Skid Plate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josh0351, Oct 26, 2013.
  1. Oct 26, 2013 at 3:32 PM
    josh0351
    josh0351 [OP] Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Have been searching and researching and probably gonna get a skid plate next.
    Should I go with the TRD skid plate, or one of the after-market plates available? I like that a lot of the after market plates come in several pieces for optimal protection.
    Thanks for the feedback in advance...
  2. Oct 26, 2013 at 3:38 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    It's all personal preference. I went with the Trd skid cuz I wanted to keep the oem look, but to each their own
  3. Oct 26, 2013 at 3:43 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Do you offroad alot, sometimes, not at all?
    Aftermarket if you offroad, because the stock skids are just stamped sheet metal at best. Aftermarket is usually plate steel to take a pounding and protect your vital equipment.
  4. Oct 26, 2013 at 3:48 PM
    josh0351
    Josh
    VA
    Some stuff...
    Haven't been wheelin in this beast, but my last Yota was out quite a bit.
    This one will be wheelin eventually so probably falls into the "sometimes" category. It will spend a lot of time in the mountains on overnight camping and weekend fishing excursions mainly. So very primitive dirt roads with some exploring OR for new water and/or camping.
  5. Oct 26, 2013 at 4:30 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    OEM plate is minimal protection and mostly just for show. Hell... I've got one on my truck but I don't off road hardcore. If you plan on getting into anything rough go with aftermarket. The OEM looks good but that's about it.
  6. Oct 26, 2013 at 5:23 PM
    SAXD Taco
    SAXD Taco Well-Known Member
    Justin
    Atlanta
    2013 DCLB, 4X4, MGM
    N-Fab Steps, BakFlip F1, TRD Accessory Skid Plate, Toyota Bed Mat, Husky Liner Floormats
    I actually just went through making the same decision. I ended up getting the TRD accessory skid, mainly because I don't do any serious off roading. Mainly just fire/dirt roads up in the mountains with the occasional excursion off the beaten path. Since it makes me cringe getting the tree branch pinstripes, let alone body damage, I doubt I'll ever need heavy duty skids. However, if you plan to do any serious off roading I would look at something more substantial.
    Have you checked out Matt123's skid out in the for sale section? It's a little more expensive than the TRD accessory skid, but it is made out of 10g stamped steel, which should take more of a beating than the OEM one. It also looks very similar to the TRD accessory skid.
  7. Oct 26, 2013 at 6:26 PM
    zzchipster
    zzchipster Well-Known Member
    2013 taco 4x4 trd lwb trd sc
    trd s/c and exhaust, 5100's,bud builts
    check out bud built....i dont think u can get anymore protection...i have had for 2 years and they do what a skid plate should do. when i was in silverton colorado last year i went over several rocks that made me glad i had that level of protection. ...there are other manufacturers that provide this type or armour...
  8. Oct 26, 2013 at 6:44 PM
    schwangster
    schwangster Well-Known Member
    Dale
    Qualicum Beach/Baja
    2013 AC, Ironman/Duratracs
    Ironman
    Matt123 builds awesome stock-looking but beefy ones. Well worth the upgrade.
  9. Oct 26, 2013 at 9:46 PM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    Wut!
  10. Oct 27, 2013 at 8:21 AM
    Pearcem87
    Pearcem87 Well-Known Member
    2013 TRD Off Road
    I got the budbuilt skids plates, and they offer fantastic protection. Easy to install, and well made. If you want to save a little weight, they are also offered in 1/8th inch steel. Beefier than the TRD, but not as heavy as most of the other steel aftermarket. My only complaint is that mine will vibrate occasionally. It's not really bad, but there is about a 200-300 range of RPMs that they will make a little noise.
  11. Oct 27, 2013 at 8:50 AM
    RearViewMirror
    Craig Christ
    Could you put a small rubber grommet in between the plate and where it touches the frame? That might take care of your vibration.
  12. Oct 27, 2013 at 8:29 PM
    Biodegradable
    Biodegradable Well-Known Member
    Winnipeg
    10 4x4 SR5 DBLC LB
    ALL-PRO Skid, Nokian R-SUV winters, weather tech, bak flip fibermax
    I took off my stock skid after hitting an ice chunk while driving on frozen lake - nice dent in it. Now that's the only "off-roading" I do.
    I picked up the All pro 3/16 steel plate 54lb skid for $269 plus shipping. Pretty trd skid which is just a cover add on is
    1/8"-thick heavy duty aluminum and $165ish. It's a pretty easy decision imho. Get the proper one and you won't ever have a problem - paint it silver if you need it to show off.
  13. Oct 28, 2013 at 9:44 AM
    Pearcem87
    2013 TRD Off Road
    Yep, this is the exact issue. I spaced the plate and reduced the contact a lot, but it still does it a little bit. Just something to know ahead of time, I still love the plates.
  14. Oct 28, 2013 at 9:48 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Relentless :)
    Much better
    oh and go the fuck away
  15. Oct 28, 2013 at 11:37 AM
    zzchipster
    HEY MAXAMINION...STILL PITCHING RENENTLESS JUNK...
  16. Oct 28, 2013 at 11:38 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    :popcorn:
  17. Oct 28, 2013 at 11:39 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  18. Oct 28, 2013 at 11:42 AM
    zzchipster
    I had some initial rubbing also...just took a small shim to fix at crossover..when u bolt it up just look where it goes and make sure u have an 1/8" or so clearance...
  19. Oct 28, 2013 at 12:02 PM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    i have a Matt123 Skidplate also.. love it!
    jmfond likes this.
  20. Oct 28, 2013 at 12:12 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Your worthless self couldn't even come back and defend the shit talking threads you started.
    Oh and just so we're clear, yes Eric is my friend, but I wouldn't defend (or promote) poor craftsmanship or shoddy business practices. Whatever issues you had with Eric were self inflicted, and you made that clear for all to see in the threads you started. How'd those threads work out for you?
    Just FYI, caps just makes you look like an idiot.
    Edit: and I really do think Eric makes bad ass skid plates and I run them on my truck, in fact, the pictures on his website of his skids are of my truck.
