Shift points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toycan, May 23, 2011.
  1. May 23, 2011 at 5:42 PM
    Toycan
    Toycan [OP] Well-Known Member
    Ontario
    11 TRD S DC Grey
    trifecta tonneau, bed mat, husky liners, TRD shift knob, Kenwood NAV DVD Dbl Din syst, TRD wheel centre caps, aux backup lights
    I've got a manual 6 speed and am tempted to skip gears when driving causally with traffic etc like going from 3rd to 5th for example, anyone else do this, seems to pull well without pinging form like 1100 or 1200 rpm and just wondered what other expirences were.
    Thanks
  2. May 23, 2011 at 5:43 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I skip 3rd all the time with my 5 speed.
  3. May 23, 2011 at 6:17 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
  4. May 23, 2011 at 6:21 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I skip sometimes depending on circumstances (going downhill, accelerating slowly, etc, etc).
  5. May 23, 2011 at 6:24 PM
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    wont hurt a thing
    manuals are made for that kind of shifting
  6. May 23, 2011 at 9:10 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Push in the clutch and move the lever wherever you want. The beauty of a manual.
  7. May 23, 2011 at 9:27 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i skip 5th all the time.
  8. May 23, 2011 at 9:27 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well the main road in my town has a 30mph speed limit and is about 5 miles before I get to the faster roads. So I take off in 1st, then hit second till 30 mph and just throw it in 4th to cruise. Now if I need to go faster than 30 then yeah you need 3rd.
    BTW my SR5 and your TRD have identical drivetrains other than your e-locker.
  9. May 23, 2011 at 9:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well you don't want to accelarate with the RPM's that low because it is bad for the engine. But for just maintaining a constant speed on flat ground 1200 rpm is fine.
    BTW I have 4.10's in my rear end, which should also be the same as you.
    Also you are right about using second if you're not completely stopped. 1st is only to be used for starting off, or slow crawling in traffic or something.
  10. May 23, 2011 at 9:40 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    nope perfectly fine, I do the same thing. Right at about 1k rpm it should slip right out.
  11. May 23, 2011 at 9:43 PM
    Hardscrabble
    Scott
    McDonough, GA
    No harm done.
  12. May 23, 2011 at 9:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Its easier and helps save on brakes to just leave it in gear till it goes down to about 1k rpm. When I was still getting used to this truck I just kept a little bit of constant pressure on the shifter while slowing till it slides out of gear.
  13. May 23, 2011 at 9:56 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    same here, I've never owned an auto and don't see myself owning one till Im old lol.
  14. May 23, 2011 at 10:01 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    do all of you guys look at the rpm's while shifting? i dont ever look anymore
  15. May 23, 2011 at 10:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    ever since driving my old Sonoma for 8 months (no tac) I dont. Only when having a little fun on the on ramp:D
  16. May 23, 2011 at 10:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yep, rear bumper has been black for over a year. I couldn't stand the chrome:D
  17. May 24, 2011 at 6:23 PM
    Toycan
    Ontario
    11 TRD S DC Grey
    Thanks a ton, good to know that I'm not alone on minimizing shifts when I can.
    Good input, Caio for now
  18. May 24, 2011 at 6:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ok, I'm sure I'm going to get blasted again but a Retired MP Sargeant friend (I know, it's HIM again) says to ALWAYS use clutch, always shift sequentially (big word for me) through each gear both up and down; it aligns the syncros so it shifts properly through the gears; if you don't you will eventually wear out the syncros and you'll be rebuilding your transmission. My .02 cents worth.
  19. May 24, 2011 at 9:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    as long as you rev match you're fine, makes no difference weather you skip a gear or not.
    I agree on the always using the clutch part though.
