Setting up Truck for Greasing Zerk's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Dec 24, 2009.
  1. Dec 24, 2009 at 4:58 PM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    What's the best way to get setup for greasing the zerk fittings as far as being able to spin the drive-shaft with your hands to gain access to the zerks with the grease gun. Does the truck need to be in neutral and the wheels off the ground?
  2. Dec 24, 2009 at 5:05 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Swise has a better link :D
  3. Dec 24, 2009 at 5:05 PM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
  4. Dec 24, 2009 at 8:34 PM
    OffroadToy
    thanks johnv...appreciate your input.
  5. Dec 24, 2009 at 8:51 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I suspect your typo had Johnv wanting to make a remark that might not be appropriate for Christmas eve... :)
  6. Dec 24, 2009 at 9:05 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    You are way over thinking this.
    If you can't access the zerks when you crawl under the truck, move the truck under its own power a few inches until you can - you'll quickly figure it out. As for the front, leave the 4wd disengaged so you can spin the drive shaft by hand.
