Stabalizing a motorcycle in the bed
Discussion in 'Motorcycles' started by obanion63, Nov 12, 2010.
  1. Nov 12, 2010 at 12:01 PM
    obanion63
    obanion63 [OP] Active Member
    Arnold
    San Diego
    10 SR5 4X4
    Bull Bar
    I have a 2010 Tacoma long bed. I wanted to add some additional D-rings in the front of the bed to secure my 2001 Honda Shadow. I went to truck shop and they said that adding new D-rings was not possible with the compsite bed Tacomas come with.
    Would the rings on the slide tracks around the bed work? I know they say max load 250lbs but my concern is they are high and it would be harder to tighten the front fork down.
    Any suggestions on how to securly strap the bike down would be great!
  2. Nov 12, 2010 at 12:11 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
  3. Nov 12, 2010 at 12:11 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
  4. Nov 12, 2010 at 12:16 PM
    Danosabre
    Dan
    Gardner,Ma
    09 TRD Off Road
    What Shadow do you have? I have a 2001 Shadow Sabre.
  5. Nov 13, 2010 at 7:06 AM
    obanion63
    Arnold
    San Diego
    10 SR5 4X4
    Bull Bar
    its a shadow spirit
  6. Nov 15, 2010 at 10:47 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Add the additional D-rings. Mount them under the bed mounting bolts. They are plenty strong mounted there.
    For securing, I recommend soft loops for the fork
    Ratched down just enough to stabalize the bike. Don't compress the crap out of your suspension. You'll get leaky for seals.
    I don't recommend canyon dancers for the bars. They are convenient, but they put a lot of stress on the bars.
  7. Nov 15, 2010 at 10:51 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Just follow that post in the free/cheap mods section. I also did this mod and added 4 extra D-rings in my 2006 DC SB Tacoma. We also did my buddies 2010 DC LB Tacoma as well. I pack around a 2008 Honda CRF250r with no issues at all.
  8. Nov 15, 2010 at 11:06 AM
    Cutter29
    Cutter29 Well-Known Member
    Utah
    15 Tundra TRD PRO
    i added two D rings under the front mounting bolts and use a soft fork strap. i strap my R6 down to all 4 D rings and have never had any issues.
  9. Nov 15, 2010 at 11:16 AM
    ThisGuy
    ThisGuy Well-Known Member
    Brad
    litchfield park, az
    All Black 2010 4x4 DC TRD Sport
    3" lift, PC wheels, 33" Cooper SST. Volant intake w/ scoop, Gibson exhaust, black tails & 3rd, grillcraft black mesh....more to come
    I have an extra set of canyon dancers ill sell ya for $20 shipped. they were used like 5 times at the most
  10. Nov 16, 2010 at 8:15 PM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    I've d-ringed the back, using the bed mount bolts. I tie down both of my race bikes on the two rings up front, and use the rear rings with one strap, going from ring to ring, through the swingarm and wheels.
    You can smash the forks down, just not for days at a time, and don't bury the fork, like buck said. I think canyon dancers work great, just be careful, because they have a tendency to squish and slide your grips, and as a result the throttle return may not work as well.
  11. Dec 19, 2010 at 7:45 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    If you have anything other than a dirt bike, you want to be very careful around the 'gate. While you can certainly load a big bike, if it bounces around, you could bend the tailgate.
  12. Dec 19, 2010 at 8:03 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I was thinking KTM 990 size...
  13. Sep 20, 2012 at 6:58 PM
    ikillterrorists
    ikillterrorists Well-Known Member
    Andrew
    New Paltz, NY
    Sold my tacoma, got a Dodge Ram
    TRD Cold air intake Aries Grille Guard Flowmaster American Thunder Dual Exhaust Pro comp 3" suspension lift KMC XD Hoss, BFG KM2 285/75/16 Hypertech Speedometer Calibrator N-Fab Side Steps Access Roll-Up Cover TRD Quick Shifter SafeHitch
    I put D-rings in the side of my bed...would they be strong enough to use to tie down a bike?
  14. Sep 21, 2012 at 9:07 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    I'm scared they'll like rip out or something
  15. Sep 21, 2012 at 9:10 AM
    DrewH
    DrewH Well-Known Member
    Not if it is just the composite material they are fastened to.
  16. Sep 21, 2012 at 9:11 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Canyon dancers work well for a bike with low bars. A soft strap for big cruisers is what I prefer. Do not use the sliding tie downs on the bed rail.
  17. Sep 21, 2012 at 9:29 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    I run the D ring mod to the frame bolts in the front of the bed. I also use a baxley wheel chock with canyon dancer. Bike stays up ok its own and the tie downs keep it level while in transit. I also modded the tailgate with a steel panel for longer bikes that have their rear wheel rest on the gate. Not one problem with this setup.
    OR: You could install a bed bar (runs across the bed rails) to add exrta support for the OEM bed rails. Like a strut brace but for your bed rails.
    OR: You can get a Bed Buddy that attached to the bed rail and adds additional support.
    OR: You can get Tie Down Reinforcement brackets.
  18. Sep 21, 2012 at 1:08 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    Hm well I am picking up my motorcycle tomorrow...what should I do? I only have those rings and the original ones in the back...
  19. Sep 21, 2012 at 2:19 PM
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    What kind of bike?
  20. Sep 21, 2012 at 2:29 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    Ducati Monster 695...370 lbs I believe
