Severe alignment issues -with photos
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anamorphic, Apr 2, 2013.
  1. Apr 2, 2013 at 6:30 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I agree that it could easily be the centering pin especially because of the AAL. Get a couple new pins and get in there and look. Also maybe take the current AAL out and get a new one, you will be better off with a wheelers or toytec.
  2. Apr 2, 2013 at 6:38 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    im not sure what the tsb pack looks like, im just assuming its aftermarket. if you have any friends with jack-stands, a floor jack, and a few metric sockets, its really an easy job to check it out/ add another leaf.
    whatever you do though, it is always a good idea to have new u-bolts if you remove or have someone else remove the old ones. I've never heard of "catastrophic old u-bolt failure" but im assuming that's because everyone replaces their old ones after removal.
  3. Apr 3, 2013 at 11:51 AM
    anamorphic
    anamorphic [OP] Well-Known Member
    08 TRD Sport 4x4
    I'm still pretty confused on what to do. There's no way the frame is bent on this thing.
    I'm thinking about getting OME Dakar's and new hardware.
  4. Apr 3, 2013 at 11:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Start with the simple shit first. There is a centering pin on the leaf springs that inserts into the top of the axle that keeps the axle centered and tracking straight. This pin is not a tight fit into the axle and there is a small amount of 'play' in the fitting. Jack the rear end up, loosen the u-bolts and tug on the tire in the direction you need them to turn. That should be enough to get your rear back in check. If the centering pin is broken, you'll know by jacking the rear end, loosening the u-bolts and letting the axle back down (put frame stands under the frame rails and let the axle hang). FWIW, I doubt your centering pin is sheared.
    The tech who did your alignment should have had a much better reason for wanting to tear apart the whole rear end. It is a little concerning that the toe for the rear isn't the same side to side (straight axle, they should be the same or close). How does the truck drive, does the rear end shake?
    Also, don't necessarily assume that the body is 100% straight on the frame. There have been some people with alignment issues as far as the body not sitting perfectly in line with the frame.
  5. Apr 3, 2013 at 12:16 PM
    BamaToy1997
    Bill
    Navarre, FL
    Sorry if I missed something, but where do you get that the caster is so far off? The readings are 1.5 and 1.3, with 1.6 being nominal. Seems reasonable to me.
    First step in alignment is pre-toe set so that the sensors are set for a proper swing, then you get the rear within specs. They came back and told him that they could not get the rear into alignment. If you can't align the rear, you are wasting time aligning the front. I would not have adjusted the front either.
    Just my $.02 worth.
  6. Apr 3, 2013 at 12:30 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Go through this thread:
    http://www.tacomaworld.com/forum/suspension/54186-aal-install-second-gen.html
    The center bolt/pin is what everyone is talking about. If it is not in the hole of the head sheared off, that could be what's causing your rear alignment issues.
  7. Apr 3, 2013 at 12:42 PM
    anamorphic
    08 TRD Sport 4x4
    Truck pulls to the right. Not terribly, but enough for me to have an alignment done. No shaking or vibes.
  8. Apr 3, 2013 at 12:44 PM
    anamorphic
    08 TRD Sport 4x4
    Thanks! I'm going to take some photos on the AAL right now. Maybe someone will be able to tell if the previous owner installed them wrong.
  9. Apr 3, 2013 at 1:09 PM
    anamorphic
    08 TRD Sport 4x4
    Honestly, I don't really know what I'm looking at. Do I have an AAL, or the TSB done?
    The curve in the leafs in the 4th picture looks a bit wavy to me. Again, no clue what I'm looking at. Not trying to act like I know what I'm talking about- just trying to gain some knowledge on what's going on with this thing.
    2991E5F9-ACBF-4DC3-A79E-2AE264A7DECA-335_e351a4ab9546ac4c9eb19785b56c10eea4a81b32.jpg
    1CC7807C-499C-4368-BC23-69918212C145-335_13faee39213e829027b17518c3470a0db77b437c.jpg
    81C8C172-3B12-44F2-8173-61A0694BA56C-335_89aecab5bdf480f1a9e088ad446c64cd26ecea95.jpg
    4AD249E0-BF16-4B2A-BB52-BCD067FD5B2E-335_20a311fcacd1cd26357b52e6211175b3aebe2d59.jpg
    04AC1515-ECD8-486F-855F-B49045D9043E-335_ec455f1d6f2d11cbf648c7df886f80ed8e9b2a3f.jpg
    80AD4B70-04F3-438B-A6DD-5B2941968CD1-335_9d2650c572cdafc71a8ff04e4631456cf9de1356.jpg
    4AAF76AB-E841-4550-8CE4-31BA024DBCC8-335_17c4fcd3afd26f3627f1e3224560c142e1489601.jpg
  10. Apr 3, 2013 at 1:18 PM
    Pugga
    Massachusetts
    You have a set of helper springs (looks like something Hellwig would make or similar). Whoever installed them would have had no reason to remove the stock centering pin to install them. The helper springs are the springs on the very top of the leaf pack. You do NOT have a TSB leaf pack, you have the standard 3-leaf pack.
    In your last picture, it looks like the helper springs are installed too far to the rear. That front clamp should be close to the stock u-bolt. By shifting it back, it just clamps the overload leaf to the active leaf pack. That's not causing your alignment problem but it's certainly not helping your ride any either.
  11. Apr 3, 2013 at 1:23 PM
    anamorphic
    08 TRD Sport 4x4
    Got it. Thank you for explaining that.
  12. Apr 3, 2013 at 3:32 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    IM SURE THIS IS IT .......
  13. Apr 3, 2013 at 5:12 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Isnt the range for caster go upto to 2.7? I always read that you pretty much want the max caster within range.
  14. Apr 4, 2013 at 7:01 AM
    BamaToy1997
    Bill
    Navarre, FL
    My documentation shows that depending on the tires, and specific Tacoma model, caster nominal spec is between 1.68, and 2.1 degrees. The print out there was indicating that his nominal would be somewhere close to the 1.68 range.
    You want caster to be at the nominal point, not the highest point. Excessive caster can cause excessive steering effort, which can cause premature wear on the steering gear.
  15. Apr 4, 2013 at 9:47 AM
    #35
    brutalguyracing
    F.U> GUYZ
    broken mods
    When lifted
