGuage that brought about the response above was in part:
    "I’m beginning to question the validity of these (temps) anyway. My ScanGauge is reporting my transmission temps (TF1 and TF2) as being in the 190 dF range which I find hard to believe in a new truck. Before I take it back to the dealer and spend $135 to have him check the fluid level is there anyway you can double check?"
    I was questioning what I considered were high temperatures, not where they were being taken from.
    Now, back to where the two temperature readings are taken...they appear to correlate to the take-off points in the picture posted of the A750E/F transmission in post #20 in which case you're correct, there isn't one being taken from the pan. But does it matter since they're being taken from the transmission control points? And yes, I know this isn't the 2016 transmission but that shouldn't affect take-off points and what TF1 and TF2 are used for.
  14. Jun 22, 2016 at 7:31 AM
    #54
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    yes in any aisin transmission the temp sensors may be physically be inside the same valve body plate, but they
    are checking completely different fluid pathways temps and perform separate functions
    one temp is used for basically lockup of clutches and brakes, the other is shift points
  15. Jun 22, 2016 at 8:21 AM
    #55
    splitbolt
    NW Arkansas
    Have you tried S-mode? I'm kind of curious if your temp would go down due to the flex lock being limited.
    SOSHeloPilot likes this.
  16. Jun 22, 2016 at 8:42 AM
    #56
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    Wonderful having the ScangaugeII on line for management.
  17. Jun 22, 2016 at 11:22 AM
    #57
    damnfingers
    Gene
    Mississippi
    Not yet...the truck is less than a week old and I'm still getting used to it...and not getting to drive it much at that. Maybe someone else with one can check?
  18. Jun 23, 2016 at 6:13 AM
    #58
    NoDak
    JR
    Minot, ND
  19. Jun 23, 2016 at 10:24 AM
    #59
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    These codes aren't working for me. I have triple checked that I have entered them correctly.
    I have two gauges, one is ver 4.06 the other is ver 4.13, the codes don't work in either.
    Both TF1 & TF2 read exactly the same and range from 150 to 3000 or higher depending on RPM's.
    Any ideas?? TIA
  20. Jun 23, 2016 at 10:49 AM
    #60
    damnfingers
    Gene
    Mississippi
    Any update on how they did while towing?
