Spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mobbinkelto, Apr 4, 2013.
  1. Apr 4, 2013 at 3:09 AM
    mobbinkelto
    mobbinkelto [OP] Member
    2010 Toyota Tacoma Mag Gry/2016 Toyota Tacoma Sport
    when I run 1.25 spacers do I need to get new studs and what not?
  2. Apr 4, 2013 at 3:55 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
  3. Apr 4, 2013 at 4:17 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    If you're talking about wheel spacers, they will have their own studs on them, and are made to work with your stock studs. Do not change your stock studs.
    If you are talking about coil spacers, they also have their own studs and are designed to work with your stock studs.
  4. Apr 4, 2013 at 4:30 AM
    Walker T
    Walker T Well-Known Member
    Greenville SC
    Silver 4x4 V6 SR5
    De-Badged. Headrests adjusted, Redline Tuning Hood Struts, Secondary Air Filter removed, BTLM
    If you are talking about wheel spacers, go here;
    http://www.gorilla-auto.com/lug-nuts-page-11
    The product you want is 68037, you need 24 of them, these are extended thread, open faced, conical lug nuts that will secure the spacers to your existing hubs. Then you can use your existing lug nuts to secure the wheel to the spacer.
    The lugs that come with the spacers are not safe on our Tacomas, because Toyota has installed some very short lug studs, and the supplied lug nuts will only give you 2-3 turns before they bottom-out. You need the extended thread lug nuts to reach down into the bored hole in the spacer to make sure your tire does not come off the first time you hit a pothole.
  5. Apr 4, 2013 at 5:42 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If you're talking about wheel spacers, think long and hard about it.
    They absolutely destroyed the way my '09 TRD Sport rode. And you should also consider the fact that the entire side of your truck will be covered in dirt unless you only drive in dry conditions.
    They were the single worst automobile related decision that I ever made.
  6. Apr 4, 2013 at 9:19 AM
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    I put spidertraxx (1.25) on my truck in January. I've done some light-wheeling, and taken some heavy potholes and no problems yet, and that's with stock lugs. I have a slight vibe around 60 (probably my 37k rugged fails and bad alignment), but it really doesn't bother me all that much. Get the spacers, torque em down right, and when you can afford new wheels, you'll be able to sell them.
  7. Apr 4, 2013 at 9:44 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    By increasing the distance between the wheel and the hub, it effectively increases the moment arm applied to the suspension.
    I felt that they made it ride more harshly. Taking them off was a big relief.
    (this would obviously apply to the front suspension only)
  8. Apr 4, 2013 at 11:53 PM
    mobbinkelto
    thanks everyone, I'll try em out and see how it rides
  9. Apr 5, 2013 at 5:55 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The problems that I had with the spacers was probably accentuated by the fact that I drive most country roads. They never seem to be in very good shape.
    I prefer my truck to ride like it's floating on a cloud of titties.
    She did look good though....
  10. Apr 5, 2013 at 6:15 AM
    chris duby
    chris duby This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    I installed some Spdertraxx spacers (1.25") on the rear only to match the front since I installed some Maxtrac spindles and they kick out the front tires 0.75". It looks good but my truck stays dirty unless it's perfect conditions outside. I have nothing to say about the ride quality since I went from a spacer lift to spindles with the spidertraxx, but it's definitley better than before. And everything I needed for the install came in the box from Toytec.com.
