Serpentine belt replacement. 2011 V-6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gregzz, Jan 17, 2020.
  1. Jan 17, 2020 at 11:03 AM
    gregzz
    gregzz [OP] Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    Hey all... I’m getting ready to change my serpentine belt here tomorrow on my 2011 V-6 and I’m looking for some info from others that have done this as there’s ABSALUTLEY no room to move around in there. Thx in advance for any help, pics, trucks, whatever. Cheers!!
    Pipeliner51 likes this.
  2. Jan 17, 2020 at 11:04 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Have you checked youtube yet???
    gregzz[OP] likes this.
  3. Jan 17, 2020 at 11:05 AM
    gregzz
    greg
    las vegas nv
    Yes but they’re not very in depth, just Sorta shows videos of where it’s located and the only thorough video is of someone’s 2006
  4. Jan 17, 2020 at 11:05 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    If I recall, I only removed the fan shroud to get better access. Pretty easy after that.
    inwood customs and gregzz[OP] like this.
  5. Jan 17, 2020 at 11:07 AM
    Tacoma Mike
    Southern Maine
    Go from the bottom.
    Make a diagram of the pulleys and belt placement.
    Only takes a few min once the skid plate is removed.
    Just did one about 20 min ago.
    Wish I had seen this earlier.
    tommie594, b_r_o, TACOGUY23 and 3 others like this.
  6. Jan 17, 2020 at 11:07 AM
    Tacoma Mike
    Southern Maine
    Don't need to remove the shroud
    R0dzilla75, Elikk, Chris(NJ) and 4 others like this.
  7. Jan 17, 2020 at 11:08 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    plenty of room and super easy, took me less than 5 mins to do.
    Access the tensioner from under the truck in front of the drivers side tire FYI
    Chris(NJ), EdgemanVA and gregzz[OP] like this.
  8. Jan 17, 2020 at 11:32 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
  9. Jan 17, 2020 at 11:35 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I bought this one, have yet to put it on though.
    https://www.ebay.com/itm/BANDO-7PK2...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2648
    Sae68 and Accipiter13 like this.
  10. Jan 17, 2020 at 11:40 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    This. Work from the bottom. Easy, just make sure you have a head lamp and a small screwdriver to put in the slot to hold the tensioner loose. The diagram helps. Spin all your pulleys to check for play. Depending on mileage I’d highly recommend you swap your three idler pulleys while you are there.
    kalaukoa and gregzz[OP] like this.
  11. Jan 17, 2020 at 11:41 AM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
  12. Jan 17, 2020 at 11:47 AM
    gregzz
    greg
    las vegas nv
    I’m going with continental for $34.99 because it has a good reputation and a 3 year warranty unlike Dayco which only offers 12 months.
  13. Jan 17, 2020 at 11:48 AM
    gregzz
    greg
    las vegas nv
    Thank you!!
  14. Jan 17, 2020 at 11:49 AM
    gregzz
    greg
    las vegas nv
    Thank you. I’ll try this. I was going to go from the top but I’ll try it your way. Thanks
  15. Jan 17, 2020 at 11:54 AM
    kalaukoa
    kalaukoa Well-Known Member
    Kailua
    2011 TRD OR 4x4 Access Cab
    As others have mentioned, go from the bottom. Drive belt and idler pulley kit are available via ebay for $64.98 w/ free shipping. Might as well change everything while you are in there. there is a diagram of the belt orientation here in the 2nd gen section under mods and tutorials I think.
  16. Jan 17, 2020 at 12:05 PM
    kalaukoa
    Kailua
  17. Jan 17, 2020 at 12:08 PM
    Jcannon
    Jcannon Well-Known Member
    Jay
    OKC, OK
    05 DC 4x4 TRD OR
    Perfect timing. I have a pulley making some noise. This will save me some time because I was going to try from the top.
  18. Jan 17, 2020 at 12:10 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Like others have said, very easy from the bottom when you remove skid plate. Use small flathead or pin to lock tensioner in place and it should be a breeze. Make sure you put the belt on in the correct orientations!
  19. Jan 17, 2020 at 12:11 PM
    gregzz
    greg
    las vegas nv
  20. Jan 17, 2020 at 12:13 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
