Spidertrax vs. Allpro spacers....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sincitytaco, Dec 15, 2009.
  1. Dec 15, 2009 at 4:47 PM
    sincitytaco
    sincitytaco [OP] Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    What is the major difference. I know spidertrax are know for being great, but I mean forged aluminum is forged aluminum. And they both are hub centric with grade 8 hardware.
    The allpros are however half the price.
    Chris4x4 what do you think?
  2. Dec 15, 2009 at 4:48 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    There was a member not long ago that bought the all pro. Turned out the spacer broke while driving. Fortunately for him he wasn't going highway speeds.
  3. Dec 15, 2009 at 4:49 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I have spidertrax on mine, I've beat the hell out of them and havent had any issues.
  4. Dec 15, 2009 at 4:51 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I vote Spidertrax... And I'm sure most everybody else would also...
  5. Dec 15, 2009 at 4:53 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I had the Allpro ones. They were plenty beefie, but I couldn't get them properly mounted without a shimmie at 60mph or more. I think it was just me though, not the spacers fault.
  6. Dec 15, 2009 at 4:54 PM
    sincitytaco
    Las Vegas
    Spidertrax are definately proven, but what is difference between the spidertrax and the allpros. I mean what can break with a spacer, only the studs right? Well the stud should all be the same since they are all grade 8.
  7. Dec 15, 2009 at 4:55 PM
    sincitytaco
    Las Vegas
    Well if they shimmied with the spacers, but no shimmy without then that is definately shitty.
  8. Dec 15, 2009 at 5:28 PM
    sincitytaco
    Las Vegas
    Some one PMd me this information below. I tend to agree with his findings, but would certainly like a reply from someone in the know instead of someone speculating.
    http://www.tacomaworld.com/forum/buy...ml#post1218890
    thought I would share some of my information with you.
    you are so adamant that the All Pro Spacers are shit and you base all of your "information" off of one incident. I have been considering running spacers on my truck in the future so I have been doing a decent amount of research, this is what i have found out:
    the incident that you base all of your information involved a larger spacer (2" IIRC) and a lot of user error. the guy installed lug centric spacers with hub centric wheels and then forgot to torque them, it is also the only publicly documented failure of the all pro spacers i could find. however the problem is not exclusive to All Pro Spacers, If you would search TW you would find this thread:
    http://www.tacomaworld.com/forum/whe...l-spacers.html
    If you were to search google you would find this as your first search result:
    http://www.jk-forum.mobi/showthread.php?t=107753
    the facts
    the difference between the All Pro 1.25" hub centric spacer and the late model toyota Spidertrax is the classification of the studs. all pro uses a standard Grade 8 pressed into the spacer, the spidertrax use a M12 metric bolt also pre installed (pressed i would assume)
    The Grade 8 bolt has a min tensile strength of 150,000 PSI which is more than enough for a 4200 lb vehicle. The M12 is around the 175,000 PSI range based off of conversion charts and calculations.
    Both use a solid machined piece of Billet 6061-T6 aluminum as the base.
    Just a little additional information so you can post more accurate information as opposed to gossip :)
    For reference:
    All Pro
    Spidertrax
    http://www.spidertrax.com/Toyota-Hub-Centric-Spacer
    Bolt Classifications
    http://www.boltdepot.com/fastener-in...ade-Chart.aspx
  9. Dec 15, 2009 at 5:47 PM
    sincitytaco
    Las Vegas
    actually if you read one of the links above that I posted you will see a post where the spidertrax have failed, again probably due to installation error though.
  10. Dec 15, 2009 at 5:48 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    I felt comfortable enough to buy my Spidertrax used. I'm the third owner of mine, and the two previous owners wheeled them pretty hard. Reputation is all you have to go on when things are made identically.
  11. Dec 15, 2009 at 5:49 PM
    sincitytaco
    Las Vegas
    very true
  12. Dec 15, 2009 at 5:58 PM
    sincitytaco
    Las Vegas
    What is the tensile strength on the OEM studs?
  13. Dec 15, 2009 at 5:58 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    spiderdicks
  14. Dec 15, 2009 at 6:50 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    O.k. I was looking at the pics of the blue tacoma on the bottom. It says running 285/70/17 plus Spidertrax spacers. Now, I am running 1.25" spacers plus I just went to 285's and my tires are NOT even close to being that wide. What is the difference? I am using the factory wheels though. Help!! Pics to follow as soon as this damn computer cooperates.
  15. Dec 15, 2009 at 8:08 PM
    sincitytaco
    Las Vegas
    That factory stud are 12Mx1.5 so they are identical to the ones spidertrax uses. I would like to buy some of the ASAP, where can i get the best price on Spidertrax and who has them in stock?
  16. Dec 15, 2009 at 10:29 PM
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    I searched for them a couple weeks ago and nobody had them in SoCal. So I called them directly (spidertrax that is) they are based in Colorado. The guy that picked up was very nice. He said that I could buy them directly from him and that he's ship them to my house. He said that he would do them for what ever price is listed on their website plus shipping.
    I would have done it except I needed them the next day, I ended up finding a guy that could build them for me the next day. I drove out to his shop and picked them up the next day. I ended up paying more for them than the Spidertrax cost...damn I am inpatient mofo...
    Order from them directly and pay the shipping...just my $.02
  17. Dec 15, 2009 at 10:42 PM
    sincitytaco
    Las Vegas
    Damn They are working on about a 10000% markup and they won't pay shipping, ouch.
  18. Dec 15, 2009 at 11:38 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    oh, and i got that same PM on TTORA as well....there's a reason that AP banboy....i mean fanboy has been booted a few different places:eek:
  19. Dec 16, 2009 at 12:01 AM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    i have 1.25 spidertrax on mine. easy install, and no problems or anything yet
  20. Dec 16, 2009 at 4:14 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I heard the ones on ebay are crap...there was 1 case of a guy that was out wheelin and his fuckin wheel
    broke off :eek:
