Searching threads stuck in park cruise works but light flashes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cowboy5T, Oct 6, 2014.
  1. Oct 6, 2014 at 9:26 PM
    Cowboy5T
    Cowboy5T [OP] Active Member
    OK
    06 tacoma 4x4
    Don't know if any of this is related but my automatic transmission selector will not shift without using override button and same day while my cruise control was engaged the light was flashing but still working I am going to scan but I was checking with Taco people if any of you have had this issue? Thank You
  2. Oct 7, 2014 at 4:50 AM
    gearcruncher
    Canadain bumper technician
  3. Oct 15, 2014 at 8:56 PM
    Cowboy5T
    OK
    06 tacoma 4x4
    Ok more help where is the brake light switch? Used search function on this forum!
  4. Oct 15, 2014 at 8:59 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    2013 Prerunner Silver
    4in MaxTrac Lift Spindles, 2in Pro Comp AAL, MB 352 16x8.5 Wheels, 285/75/r16 General Grabber AT2s, 2.7L I4
    Check the fuses by the battery, I had the same problem and it was a blow fuse.
    Extra fuses should be on the bottom of the lid to the fuse box.
    See the manual for which fuse it could be.
  5. Oct 16, 2014 at 9:06 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Under dash at top of brake pedal. If the switch is bad or mis adjusted it may be the issues. Check your fuses first !!, Then check your brake lights too.
  6. Oct 16, 2014 at 7:05 PM
    Cowboy5T
    OK
    06 tacoma 4x4
    Ok I am going to ohm out fuses this weekend
  7. Oct 23, 2014 at 7:26 PM
    Cowboy5T
    OK
    06 tacoma 4x4
    Burned out fuse on brake light where do I chase down what caused it it happened with no trailer hooked up just long distance drive.
  8. Oct 23, 2014 at 7:46 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    I got my truck stuck and someone pulled me out which is what popped mine. I don't really know if there's a way to tell.
  9. Oct 23, 2014 at 7:51 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    IGN-1 Fuse is blown.
  10. Oct 23, 2014 at 7:51 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    i bet your AC controls dont work?
  11. Oct 24, 2014 at 5:25 AM
    Canufixit
    New England
    Did you save the burned fuse??
  12. Oct 25, 2014 at 10:23 AM
    Cowboy5T
    OK
    06 tacoma 4x4
    Ok, AC control works, think I saved fuse was a complete burn out in two, get in it today (drive company rig all week) and shifter stuck again going to check fuse again where am I going to ground? Think it's a direct short I do pull but nothing when fuse burnt thinking trying at trailer lights and working forward.
  13. Oct 25, 2014 at 11:12 AM
    Canufixit
    New England
    Look at the fuse. If it's vaporized it's a dead short to ground. If it just melted enough to open the circuit, it's over amperage draw. Tell me what you see and I'll try to help.
  14. Oct 25, 2014 at 5:52 PM
    Cowboy5T
    OK
    06 tacoma 4x4
  15. Oct 25, 2014 at 6:39 PM
    Canufixit
    New England
    It looks like an over amperage not a short, but Per the picture I'm not absolutely sure.
    How many amps is the fuse?
    Fuse powers what ???
    Is the fuse the correct amperage?
    Did you install another and did it blow ???
    Do you have trailer harness?? If so, aftermarket or Factory??
    Sorry for the delay response. my wireless router had an issue I needed to fix ...
  16. Oct 25, 2014 at 7:07 PM
    Cowboy5T
    OK
    06 tacoma 4x4
    How many amps is the fuse? 15 amps I believe
    Fuse powers what ??? Brake lights
    Is the fuse the correct amperage? Yes always put right amperage in Journeyman electrician (high voltage)
    Did you install another and did it blow ???just that one to replace the one that blew
    Do you have trailer harness?? If so, aftermarket or Factory?? Yes trailer harness factory tow package do have electric trailer brake box installed by a trailer place
    I Put my ohmmeter on it rang out minute i depressed brakes petal (1 on hot one one on other side just completed circut right?
    Thanks
  17. Oct 25, 2014 at 7:22 PM
    Canufixit
    New England
    Well it is working now correct??? DO not put in a higher amp fuse.
    Since it's working now It's a bitch to find it.
    This is what I'd do.
    Buy extra fuses and keep them handy.
    Drive the vehicle as is and see if it blows the fuse. Let a number if days go by.
    If it does or does not blow. Hook up the trailer with the e brakes and take a spin to see if it blows. If it does you have a starting point. if it blows with the e brake now connected, I'd isolate the ebrake line going from your truck to THE CONTROLLER (not the trailer). cut into the E brake wire that is blowing the fuse (use your ohm meter back to the fuse) and splice an inline fuse and put in a 10 (ten) AMP.
    Repeat the above and see which fuse blows first. If it blows in the fuse box - the problem is in the truck ... if the lower 10 amp new in line fuse blows - its the E brake adapter and or from there to/in your trailer ...
    Does that help??
  18. Oct 25, 2014 at 7:44 PM
    Cowboy5T
    OK
    06 tacoma 4x4
    It blew with out trailer hooked up seems to blow the after depressing the brake petal it has been doing this when i am not towing
  19. Oct 25, 2014 at 7:49 PM
    Canufixit
    New England
    can you disconnect the ebrake controller that was added?? Do that and see if it still blows. IF it does I'll have to start looking at schematics.
    If it does not blow then;
    isolate the ebrake power line going from your truck to THE CONTROLLER (not the trailer). cut into the E brake wire that is blowing the fuse (use your ohm meter back to the fuse) and splice an inline fuse and put in a 10 (ten) AMP.
  20. Oct 26, 2014 at 8:35 AM
    Cowboy5T
    OK
    06 tacoma 4x4
    Ok don't know if this is related but I found 3 random wires appearing to come out of the driver side tail light red, red white stripe and black no voltage when I put volt meter on them but I didn't have lamps or brake depressed taped the off and disconnect tr brake controls so far so good
