Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Feb 28, 2017 at 8:21 AM
    #1861
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ah that makes sense. Are you moving the crossmember you made? I've always had theories on how to maximize shock travel with our trucks without going through the bed or going with a wider axle. My thought was that there is about an inch gap between the bed and frame so ideally a crossmember pushing right up to that part, plus mounts on the axle that might hang down ever so slightly but be beefed up to take hits. It should be able to net at least an inch or two bigger of a shock. Of course I've never been able to test this theory yet.
    But does that not really matter as much as that is just shock travel vs vertical travel that the springs let you attain?
  2. Feb 28, 2017 at 8:23 AM
    #1862
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you'll be able to stuff 12s like that straight up and down angled back a bit.
  3. Feb 28, 2017 at 8:25 AM
    #1863
    cynicalrider
    cynicalrider #NFG
    Jersey
    That was my goal, and what I hope to do before RT. I'll be likely doing it on a set of Dakar's though.
  4. Feb 28, 2017 at 9:04 AM
    #1864
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    x2 - What did the Dakars cycle. I've got em and I'm looking to do a shock relocate soon.
  5. Feb 28, 2017 at 9:07 AM
    #1865
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I did that a few years ago with some SAW 12's, the shortest compressed 2.5 shock at the time. 2011 per the pics. I could move the lower mounts up to be about level with the bottom of the axle since like Brett the leafs don't go negative arch very much if at all.
  6. Feb 28, 2017 at 9:23 AM
    #1866
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Beauty of that kit is it uses stock hangers. Don't think anything like that exists for our trucks. I feel like I'm on a bit of a time crunch with trips coming up in a couple months. Takes a lot of time to get custom parts and the fab work to get them all setup.
    Current crossmember is most likely going when I box the frame here shortly. I don't think I'll be able to get the frame plates in with it there.
    What you describe is what I've been looking at, also have that 1" BL in the back of my head that I could use to get the upper mount up an inch.
    None of that would make a bit of difference with my current leafs though, as those are what dictate travel.
    What leafs are you running?
  7. Feb 28, 2017 at 9:38 AM
    #1867
    Moosedog
    Moosedog Well-Known Member
    Bryan
    Harrisburg, Or
    99 tacoma SR5 TRD v6
    kings, dakars, relentless front bumper, NWTI rear bumper
    Driver side: ext. 25.5 in, col. 16 in
    Pass side: ext. 25 in, col. 16.5 in
    4.5 inch minimum bump stop
    Collapsed length could be different for some people, I have the rear locker skid and it was about touch the gas tank. But at the same time the springs had pretty goood negative arch.
    I'll be going with 10" travel kings with a custom length. 26" ext, 16" collapsed in Stock location. Should give me half inch both ways of clearance.
    Edit: half inch of clearacne both ways with 5 inch bump stop..
    Squeaky Penguin[OP] likes this.
  8. Feb 28, 2017 at 10:23 AM
    #1868
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Deaver J59 I think. They started life as 7 leafs then sagged out and I had deaver re-arch and add 2 more leafs. Been holding up well since 2008 or 09.
  9. Feb 28, 2017 at 12:52 PM
    #1869
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahhh didn't know that.
    Gotta be something you could do. idk what Deavers turn around time is but you should be able to ask if they can make a SUA spring for stock hangers....that said..i have not idea if that would be beneficial.
    Welcome to my world haha the pressure is on!
  10. Feb 28, 2017 at 1:06 PM
    #1870
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Link it, you have done most of the work already (taking the bed off).
    That's a bummer though, not much to had without some major changes. Maybe just a nicer shock at this point, keep the mounts where they are.
  11. Feb 28, 2017 at 1:10 PM
    #1871
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nicer shock and start tuning it good. Still ride good and work good.
    Guess it all depends on the direction of the build..
  12. Feb 28, 2017 at 1:32 PM
    #1872
    Squeaky Penguin
    Brett
    This is the easiest direction to head, and realistically, probably what I'll end up doing. Just seems like a lot of work and money going into what is not the best setup.
    I really want to say screw it, go SUA, and shocks through the bed. This will then ruin the usable space in the bed, and I probably couldn't sleep back there as easy. So then I would build a bed rack and get a RTT. And then I'll have spent entirely too much money on this pile for the second year in a row.
    jubei likes this.
  13. Feb 28, 2017 at 1:38 PM
    #1873
    Blackdawg
    Monte
    Wyoming/St. Louis
    spending too much money on our piles is the point :p
    Probably couldn't sleep back there anymore that's probably true.
    Again, all depends on what you want out of the truck. Redoing and dialing in your current setup can still merit good results. Travel isn't everything..valving is.
  14. Feb 28, 2017 at 5:45 PM
    #1874
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I haven't checked in here on this thread for a long time. Glad to see people referencing my work! :)
  15. Feb 28, 2017 at 6:17 PM
    #1875
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I am done thinking it through. It's time to get the phuck out there and adventure this year!
    jubei likes this.
  16. Feb 28, 2017 at 6:21 PM
    #1876
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    This needs to be my motto.
    Because shit is never, ever gonna be 'done', and its way too easy to overthink things.
    Gramps[QUOTED] likes this.
  17. Feb 28, 2017 at 6:29 PM
    #1877
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah but young Brett has had more adventures in the past year then I. This year my shit will be "done" for the season and I want to get out more. I need to use my shit!
    jubei[QUOTED] likes this.
  18. Feb 28, 2017 at 6:33 PM
    #1878
    jubei
    NoCo
    Stuff. Also things.
    Here here.
    I don't get time to camp and wheel much anyway. I really don't want to let my OCD for having things perfect keep me from using my truck for precisely the reason I own it!
  19. Feb 28, 2017 at 6:49 PM
    #1879
    Squeaky Penguin
    Brett
    After lots of thinking, just going to get 10" smooth bodies and dial them for now.
    Hell yeah! I just need to get this thing off jackstands to be ready to go in a couple months. :anonymous:
    Work on the truck in winter and spring, wheel all summer long. Worked for me the last couple years. I'm sure I'll be working on new and different projects next year as well. No reason not to get out no matter where you're at in your build.
    Oh, and some redneck engineering:
    [​IMG]IMAG0191 by brettbjorgum, on Flickr
    1" longer shackles gained 3/4" of droop. Negative arch doesn't look bad either.
  20. Feb 28, 2017 at 7:03 PM
    #1880
    cynicalrider
    cynicalrider #NFG
    Jersey
    Good to know. I have both stock and slightly longer shackles so if I can use them to net a little more droop I dig it. Still not sure how shackle length affects ride height though. I feel like my angle isn't ideal but can't remember why.
