SR5 Remote Start - 1H Connector 90980 – 12944 Pin Size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaC, Jan 25, 2023.
  1. Jan 26, 2023 at 7:22 AM
    YotaC
    YotaC [OP] Member
    I'm not sure what the full schematic looks like. Only that the remote start requires interrupting that signal to keep the keyless remote working after remote starting.
    It is pin 33 on the 1H connector near the left kick panel.
  2. Jan 26, 2023 at 8:03 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    TPMS and keyless entry share certain components, so it makes sense.
    Jeff
  3. Jan 26, 2023 at 11:29 AM
    caribe makaira
    Caribbean, Puerto Rico
    That is just fused Ignition power...hmmm
  4. Jan 30, 2023 at 7:55 AM
    YotaC
    YotaC [OP] Member
    I just wanted to provide an update in case this proves useful for anyone installing the remote start on a Gen 3 and not wanting to cut the TPMS/Ignition wire.
    I was able to locate some wiring connectors on a Scion car in a junk yard that had the same style terminals/pin in the connector as the 1H. I depined my 1H (as shown in aftermarket remote start manual) and installed a flying lead or pigtail wire in its placed. From there you can make your circuit up to complete the remote start install.
    Or just cut your wire. :)
  5. Jan 30, 2023 at 8:42 AM
    tacos4u
    tacos4u Active Member
    You don’t have to cut it. Strip the coating off of it in the middle make a hole in the wire you can slide the other wire through, twist it and solder. No cutting if the wire. Tape it
  6. Jan 30, 2023 at 8:45 AM
    YotaC
    YotaC [OP] Member
    True. But if you want to keep it where you can switch back to Factory with no signs of damage to the wire the depin can do it.
    Also, I didn't test this but I think the remote starter needs to be in series so a tap wouldn't work.
  7. Jan 30, 2023 at 11:31 AM
    caribe makaira
    What did you do with the removed terminal and wire? ...Mating male terminal and some heat shrink? Or wrap around bare copper and tape?
  8. Jan 30, 2023 at 11:36 AM
    YotaC
    YotaC [OP] Member
    I used a male terminal coming from my remote starter to plug into the factory female sumitomo terminal. I then heat shrinked it. I should have taken some pics but the dash is back together for now.
  9. Jan 30, 2023 at 11:45 AM
    caribe makaira
    YotaC[OP] likes this.
  10. Jan 30, 2023 at 12:01 PM
    caribe makaira
  11. Jan 30, 2023 at 1:06 PM
    caribe makaira
    YotaC[QUOTED][OP] likes this.
  12. Jan 30, 2023 at 1:54 PM
    caribe makaira
  13. Jan 30, 2023 at 2:53 PM
    tacos4u
    You would never see it snip the wire off and wrap it in the cloth type electrical tape no one would even know.
    Definitely works not a tap directly wire to wire.
  14. Feb 2, 2023 at 12:14 PM
    taintsandtacomas
    taintsandtacomas New Member
    Does anyone know what the pin type/size is for the 1H connector? Specifically pin number 33.
    RE: I believe the connector you are looking for has the part number "82998-24290" . I have seen these in the past and have been able to use some from other manufacturers as well. Just play with it enough and you get it in there.
    Also, when working in these winter conditions its a good idea to wear gloves to protect your skin from drying out and cracking. That along with some gold bond always does the trick for me.
  15. Feb 2, 2023 at 12:20 PM
    #35
    HabibTheGOAT
    HabibTheGOAT New Member
    RE: Jergen's is also really good. I notice in this picture I can see every crack and crevice in your hand. Like taintsandtacomas said gloves are a MUST when you are working in these environments. I feel like I know what your exact fingerprint looks like just from this picture. Apply some lotion and have a nice day!!!!!
  16. Feb 2, 2023 at 12:27 PM
    #36
    YotaC
    YotaC [OP] Member
    LOL! Naturally wrinkly hands. Lotion will not fix those problems. LOL
  17. Feb 2, 2023 at 12:32 PM
    #37
    taintsandtacomas
    You're Right!! Those hands are basically sand paper. Poor fella.
    He must be very hard, worker.
  18. Feb 2, 2023 at 12:34 PM
    #38
    HabibTheGOAT
    For real though, you will want to be very careful grabbing those wires.....
    Pretty high chance you will cut through the insulation with those dry puppies.
  19. Feb 2, 2023 at 12:36 PM
    #39
    caribe makaira
  20. Feb 2, 2023 at 12:39 PM
    #40
    taintsandtacomas
    I know these struggles. Gold bond makes a "working hands" formula that doesnt leaving me feeling all greasy after. The part number is B008WERFUO
